XtremeSystems Forums
Reply
Old 06-08-2009, 07:51 PM   #1
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
Exclamation Confirmed: Feser 1 Blue Premix + GTZ = do NOT want
Well guys, I tore permafrost's guts up tonight because the Blue Feser 1 had lost its color and my CPU temps were terrible; here is a log of what I found.
drained liquid NOT blue
That particulate crap in the liquid is blue
looks O.K. from here....
I cringed after removing this rotary - looks like corrosion an that part is still being sorted in a bath of vinegar before I know for sure. the stuff on the toothpick is from the 45.
You know that feeling you get when you know something is gonna be really bad? I has it.
Yeah, its worse than I thought. thats not a problem with the color in the picture, its actually pitch black goop and grime.
Here is what the base looked like after I rinsed it with water and scraped at it with a toothpick. everything you see there is a hard plaque-like substance. In the top right corner (where the injector barb is I presume) the "plaque" is almost a milimeter thick.
I pick at it with a small flathead screwdriver, it takes a LOT of gauging to get it all off.
Here's how I cleaned the base after taking pics. Take a guess what that stuff is - I'll give you a hint, its not barbecue sauce....
(its Ketchup )
Its clean..... finally after a half hour of scrubbing and scraping.
looks a lot better than the first pic i took looking into the block eh?
A few notes about the incident:
-This machine was crunching 24/7 (60C load all day and night) for at least a month before I noticed the clogging via higher temps.
-The loop has a mosfet block after the outlet. this block will be rinsed tomorrow, I looked in with a flashlight and didnt see any gunk.
-This was new style bottle Feser one Premix coolant of the standard blue color.
-My only conclusion to come to is that it is NOT ok to use this Feser ONE coolant at high sustained temperatures!
This has been a public service announcement
cheers and be sure to follow my worklog for Project Flow,
-Ian H
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 06-08-2009, 07:54 PM   #2
iandh
Zombie Assassin
iandh's Avatar
Hmmm... this is rather fail-ish.
At least your block is Ok
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
iandh is offline   Reply With Quote
Old 06-08-2009, 07:55 PM   #3
MomijiTMO
Banned
Send a message via MSN to MomijiTMO
Coloured tubes + distilled ftw.
BTW, black coating on copper is pretty normal but that isn't just that, there is something else on there too. WTF barbs.
MomijiTMO is offline   Reply With Quote
Old 06-08-2009, 07:57 PM   #4
zanzabar
I am Xtreme
zanzabar's Avatar
it looks like asphalt
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is offline   Reply With Quote
Old 06-08-2009, 07:58 PM   #5
NaeKuh
Broken Gainestown
NaeKuh's Avatar
snipe id give a good 15 min boil in vinger + salt.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is online now   Reply With Quote
Old 06-08-2009, 08:06 PM   #6
Sn@ke:~
Sn@ke:~'s Avatar
use acetone with a brand new tooth brush for final cleaning.
on the copper only
Sn@ke:~ is offline   Reply With Quote
Old 06-08-2009, 08:06 PM   #7
defect9
defect9's Avatar
wow, so the GTZ is like the perfect filtration system. I should use that on my fish tank.
__________________
Watercooling Initiate (in the process of sourcing all parts)
E8400 @ 3.6Ghz (on crappy air), 4GB 1333Mhz DDR3, 8800GT G92 (not OC'd yet), Zalman ZM1000 PSU, CM Cosmos 1000 Case, AuzenTech Forte 7.1, XSPC RX360, assorted Scythe fans all around
Still Left: CPU Block, Tubing, Fittings, Pump, Top/Res
Originally Posted by Conumdrum View Post
I just tighten them with a pipe wrench till they break, then back off half a turn.
Originally Posted by Sadasius View Post
That's right...I said it....You broke your bunghole!
defect9 is offline   Reply With Quote
Old 06-08-2009, 08:08 PM   #8
ColonelCain
ColonelCain's Avatar
Damn... and I thought that the build-up I found from Pentosin was bad...
__________________
For all of your Watercooling needs, head over to Petra's Tech Shop.
"Never skimp on the Power Supply" -Me (HEAT)
Do your senses a favor, get the Klipsch ProMedia 2.1 sound system.
Build
E8400 @4.0(for now) | DFI LT X38-T2R | 4x1GB Ballistix PC8500 @Stock(for now) | HD3870 | PCP&C 610 | Creative X-Fi | NEC 1970GX LCD | Heavily modded Aspire X-Cruiser
Watercooling
MCP655 -> Swiftech MicroRes v1 -> Dtek FuZion v1 -> BIP 2X120 [suspended off case DIY] ->MCW-60 -> PA160 w/shroud [Inside of case ] ->MCP655 Tygon 5/16, PT_Nuke + Pentosin, Yate Loon D12SM-12's for rad's.
ColonelCain is offline   Reply With Quote
Old 06-08-2009, 08:28 PM   #9
LOUISSSSS
Banned
so the culprit is definitely the feser1 fluid?
LOUISSSSS is offline   Reply With Quote
Old 06-08-2009, 08:32 PM   #10
shazza
Xtreme Fan
shazza's Avatar
I dunno ... I'm not saying it isn't the Feser One. Mine has been in place with the GTZ for over 4 months ... running mostly 24/7. But, there is nothing else in the loop. My temps at load are in the 55 degree range. I'll keep an eye on it and report back.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 06-08-2009, 08:34 PM   #11
Diverge
Diverge's Avatar
with your block looking like that, would you have to worry about what the inside of your rad looks like?
__________________
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [HIS HD 5970] [SeaSonic X750 Gold ] [Windows 7 (64bit)] [OCZ Vertex 30GB x3 Raid0]
[Swiftech MCW30, Duniek DFI X58 Mosfet Block, D5 w/ Typhoon III] [Swiftech Apogee GTZ] [TFC 360 rad]
Diverge is offline   Reply With Quote
Old 06-08-2009, 08:35 PM   #12
hellcamino
hellcamino's Avatar
Ouch! I should have taken some pics of my recently rebuilt loop, over six months months running distilled + 10% green antifreeze and everything was shining like new! I found what looked like a tiny piece of paint or delrin caught in my cpu block and nothing else.
__________________
Originally Posted by Movieman View Post
I don't care, I'm running out of popcorn waiting for the results..
hellcamino is offline   Reply With Quote
Old 06-08-2009, 08:42 PM   #13
Baleful
Banned
Lmao, and how long have we been saying additives and mixtures BREAK DOWN OVER TIME. Some last longer than others, but at the end of the day they will always break down.
Baleful is offline   Reply With Quote
Old 06-08-2009, 08:45 PM   #14
Adamantine
So... all of the blue coloring got caked on the GTZ?
__________________
Cosmos S | Antec Signature 850 | Core i7 920 | DFI X58 | 12GB Super Talent DDR3 1333 Samsung HCH9 | eVga 280GTX | 2x eVga GTX275 | VelociRaptor 300GB | BD-ROM
Loop 1: TFC360 | HeatKiller 3.0 CPU w/ Koolance Backplate | MCP355 attached to XSPC dual bay res top
Loop 2: MCP355 attached to XSPC dual bay res top | Swiftech MCR220 + MCR220 Stack | Swiftech MCW60-R w/ GTX280 FC Plate | 2x Koolance NX275 Waterblocks | Enzotech NB
Adamantine is offline   Reply With Quote
Old 06-08-2009, 08:47 PM   #15
MpG
MpG's Avatar
What I'd like to know is why the gunk seems concentrated exclusively in the GTZ, and is worst BEFORE it hits the pin-grid. Something to do with the impingement region? That doesn't happen in a mosfet block, which might explain it's (apparent) cleanliness.
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
MpG is offline   Reply With Quote
Old 06-08-2009, 08:51 PM   #16
Serpentarius
Serpentarius's Avatar
look like tar ..
ok, is that copper oxide? the black color?
Serpentarius is offline   Reply With Quote
Old 06-08-2009, 09:02 PM   #17
defect9
defect9's Avatar
wait, was there an algae inhibitor in the loop? or no?
__________________
Old 06-08-2009, 09:15 PM   #18
eRazorzEDGE
eRazorzEDGE's Avatar
the premix's are supposed to contain all of that stuff.
that's horrible sniipe. would definitely check the rad as suggested above, too.
eRazorzEDGE is offline   Reply With Quote
Old 06-08-2009, 09:15 PM   #19
millertime359
Xtreme Guru
millertime359's Avatar
Feser 1 has algae inhibitor in it. Check here
That is nasty. Let us know how everything else looks. It is weird that its not blue though, its black and after only a month.
I've had the Feser 1 black coolant in mine for a week now and no problems, but I haven't been loading it down yet. I would like to start doing some crunching and folding here soon, so any more info on this would be great.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 06-08-2009, 09:20 PM   #20
yonton228
Send a message via MSN to yonton228
Holy hell man...... Glad you got most of cleaned up.
-yonton228/timmy
__________________
"Man, I wish my country wasnt run by liberal mangina's that piss their pants at the sight of guns..."-turtletrax
yonton228 is offline   Reply With Quote
Old 06-08-2009, 09:26 PM   #21
DarthBeavis
Infected with the Ewe Flu
DarthBeavis's Avatar
I think that stuff kinda looks like Soylent Green in its gelatinous form. . .or resin from a pipe . . .not that I would know what that looks like
__________________
Please stop by my blog: www.outoftheboxmods.com
DarthBeavis is offline   Reply With Quote
Old 06-08-2009, 09:28 PM   #22
SNiiPE_DoGG
yeah guys, I get up at 630am for work every day so I only have a little time each night to do things; I will thoroughly rinse the rads and setup a pump loop through the mosfet block alone to make sure its clear of gunk.
It was really bad, and as I said in my conclusion in the OP I'm almost sure the 24/7 crunching @ 60C had a major role in the cause of this crap separating.
__________________
Old 06-08-2009, 09:30 PM   #23
Erasmus354
Banned
Simple, it backed up in the grid first and worked its way back towards the entrance and started building up more and more from there.
Here is another vote for colored tubing, silver antimicrobial, and no additives at all.
Erasmus354 is offline   Reply With Quote
Old 06-08-2009, 09:33 PM   #24
fox3
fox3's Avatar
Wow that looks nasty, glad I chose to go with PrimoChill PRO LRT Tubing instead of dyes.
Hope the RAD is not gunked as well. Thanx for the heads up.
__________________
ASUS RAMPAGE EXTREME || Q9650 @ 4.32GHz 1.38v || (2) x 2GB G.Skill F3-12800CL7D || SAPHIRE HD 4870 X2 || CORSAIR HX 1000W || ANTEC 1200
cuplex XT di || Bitspower AIX48SNE-BK || BP-AM48 || (2) BP-WBAMOS1-BK || feser 480 w/ (4) S-Flex F
aquaero VFD || aquatube white delrin || aquabay || tubemeter || aquastream XT Ultra || aquagratiX HD 4870 X2 wip
fox3 is offline   Reply With Quote
Old 06-08-2009, 09:40 PM   #25
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
That is just nasty.
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
