@ coop, How about some BIOS Settings please...I'm interested in your MCH/DRAM Reference setting. Thanks!
woot
Freq : 5102.29 MHz (537.08 * 9.5)
cpuZ
http://img.techpowerup.org/090223/cpuz-51.jpg
http://img.techpowerup.org/090223/es-06-28000.jpg
great job systemviper.that is one awesome OC there.
whats the highest i wanna go on the MCH Core for 24/7 ? the NB is on water
hi, wanted to ask, im searching for the best bios for the UD3P... but i see there are already 2 revisions of this board... i think mine is 1.0 but i cant see any diffrence in bios versions... seems like its the same bios...
can anyone put some light on this subject?
if the revision is the same as the UD3R it's the heatpipes that have changed, board is unchanged.
the revisions is on the mobo also on the corner where the pci slots are
All you ud3p gurus, im building a system for a friend with this board, i have e8400 i want about 3.6 stable, about 1100 mgz on the ram, i need to know what voltages you recomend ? mch ? all that good stuff, just a good starting point would be nice, i dont have time to spend days playing with this thing, thanks.
you can try my voltages
http://img7.imageshack.us/img7/9972/...032m002rj6.png
My bios settings for the 2gb @4500 P95. It took many attempts trying to figure it out. It seems the most critical ones are the ref. ones. I tried to get the lowest voltages possible with vcore, mch and dram. 1:1 is alot harder I think. Also I think I got lucky with my cpu and my dimms I've had for some time and they work pretty well even with little V. I don't know why 1:1, but to me if you want to go up in a building an elavator is easier. So is 5:6. 1:1 seems like the stairs. Unless I don't know about why 1:1. (actually I don't) If you can't use the same voltages, try to use the same ratio, what I have on mine it is essential. Thanks to those in much earlier post who spoke of this.
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
CPU Frequency .........................: 4.5GHz (500X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 500
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: 700
PCI Express Clock Drive................: 800
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 50ps
DRAM Performance Control
Performance Enhance....................: Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 333MHz
System Memory Multiplier ..............: 2.40D
Memory Frequency (Mhz) ................: 1200MHz
DRAM Timing Selectable ................: Manual
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
but tRFC 56 and Drive Strength Profiles OC-1200
DDR Write Training: Disable
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Disabled]
CPU Vcore..............................: 1.375V
CPU Termination........................: 1.34V
CPU PLL................................: 1.63V
CPU Reference..........................: 0.888
MCH/ICH
MCH Core...............................: 1.34V
Reference..............................: 0.768*
MCH/DRAM Ref...........................: 0.900v
ICH I/O................................: 1.5V
ICH Core...............................: 1.100V
DRAM
DRAM Voltage...........................: 2.22v
DRAM Termination ......................: Auto
Channel A Reference....................: Auto
Channel B Reference ...................: Auto
Thanks HiCookie, appriciate the help, is that ok for 24/7 use ?, i will try that setup. I had this board for 1 day and it burned up on me, i cant find the vista raid drivers ??????? i looked all over the cd, where do you get the raid drivers for vista 32 ???? says in the manual there in the boot drv folder, i dont see them, i want to put them on a usb.
Seems you have some different things in your settings like, strap, memory strength, and which memory are you using? brand model? etc
i`m with OCZ reaper now 2x1gb but i`m thinking to change for 2x2gb of mushkin 996599 or g.skill pi series all pc2-8500 .
i`m not feeling confident with my pair of memory, maybe it is hold on my system to reach high OC, but i`ll try your settings today and see how my system responds.
New BIOS released 24.02.09:
GA-EP45T-UD3P - F6
GA-EP45T-UD3R - F5
GA-EP45T-UD3LR - F5
GA-EP45-UD3 - F6
GA-EP45-UD3L - F4
GA-EP45-UD3LR - F5
GA-EP45-UD3P - F8
GA-EP45-UD3R - F7
TT Forum
rechecking that final F6 bios for EP45T UD3P later today , as the F6A was a total bummer on my hardware...
Stasio, what are the changes of the F7 bios on UD3R?
there no changelog ever .. this is lame ...
users should know what the update is going to fix or enhance...
