Originally Posted by
WhiteFireDragon
i seem to be having a problem with ET6 i think. the CPU reference i set in bios is 0.848v, but i boot into windows, ET6 shows it as the default 0.760v. which voltage reading is correct? also, anything above 340fsb, the "smart" tab in ET6 for the CPU fan speed control is useless because it shows RMP as zero and the speed is not adjustable. is this a bug for the software or do i need to update the bios? i'm currently on UD3R F5 bios. are there any improvements for stability in F4 or F6 bios?
