C1e
C1e
Thank you Brother.
You're welcome:)
Probably been discussed already, but has anyone removed the stock cooling and replaced thermal compound ?
Sometimes it gets a little tricky if you get a bit too eager beaver & try loading things in a hurry.
I have got into a habit of loading the chipset drivers first then teaming then lan & so on perhaps re running/loading these drivers in this order may help, it cant hurt to try.
You could also try start - run - cmd - sfc/scannow & let windows replace any missing files, definitely worth a go rather than a re-install.
CN :)
This board seems to be very picky.
I have a 2X1GB set of 8500 Crucial ram.
It will boot fine with 1GB stick in any slot, but whenever I put the second stick in, it refuses to go past LED code 55, or verifying DMI data at the black screen.
Any one?
dead stick? is your dram voltage set to 2.2v?
Dram voltage set to 2.0V
I know these sticks can run on 1.8V as it is.
Will try switching sticks.
Is it me, but does this board need a significant amount of force to get the sticks to "click" in compaired to others?
I have a set of Tracer 8500's & they run real good in this board.
The only time I have had post/boot freezes is with the 1107 BIOS, my board hates it for whatever reason :shrug: but I don't hear anyone else complaining about it so I think it must just be me.
CN :)
What bios should I update to.
Latest?
that works 15% of the time for me:(
also i know the tracers work well how about these mushkin?
any user info?
1066
http://www.newegg.com/Product/Produc...82E16820146677
1150
http://www.newegg.com/Product/Produc...82E16820146686
So heres the deal on the ram..
I have confirmed both sticks work.
I have boot into windows with them each, but when I put them together, I stop at either code 50, 75 or Verifying DMI Pool Data......................._
I'll keep working at it.
Tnx.
Well a bit yes, i have enough room for another Noctua and i thought of putting in into a push-pull combo, though the TR is already in a air tunnel made my three 120mm silent CM's.
I think i takes a couple of degrees in load no doubt.
Wow. I don't get that temperature drop with the side off and a biga** fan blowing in :(
If you were going to mount that Noctua on the NB heatsink how would you secure it? Drill holes in the topmost NB plate and bolt the NC-U6 down onto it? I'd like to get the NB idling a little cooler than 45C.
Oh I see you've got your's in a 900 now so you're already all set. Nice case, isn't it: What are you seeing in the way of NB and CPU temperatures at whatever you've got your 6750 at? I'm at 450x8 and under load I'm peaking 65C in coretemp, the NB tops out at 51C. I can get it to 475x8 but not without going beyond 1.5Vcore, and FSBs over 477 or so just aren't stable for me
Hey , Anthrax.....Dude, whats up with that Picture....lol:rofl:
LOL not sure but I found it funny.
Brother, Do my temps for chipset and PWM seem ok?
According to Smart guardian.
CPU: 21C
PWM: 34C
Chipset: 39C
This is WITHOUT the transpiper or replaced TIM on the board.
Yes but that also depends on what clocks you are at and what you're ambient is too!
I think this board honestly hates my ram
Another C1 error, will not even get to the bios.
I just had it working and I made one small change in the bios and now I have a C1.
30 minute clear, Battery out, Power cables out and PSU off dosen't do it, and EZ clear dosen't do a thing either.
I can only run on 1 stick, 2 dosen't even post. I have set the Vdimm to 2.15, more then enough for these sticks.
Hopefully someone can help
If you want a Programmed Bios Chip let me know sometimes Bios chips become corrupt!
