well if one is 1fps and the other is 3 then 2 fps means much :D
683/734 means a 10% increase... not too bad
"performance is good but price is not" is complete nonsense. The only case this could be true if it was the fastest card ever built or something like that.
When its performance is in the middle of somewhere, performance and PRICE are the two variables in the kick-ass-card function. Its priced $240 so its performance is not good at all, it is bad. If it was priced $200 its performance would be "good" and even then not extremely so
Exactly. Those min fps values are often I/O related (loading scene) and not strictly GPU related. The scenario you describe above is good starting point.
Looking at the posted numbers for the 470 model I'm really not impressed. The chip is huge,hot and clearly not designed with gaming in mind(but GPGPU). It will be inefficient in gaming from the perf./watt/$ POV and AMD scored a big win with the "small&scalable" approach. AMD will have little trouble competing with top fermi model even with single turbo clocked Cypress... And the 6xxx series refresh is not even here...
You mean 5000 series "refresh"
6k series will not be a refresh, as stated many times by AMD since last year or maybe longer than that. New architecture, most likely Q4 launch with Q1 availability.
Now a "5890" with 1Ghz clock should compete with the Fermi just fine although I'm afraid of what AMD will charge for that one.
Really, comparing two cards that don't have the same mem size at high resolutions is just silly. Of course a 1GB card is going to lose vs a higher memory card at 2560 res.
Come back with a 2GB 5870 comparison then we can see realistic results. Sadly, both cards don't exist for consumers atm :ROTF:
where did you get the idea fermi was designed without gaming/graphics in mind? it has one of the biggest firsts for graphics: parallel setup. ATi has some patents on this too so we might see that in their future gpu's. double precision isnt as fast on geforce and the caches are used for graphics. there isnt much gpgpu hardware holding back graphics. they are not that different anyways.
read the graphics whitepaper.
http://www.nvidia.com/object/IO_86775.html
GTX 470 with 220W TDP doing 10% worse than 5870? No thanks.
LOL @ these cherry picked benchmarks @2560x1600 where the 5870 is obviously running out of memory.
yeah, it looks like the performance slides from both AMD and Nvidia. An independent reviewing site shouldn't do things like this
The reviewer gave numbers, not graphs.
It's only the Unigine one that's off, and the scores are misleading: 29 vs 27FPS is not 734/683
Anyways, min fps on one Crysis Warhead run? He should have run it at least 3 times, to eliminate the possibility that it was a single hitch or I/O error for example. Then again, PHK got in trouble for biased benching the GTX2xx's vs the RV770 back in the day./shrug
of course I've "seen" them before, made them from the data posted in this thread... :rolleyes:
http://www.madshrimps.be/vbulletin/f...website-70508/
do I detect sarcasm? ;p
blame Excel 2007 :(
for the other charts it auto-scaled the values correctly, starting at 0, that's how I like all my charts (check www.madshrimps.be charts if you don't believe me);
for the last one it didn't start from 0 for some reason :shrug:
ah well... thing to take away from those chinese benchmarks is that GTX 470 is slower than HD 5870, no matter what synthetic benchmark output says
Since when a 5870 is midrange and a GTX 470 is a "real high end monster"? That's funny
edit
Oops, you're right, I screwed up my math :rofl:
Uh, and how do you guys know that games aren't reaching the limits of shading/texture power? Neither side might have "screwed up", it might be that hardware is reaching a saturation point
