Well here we go again, Q9650@500 4,0GHz and 4x2 OCZ Reaper PC8500@1000 555 15 tRD10.
Itīs stable with 30 loop LinX (~3,5hrs, max problem size and max memory use), 10hrs with four instances of P95 blend, Is it stable or what. :rofl:
Pretty nice 24/7 setup I most say. ;)
http://i282.photobucket.com/albums/k...autotRD1-2.jpg
Code:Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 8
CPU Frequency .........................: 4.0GHz (500X8)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 500
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: Default
PCI Express Clock Drive................: Default
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 50ps
DRAM Performance Control
Performance Enhance....................: Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 400MHz
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ................: 1000MHz
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enabled]
CPU Vcore..............................: 1.3875
CPU Termination........................: 1.30
CPU PLL................................: 1.57
CPU Reference..........................: 0.760 (ET6)
MCH/ICH
MCH Core...............................: 1.34
Reference..............................: 0.840 (ET6) one step up or down, LinX error within 5min
MCH/DRAM Ref...........................: Normal
ICH I/O................................: Normal
ICH Core...............................: Normal
DRAM
DRAM Voltage...........................: 2.10
DRAM Termination ......................: Normal
Channel A Reference....................: Normal
Channel B Reference ...................: Normal
