Wow these legendary CPUs are still kicking!!
check my sig :D
wow, looks you got a great one bro :toast:
only with that low voltage. :eek:
you know: good low voltage cpu's are most not good with high voltage/clocks.. or has a horrible coldbug. :yepp:
I don't think that chip has a bug that's SO bad. Most B1 chips from about the same week +- 6 weeks don't;) It seems as if the latest chips have the worst bug (0633 and up). This is a 0620.
My 156 is here, btw:D I think it can do the same as the 3800+, booted nicely on 3g/1.216v and ran orthos for a couple of minutes before I stopped it. 3.3ghz/1.39v atm, but not stable... My cnps9700nt isn't very flat, only makes contact with 1/3 of the IHS:yawn: That's why the temps go through the roof at stock voltages:D
Coldbugwise it should be nice, my 152 can take -15 for 290mhz htt:) And it's almost the same batch!;)
2 FX53's, 1 3200+ sempron, 1 Opty 1218, Opty 144 s940, 3100+ sempron s754, 4 opty 842, 2 2x512mb kits (hopefully BH5, but not sure) and Iwaki RD30 + Meanwell DC power supply unit - that's what I got today:D
this weekend we have an oc-session with our overclocking team switzerland. my first steps on am2... and ~25x socket a cpus.
but after the 6400+ oc try i'll be the ln2-buddy.
Is that the 6400+ from Dukee ? This should be very good under Dice or LN2 ;)
@ Knut
0620 isnt so ggod I think. should do 3.5 to 3.6 ghz I think.
yapp it's that one of duke. (only one e, dukee is from germany ;)) the monster-tube will do his job. :)
3day left.
btw: ripping.org cracked today the 1/2 million visitor mark. and there are more people from china on the site than ever.
We'll see how that 0620 does in a little while;) I'll try it on a TT BT when my Venus arrives.
Btw, 230x14=3220MHz/1.31v is my new 156 24/7 setting:p:
This thing totally smokes everything else I have, the only downside is that the temp sensor is a bit crazy. No idea what to think about the temps. idle in BIOS is 39c at this setting. Core temp reports 22-23c, and 35-36c load. ITE reports 33-34c idle, and 43-44c load.
If the BIOS reading is correct, then this chip should be in the low 50's load. On chips I KNOW have decent temp sensors, the core temp is never lower than ITE temp - so by looking at it that way, the BIOS reding looks most right. The 9700nt I'm using had contact with about a third of the IHS (in the middle, but NOTHING near the edges). After a wuick lapjob it's slightly better, but since all I had was a sheet of 180 grit paper as well as a 400 grit sheet, the results weren't the best. I guess it's having contact with half the IHS now, but it's more scratchy than before.
Any comments about this temp "problem"?:)
I could give you one screen from my Opteron 156 under air and default vcore....let me search it. I have the same temps like yours so it should be real. Read out with smart guardian and speedfan. Core temp didn´t works correct.
not bad. ;)
let's play
http://octs.bastel-gianni.ch/octs-schrot.jpg
http://img258.imageshack.us/img258/9980/dsc04347jj7.jpg
:D 230L LN2 yammie!!!
hehe, good luck gianni :D
thanks... spent 500$ for ln2 & dice. :D
WOW awesome looking GPU containers gianni-gt :eek:
@ Knut
I receaved your mail ;) I could send the FX-55 together with the FX-53 to safe shiping costs ;) When do you want to pay for the FX from ebay ?
@ gianni
Good luck with the "other" hardware :D
yeah no.7 overall amd
http://valid.x86-secret.com/cache/screenshot/391478.png
http://valid.x86-secret.com/show_oc.php?id=391478
gratz gianni. :toast:
Gigabyte GA-MA790FX-DQ6 ;)
yup, :)
@masterofthereal.
look in the cpu-z link on the left side. ;)
Nice score with such a crappy board (DFI FTW!):D
Where did the coldbug hit ya? And is this a B8 chip?;)
knut, can you show your oldest 939 CPUs? Thanks ;)
