question about GA-EP45-UD3R and Cold Boots...?
Greetings,
I am looking for some advice on my cousin's new build. Here are the specs...
Gigabyte GA-EP45-UD3R (BIOS - F6)
Intel Q6600 @ 3.2GHZ (400 x 8) 1.4500v
OCZ 4GB 1066 Reaper @ 1066 5-5-5-15 (w/ tight alphas) 2.20v
BFG 9800GTX @ 792/1944/2304
We are experiencing a weird problem. The system is Prime stable (all 4 cores & memory). We can run 3DMark and play games all day long. The system can be rebooted over and over, without any issues. However, once the unit is powered down (turned off), it will not boot back up successfully. It will attempt to boot like 3 times (never getting through POST), then it will go back to stock settings and boot. When you go into BIOS, you get the message saying the system didn't boot due to overclocks or voltages... however, you can apply your overclock settings and everything will be fine, until the system is Cold Booted again?! It is very annoying, especially since he turns his system off when he is not using it. Has anyone else experienced this "Cold Boot" issue or have any ideas and/or suggestions? Perhaps it's just a simple fix, like raising a voltage up a bit (I have tried CPU voltage, with no luck)...
-Thanks
NOTE - Only the VCore and VDimm have been raised, all other voltages are still on Auto...
