Originally Posted by
Fritz_the_germ
Hi folks!
I got my new G.Skills 2*2 Gig PC-9600 a few hours ago. They ran one hour trough memtset 2.11, test 5#, passed 33 loops without any errors.
Each time I call up to my vista 64 partition, I get freeze. On vista runs memset4, that forces the 16,383 tREFs.
The W 7 partition runs pretty good without memset. I have 3120T tREFs though.
Here are my bios settings:
Ai Overclock Tuner [Manual]
OC from CPU Level Up [Auto]
CPU Ratio Control [Manual]
Ratio CMOS Setting: [9]
FSB Frequency [450]
FSB Strap to North Bridge [400]
PCIE Frequency [100]
RAM
DRAM Settings [Manual]
DRAM Frequency [1,200MHz]
DRAM Command Rate [2T]
DRAM Timing Control [Manual]
DRAM CMD Skew on Channel A [Auto]
DRAM CMD Skew on Channel B [Auto]
DRAM Clock Skew on Channel A [advanced 100ps]
DRAM Clock Skew on Channel B [advanced 100ps]
CAS# Latency [5]
RAS# to CAS Delay [5]
RAS# Precharge [5]
RAS# Active Time [15]
RAS# to Ras# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
Read to Write Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
Write to Read Delay (D) [Auto]
Read to Read Delay (S) [Auto]
Read to Read Delay (D) [Auto]
Write to Write Delay(S) [Auto]
Write to Write Delay (D) [Auto]
DRAM Static Read Control [Enabled]
Ai Clock Twister [moderate]
Transaction Booster [Manual]
Common Performance-Level [6]
Pull-In CHA PH1 [deaktiviert]
Pull-In CHA PH2 [deaktiviert]
Pull-In CHA PH3 [deaktiviert]
Pull-In CHB PH1 [deaktiviert]
Pull-In CHB PH2 [deaktiviert]
Pull-In CHB PH3 [deaktiviert]
Voltage Settings
CPU Voltage [1,30625V]
CPU PLL Voltage [1,54V]
North Bridge Voltage [1,33V=1,36V real]
DRAM Voltage [1.96V=2,04V real]
FSB Termination Voltage [1,24V=1,16Vreal]
South Bridge Voltage [1,05V]
Loadline Calibration [Enabled]
CPU GTL Reference [0,63x]
North Bridge GTL Reference [0.67x]
DDR2 Channel A REF Voltage [Auto]
DDR2 Channel B REF Voltage [Auto]
DDR2 Controller REF Voltage [Auto]
SB 1.5V Voltage [Auto]
CPU Clock Skew [Delay 100ps]
NB Clock Skew [normal]
Is my vDIMM correct?
The tag on the sticks says "stock voltage 2.1v".
Alien Grey told me a few posts before that he was running them on 1,200 Mhz with ~1.8 volts.
Should I set "Auto" on DRAM Skew on Channel A or B instead of 100 ps because Everest tells me 10T Clock Fine Delay on all 4 (?) Dimms even when I have just 2 sticks?
The lower the number of the Clock fine delay timings the better runs my system, doesnīt is?:shrug:
