Yea, but just a small box since it's Dino!:rofl:..J/K
lol 4 drives are much faster than 6
i cant believe a raid controller can choke that quick hahahah......oh well
Care to share some figures Dino?
Odd number of drives often results in better performance, did you try using 5 drives?
I finally got around to updating my pcmv results, my pb now labeled properly. Surprised to still be in 4th. Good luck dino!
yes your result and array is a bad mofo! dino looks to be charging though...
and where is mike? i expected a sandbag by now :)
"stock" run with 980x. 4.1 ghz
http://www.futuremark.com/community/...pcmarkvantage/
The ssd is NDA :p:
Is this the lowest cpu OC on the whole Hall of fame? :rofl:
Not bad Nizzen,
NDA as in you won't tell :)
Which controller?
I'm close to cancelling my order on the C300 64GB drives, I'll be doing some PCMV tests using 3-4 SF drives this weekend, lets see how that turns out.
very nice drive performance
Nice, nizzen. good run! lemme guess..Intel?
oh..oh! pcie drive?
Good job and congrats to both mssrs Dinos and Nizzen! :clap::clap::clap:
Very nice scores guys - #3/35076 and #9/26959 respectively. :eek:
http://service.futuremark.com/search...esolution=-100
Excellent work guys! :up:
Mr Dinos - Toping Corsair Labs (Mr Planet's most excellent ~5.8ghz/ln2) is a tough act!
What was your cpu clock if I may ask? cooling?
i think that was with about 5.4Hhz CPU...something like that
that was just a warmup(hi jody)...more to come :D:up:
Wow! excellent work - I assume ln2?
This benchmark is a lot more about drive performance anyways. That's what its all about..............
i do have something else im working on which might interest some of you......will show it off soon :D
With a 166 BLCK (22*166=3.6GHz), RAM at 1333, and PCIe at 103, I was able to hit 24453 PCMarks -- enough to be at the bottom of the first page of the ORB.
Any suggestions on how to improve my score would be very much appreciated! I've read through the threads here on XS; most of the info seems related to OCing -- with my current cooling, there's probably not much more I can do on that front for the moment.
@ Mr AceNZ -
the futuremark website has some quirks - log out and log back in
like dinos said - other than oc (obvious) - storage system performance in pcmv is the other huge player
deleted
Working now; 24790 PCMarks:
http://service.futuremark.com/compare?pcmv=352220
Are there no OS/registry-level tweaks? Services that should be disabled? Settings on the graphics card?
I've seen multi-page-long lists of tweaks for 3DMarks; is there nothing equivalent for PCMV other than "OC and a fast storage system"?
wish i had a more powerful SS myself. still wondering about your drive though...
Grats Dinos! I can probably get ~5ghz stable with water, already that's hanging out at 90c.
The 1880 doesn't seem like it's going to be life changing so I guess I'm done. Will be fun watching you guys go at it though. Someone catch steve and make him squirm at least!
http://service.futuremark.com/compare?pcmv=352346
28495 PCMarks and only 4.2ghz :D
congratulations! that is impressive!
dinos which controller u using for your 5x ssds?
