No this IS the white acetal range, I didn't beat him to the punch at all. I bought one the day they became available.
I asked Eddy about custom engraving a while back, unfortunately he replied that they don't do that, and anyway it would not show up well in white acetal. He's right about that, too bad nonetheless.
Thanks ala_GK!
Thanks as always Wezly, glad you like it. :)
Thundering typhoons
Thanks to Charles for THIS guide from a while back on staggering solder joints. :up:
Tip: When you're doing fans, you can attach them to any old triple grill to work on sleeving, soldering extensions, crimping, cutting wires to length, etc. It's the same as attaching them to a rad, but less cumbersome, and it keeps things neat.
http://farm5.static.flickr.com/4041/...a82b26f8_b.jpg
<3 <3 the little cable clips on these fans.
http://farm3.static.flickr.com/2733/...96d0f14b_b.jpg
http://farm3.static.flickr.com/2774/...44c287bd_b.jpg
http://farm3.static.flickr.com/2760/...7c58cdd6_b.jpg
http://farm3.static.flickr.com/2735/...e96a7d3b_b.jpg
Next up, installing them. Thanks for looking!
