i hit 500fsb still testing
my e6400 hit 3.5 i'm sure can go even higher temps 46 idle
memory @1000mhz 5-5-5-15
16 seconds in superpi 1m
sweet board
DDR3 is the only difference. Here are the differences between all the P35-boards (Dutch). The P35T-boards are not in it, but the only differences with the non-T versions are the DDR3-slots instead of DDR2-slots.
I think the DS3P will be a little better in overclocking, because it has better cooling.
Since this is an "bios/info" thread I will post my findings here. I read a review at legionhardware that the xp-120 fitted with the crazy cool stuff. It does after u remove the backplate and twist the crazy cool heatpipe to clear the heatsink:http://img504.imageshack.us/img504/7...1279dh5.th.jpg
2.45Vdimm is a lot, definately for 24/7.
Here is what i use for 24/7 for my FSB.
http://i18.photobucket.com/albums/b1...isc/515MHz.jpg
This is 4 sticks of ram too. I quite enjoy this motherboard.
Two new reviews of the P35-DS3R:
http://www.legitreviews.com/article/513/1/
http://www.bit-tech.net/hardware/200..._ga-p35-ds3r/1
Lowfat....why not use a 7x multi?...your SuperPi score would go way up.
I just recently got P35 DQ6 and Ballistix Tracer 8500. But having alot troubles with the memory.
BIOS F3: Default settings 800 2:3 5-5-5-18 1.8 volt
BIOS F4: Default settings 1066 1:2 5-7-7-24 2.2 volt
I can't run Memtest86+ v1.70, Memtest 3.2, Orthos Blendtest without my computer hangs up.
With F3 BIOS at default settings, I can run all the tests without problem, but when set manually to 1:2 to run it at 1066 Mhz 2.2-2.40 volt and the freezing came back.
Can stresstest the CPU, even with OC to 3.2 Ghz without any problem and it's the Tracer I having alot problem with.
Thought I got faulty modules, but with BIOS F3: Default settings 800 2:3 5-5-5-18 1.8 volt and 4 Pass without any errors reported. It doesn't lokes like it's faulty modules I got and I got no idea what's wrong here.
Everything in BIOS is set to default settings, all Eist etc is disabled and trying with both Auto/manual set the RAM settings too find the problem with all the freezings.
With Everest BETA 4.0.0 it reports:
Northbridge: 1.25 volt
Southbridge: 1.05 volt
Aren't this too low?
Anyone knows if the Tuniq fits on the mobo? (The DS4)
P35 DQ6 owners on here are saying that the F4 bios is crap compared to F3 in mem scores, how much worse off is it ? and anyone know whats improved in F4 over F3 according to Gigabyte. Thanx.
Why cant I install the intel storage matrix driver? It says my system is not up to spec. When I change the bios options from IDE mode to AHCI or Raid mode, I get blue screen on boot up. Catch 22?
one noob question
is posible tu insert ICH9R Driver in windows xp? without floppy of curse.
thanks
New Realtek 8111B LAN driver, June 4th 2007:
http://www.realtek.com.tw/downloads/...&GetDown=false
