Originally Posted by
skuldarin
i just wanted to hit 2000 because it's been done and from the sounds of it, rather easily.
if LinX is just THAT difficult to pass then i'm just not going to worry about it and go by the other programs (Prime, PI, memtest) cause they all pass without any issue all the time. and like Nub says, LinX does require me to up vcore quite a bit over when i would deme stable through other programs. i only need about 1.43v vcore for it to pass everything else at 4.5ghz where as LinX wants me to put it to 1.47 which just sky rockets temps.
@ 4.5ghz / 1866mhz CL7, it passes Prime95 previously tested upto 11 hours and no hickups, it passes Pi multi on 32m repeatidly with no issue and it passes memtest easily enough aswell all without BSOD at the following:
vcore - 1.44v
vtt - 1.3125v
dram - 1.7v
IOH - 1.23v
PICE - 1.53v
uncore - 2800
link - 7444mhz
ratio - 29x155
cpu - 4.510ghz
mem - 1866mhz @ 7-9-7-24-72-2T
average temps - mid 70's
peak temps - 84*c on core 1, 82 on core 5, 79 on the rest
EDIT: not to mention the only error i get from anything at all is with World of Warcraft. it does get a critical error on a very RARE basis but other than that i don't have any issues.
