NO DATA CORRUPTION on 100MHz
I can safely confirm there there is no sort of data corruption when PCI-E is set to 100 MHz.
Last 1 week i have misused and abused my hard disk on live system (I have a clone disk).
2008 Server Enterprise x64
X38-DQ6
Q6600
Samsung 500GB SATA-II
AHCI
I had countless BSODs, reboots, crashes, system freezes playing with OC settings, benching, stress testing, etc. I intentionally did not even do a single chkdsk. I had torture tests running on my disk for hours while doing PGP file shredding, winzips, md5sums simultaneously. Yes the hard disk sounded as if it was going to explode as it was madly seeking!
Today I booted into stock settings and did md5 comparisons. All files matched.
Voltages I mostly used was vcore 1.35v, ddr +0.25, gMCH +0.05.
So I guess it is safe to use 100MHz PCI-E and not worry sinister corruption issues if the system is CPU/Memory/GPU stable.
Originally Posted by
ubiquityman
I have personally experienced this problem, not with SATA but with SCSI. I overclocked the PCI bus, and everything ran stable for a few days, but after some extended period of time, my system became noticeably unstable. I had previously done some burn-in testing at the overclocked configuration, but apparently I didn't do it long enough. In the end, I figured out the SCSI adapter/drives were slowly being corrupted. I'd get a bad bit every few hours. over time, this accumulated in files/data.
In the end, I backed down the PCI bus, reformatted and reinstalled the OS, then everything was fine.
