Would any of you guys buy the Maximus Formula again if you fried one?
I would definately.
Can people who reach 3.8+ with their Q6600 please post their BIOS settings? I cannot make mine stable above 3.780Mhz, although my cooling, mem, etc should handle more. I do believe the CPU can too.
yeah i did flash to 0701, but the temps were really scaring me so I flashed back to 0505
I also got rid of the crappy OCZ golds and swapped in a new set of Corsair Dominator PC8500, but with my current 9x400 clock speed, and ram set to dd2-1066 my divider is 3:4 was there a problem with that divider ratio or should i be ok?
stress testing as we speak
Exact same thing here. Stock Idle 47C ???? And 47C load?! Weird.
No way...not with a PA160...
I dunno man either the figures are bogus or this board rons 20C hotter than anything I've put the G0 in.
What's weird is the first BIOS the temps were way too low...17C idle
CyberDruid, are you on the 0701 bios? someone mentioned that there's a temp bug in that bios, could be that?
stress testing with prime right now, core temp says my cores are 86-92* O.O!!! VID = 1.225v is that undervolted?
0701 here and my temps seem a little higher (4-5c) but i also moved my puter and didnt' realize it's right next to the heater. i think that is why it's up in temps.
My CPU should be idling at about 24-28C, right now its at 40C, I've tested these bug with 0505-0701 and they all have the same bug i guess.
I'm not to worried about the reported temps. As long as it stays below 75* full load. I've changed my auto voltages to what Probe was showing. Believe it or not my reported CPU temps under load went down about 3* and I haven't touched vCore. I only have cpuPLL on auto now. Those settings I posted I didn't test in Prime. Was just trying to successfully bench. It errored in P95 in seconds. :(. So I've done some more tweaking. Changing timings had almost zero effect. Changing clock twister to Moderate had some effect. Was 2 hr. prime stable. Last thing I've tried was DD2 Ref Voltages. I've not seen anyone mention changing those and I thought I was give it a try. I've changed all 3 to +10mv and I also noticed that under full load my VDIMM was fluxing by .02v. So I upped vDIMM by .02v and running another P95 blend test. I'll report back later with more info.
And if this board where to fry next week and I had to purchase it again I would say no. I would probably get the upcoming QuadGT X38/X48 board. I've always like Abit. This is my first Asus board in 10 years. Last Asus board was for Socket 7 233MMX. :)
hmm the 0701 damn buggy
was running 500x8 with rams at 1:1 4-4-4-8
when i flashed it to 0701 it worked flawlessly
today was doing some benching overclocking.. suddenly got det ram error
it didnt even allow my board to boot past 450fsb
reverted it back to 0602.. working fine.. but i still prefer 0505 as the rams sandra bandwidth was better..
anyone running 3:4 divider?
C2D X6800 B2 L628A937
http://forum.lowyat.net/index.php?ac...post&id=311883
http://forum.lowyat.net/index.php?ac...post&id=311882
http://forum.lowyat.net/index.php?ac...post&id=311881
E6850 G0 L720A948
http://forum.lowyat.net/index.php?ac...post&id=314458
http://forum.lowyat.net/index.php?ac...post&id=314459
http://forum.lowyat.net/index.php?ac...post&id=314455
http://forum.lowyat.net/index.php?ac...post&id=314454
http://forum.lowyat.net/index.php?ac...post&id=316947
im coming from a P5K premium and i definitely dont regret it. The P5K Premium was a pain in the butt...
here's my Small FFTs running on prime95 64bit version 25.5 so far. I'm not having any trouble other than a high NB temp. my volts aren't fluxing at all.
I've finally built up my machine now, and I'm surprised (initially) at the vast stability improvements over the i975X, I haven't tweaked things much but just installed XP to test a few options with Prime.
Kup: is your modded 0701 SLIC BIOS meant to report a bad boot block error on EZ FLASH 2? I avoided flashing with it. The SLIC modded 0903 BIOS for my P5W64-WS didn't report any bad boot block errors during its flash, so that's why I'm asking.
P.
Hi notice in your sig;
How do I flash the BIOS without a floppy, answer USB.
Please would you give details how I can do that with this Mobo as I can't seem to find a boot from USB option, also I want to use the USB to put my Raid drivers on XP using F6 again I haven't a clue been trying for 2 full days now.
Thanks..
