jor3lBR,yep very true.ill give it a go here a little later.ill keep you posted.thanks again
Anandtech just reviewed the UD3P and found out what we have already known for months. That its great! They gave it their Gold award thingie :up:
Since they liked it so much I guess we won't hold it against them that they didn't review it in October. ;)
http://www.anandtech.com/mb/showdoc.aspx?i=3508
Aren't Anandtech voltages a bit too high, especially compared to the ones posted here?
btw Are my voltages and temps posted here safe for 24/7 on Duo 45nm?
Anyone help me tweek these? It runs stable but I leave it in suspend (S3) and when I restarted today it went into a boot cycle.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto <===
CPU Clock Ratio .......................: 8 <===
Fine CPU Clock Ratio...................: +0.5 <===
CPU Frequency .........................: 4.03 GHz (475X8.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 475
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled] <===
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 800mV <===
PCI Express Clock Drive................: 900mV <===
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: [Std]
Extreme Memory Profile (X.M.P.)........: [Disabled]
(G)MCH Frequency Latch.................: [400MHz] <===
System Memory Multiplier ..............: 2.0B <===
Memory Frequency (Mhz) ................: 950
DRAM Timing Selectable ................: [Manual] <===
Standard Timing Control
CAS Latency Time.......................: 5 <===
tRCD ..................................: 5 <===
tRP'...................................: 5 <===
tRAS...................................: 15 <===
Advanced Timing Control
tRRD................................(4): Auto <===
tWTR................................(4): Auto <===
tWR.................................(8): Auto <===
tRFC...............................(68): Auto <===
tRTP................................(4): Auto <===
Command Rate (CMD) .................(0): Auto <===
Driving Strength Profiles
Driving Strength ......................: Auto <===
Channel A
Static tRead Value..................(6): [10]
tRD Phase0 Adjustment..................: [AUTO]
tRD Phase1 Adjustment..................: [AUTO]
tRD Phase2 Adjustment .................: [AUTO]
tRD Phase3 Adjustment..................: [AUTO]
Trd2rd(Different Rank).................: [AUTO]
Twr2wr(Different Rank).................: [AUTO]
Twr2rd(Different Rank).................: [AUTO]
Trd2wr(Same/Diff Rank).................: [AUTO]
Dimm1 Clock Skew Control...............: [AUTO]
Dimm2 Clock Skew Control...............: [AUTO]
DDR Write Training.....................: [AUTO]
Channel B
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enable]
CPU Vcore..............................: 1.250v <===
CPU Termination........................: 1.30 <===
CPU PLL................................: 1.57 <===
CPU Reference..........................: 0.863 <===
MCH/ICH
MCH Core...............................: 1.36V <===.
MCH Reference..........................: 0.863 <===
MCH/DRAM Ref...........................: [AUTO] <===
ICH I/O................................: [Auto] <===
ICH Core...............................: [Auto] <===
DRAM
DRAM Voltage...........................: 2.1v <===
DRAM Termination ......................: 0.96 <===
Channel A Reference....................: 0.96 <===
Channel B Reference ...................: 0.96 <===
CPU = Q9550 rev C1
RAM = G.Skill PC2-8500C5 2x2048MB
It ran fine and a quick prime was stable. Have turned it on and off a few times. Last used it put it into suspend (S3) I think, default, but when I started it up it went into a boot cycle!
Any ideas what I need to tweek guys?
Cheers
Anandtech's voltage settings (at least some of those shots) remind me of when I was using the AUTO settings to try and get to 600 FSB for playing around. They also mentioned something about getting out the Peltier cooler to get to 5Ghz, so some of those higher settings may also reflect using that Coolit Freezone thing. The 5Ghz shot has a CPU voltage of 1.52v and 1.55v so I would imagine they weren't doing that on air :)
The gallery images show various voltages and settings and some are more like what you see here.
Touche
Your voltages look fine to me.
Hi, i need some advices to reach over 500 FSB, now i`m stable at 500x8 but my intentions are reach 530x8 or the max as i can. But my first attempts were frustrating. With 510x8 i got my CPU stable ran ORTHOS 1h small FTT and no errors. But blend test gave error before 1min, so there is some wrong with my settings about the memory. And please take a look and let me know what can i do.
http://i11.photobucket.com/albums/a1..._orthos_3h.jpg
Bios F7 settings
Thanks!Code:****** Gigabyte EP45 UD3P Bios F7 ******
E8500 500 X 8 4000MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.0GHz...........................[ 500 x 8 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 510 ]
PCI Express Frequency (Mhz).....................[ 102 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 400MHz ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 1066...........................[ 1000 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ] Tried auto
tRCD............................................[ 5 ] Tried auto
tRP.............................................[ 5 ] Tried auto
tRAS............................................[ 18 ] Tried auto
******Advanced Timing Control******
tRRD............................................[ 4 ] [Auto]
tWTR............................................[ 4 ] [Auto]
tWR.............................................[ 8 ] [Auto]
tRFC............................................[ 54 ] [Auto] Tried 54 ~ 72
tRTP............................................[ 4 ] [Auto]
Command Rate (cmd)..............................[ 2T ]
******Channel A Timing Settings******
Static tRead Value [ 11 ] ................[ 9 ] Tried 9,10,11
tRD Phase0 Adjustment [ 1 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Disabled ]
CPU Vcore [ 1.25000 ]...................[ 1.36250 ] Tried ~ 1.37500
CPU Termination [ 1.20 ]...................[ 1.28 ]
CPU PLL [ 1.50 ]...................[ 1.5000 ]
CPU Reference [ 0.760 ]...................[Normal ]
MCH Core [1.100 ]...................[ 1.400 ] Tried 1.420
MCH Reference [0.760 ]...................[ 0.750 ] ET6 show 0.720 Tried 0.700
MCH/DRAM Refernce [0.900 ]...................[ Normal ]
ICH I/O [1.500 ]...................[ 1.500 ]
ICH Core [1.100 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ 2.060 ] Tried ~ 2.100
DRAM Termination [0.900 ]...................[ Normal ]
Channel A Ref [0.900 ]...................[ Normal ]
Channel B Ref [0.900 ]...................[ Normal ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Enabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Enabled ]
*******Integraed Peripherals******
Legacy USB Storage Detect.......................[ Disabled ]
Try this and then go for lower volts/timings if it's stable:
E8500 510 X 8 4080MHz
CPU Frequency 4.0GHz...........................[ 510 x 8 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
Static tRead Value [ 11 ] ................[ Auto ] Try 12 also
CPU Vcore [ 1.25000 ]...................[ 1.41250 ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU Reference [ 0.760 ]...................[0.823 ]
MCH Reference [0.760 ]...................[ 0.783 ] Try 0.783-0.823 + step or two up
MCH/DRAM Refernce [0.900 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ 2.200 ]
DRAM Termination [0.900 ]...................[1.100 ]
Channel A Ref [0.900 ]...................[ 1.100 ]
Channel B Ref [0.900 ]...................[ 1.100 ]
Why does everybody run there memory 1:1 here ? does the 333, 266 strap work on this board ? maybe tough with a quad, but not with dual core, 1:1 totally stinks, it kills your memory bandwidth.
for me its mainly cause i was having trouble running 5:6 but i got it going but noticed that the clocks i was able to achieve with 5:6,my everest scores were not that much higher than when i ran 1:1.and since i have recently bought a second set of g.skill pc-8800's i figured using 8 gigs at these clocks would be just as good(with lower v dimm).so far it performs very well at 510x8.5 w/8gigs.but now ive noticed that im able to run this clock with the 8gigs at the same volts as with 2gigs,so im might just try 2gigs again running 5:6 and see how far i can push this 9650 now that im getting the hang of it.BY THE WAY-i got a brand new maximus II for my replacement from asus(finally).only took four boards from asus+the original that i bought so i guess 5 is the new lucky number 3.ill be selling it if anyone is interested.not looking to make all my money back,just want to wipe my hands of this ordeal,so it will be cheap.pm me if you interested
Its likely MCH ref or even MCH core that is holding you back. Run memtest and loop test #7. If you see tons of errors, raise the MCH core or even raise PL(static tRead) or your mem timings. If you get 1-2 errors in each pass then change the mch reff.
I just got my Q9650:up:, So far I need different MCH ref settings and likely cpu reff settings for sure. I dont have much time tonight but will be looking back through this thread to try some settings.
Hopefully they will fix this issue with the straps, and yes memory bandwidth does matter in everyday use. Im curious what kind of temps you guys are getting on the northbridge ? does this board run hot on nb ?
Any benchmarks?
http://www.xbitlabs.com/articles/mem...ory-guide.html
I am using that exact template. Ony things different are 490fsb instead of 489 and Memory is 400 2.00D 1:1 for 980mhz for the 8gb. Bandwith is good enough for me. Temps are good under load since i replaced the TRUE with a water loop. F7 bios. This is my 24/7 setup. It gets me 22000 on 3dmark06 and 23000 on Vantage.
http://img8.imageshack.us/img8/6098/capturemd7.jpg
nugzo,very nice .thanks for the info
Hey I just poped in my Q9650, used Jor3lBR's template and on air I go easily. Clocks just as good if not better than my E8400 E0, just hotter, haven't even let the AS5 settle yet.
1st testing done, booted right up. On to stability now.
1M Spi
http://i115.photobucket.com/albums/n...ter/10719s.jpg
32M Spi
http://i115.photobucket.com/albums/n.../11m42797s.jpg
I'm sure I can lower the voltage or clock higher this is 1st test!!:up:
Edit: it failed after 30min of OCCT, so on to tweaking, lol.
What's the scoop on removing the "Gigabyte" and "Ultra Durable" covers from the MCH and PWM covers?? As I know that my northbridge is running much hotter than ET6 reports. I thought I saw a couple degree's cooler?
Nice work SpeedEuphoria
Good luck.
Everest and ET6 both report NB temps, but they are different :confused:
Also whats the max safe NB temp?
hi, first post on XS . couldn't find the "welcome to the forum " post so i guess just dive in ?
ive been following these threads for a while , right after i bought a Q9650 that is.
guess what happened next ? I ended up building another pc instead of upgrading the one i already have, lol.
need a little advice on my setup, btw thanks for the bios templates guys !!!
Q9650 L826A965
9 x 423 for 3.8 , max temp with IBT 1.9 = 61c
cpu @ 1.25625v bios / 1.23 cpuz/everest
ive booted to 4.5 but it gets too hot with just prime , as soon as i see it hit 65c i stop it. cooling = TRUE (not lapped) antec 120's on high push/pull , case HAF 932. fix??? 120 x 38 fans on cooler or do you think water would get me there ? im thinking this kit : Swiftech H20-220 Apex Ultima
p.s. by there im thinking 24/7
thanks in advance .
Hey everyone, longgggg time lurker here, I never post! Just wanted to start by saying thanks to Jor3lBR and nugzo, your BIOS settings have helped me alot.
The Q9650 and UD3P truly were made for each other. I'm at 4.25GHz stable, but I'm pretty sure I could run this baby at 4.4 or 4.5 24/7 stable if I had better watercooling. I just have a crappy rad (MCR220). I should've gotten the Thermochill or Faser '3 fan' rad :( Oh well.
No success running 509+ FSB at a lower multi :( Best I got at a lower multi was 508x8.5, but I think I like 473x9 better. Let's me run my Dominator's at SIGNIFICANTLY better timings.
I'm Prime95, OCCT, and Orthos Stable...but I fail IBT instantly, IBT gets my CPU wayyyy too hot (75C+). I doubt anything I'll ever run will get my CPU that hot so I'm ok with failing that.
Also, thanks to EVERYONE in this thread because it wasn't just nugzo and Jor3lBR that helped me, it was comments posted by many different people in this thread and in nugzo's other UD3 thread.
Good luck to everyone and I hope you can acheive a good stable clock like I have, it's a good feeling! :D
Screenshot:
http://img26.imageshack.us/img26/6871/4250ghzaafw9.jpg
My Baby:
http://img264.imageshack.us/img264/2544/mybabybs7.jpg
Here are my BIOS settings:
CPU Clock Ratio.................................[ 9 ]
CPU Host Frequency (Mhz)........................[ 473 ]
C.I.A 2.........................................[ Disabled ]
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
Memory Frequency 1066...........................[ 946 ]
tRP.............................................[ 4 ]
tRAS............................................[ 12 ]
tRRD............................................[ 3 ]
tWR.............................................[ 6 ]
tRFC............................................[ 55 ]
Static tRead Value [ 11 ] ...............[ 9 ]
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.25000 ]...................[ 1.4000 ]
CPU Termination [ 1.20 ]...................[ 1.42 ]
CPU PLL [ 1.50 ]...................[ 1.59 ]
CPU Reference [ 0.760 ]...................[ 0.939 ]
MCH Core [1.100 ]...................[ 1.42 ]
MCH Reference [0.760 ]...................[ 0.939 ]
MCH/DRAM Reference [0.900 ]..................[ 1.11 ]
ICH I/O [1.500 ]...................[ 1.57 ]
ICH Core [1.100 ]...................[ 1.2 ]
DRAM Voltage [1.800 ]...................[ 2.2 ]
DRAM Termination [0.900 ]...................[ Auto ]
Channel A Ref [0.900 ]...................[ Auto ]
Channel B Ref [0.900 ]...................[ Auto ]
Virtualization Technology.......................[ Disabled ]
Legacy USB Storage Detect.......................[ Enabled ]
I Just got my board today its rev 1.1 with F6 Bios, I have Q6600, 8GB Gskill DDR2-1000 should i update bios to F7?
Also anyone with Q6600 and this board post bios setting they are using im looking through pages atm so if someone has it already and can post fast i would appreciate that :)
Hey
Anyone had a chance to look over my settings on page 72 #1799 ?
Its the big post as I dont know how to use frames!
Cheers guys, I just need a little help :)
hmm right now im trying 3.6ghz on Q6600 i know i can do it just trying different voltage, now is Load-Line Calibration bad to have on enabled?
