634fsb and ddr3 ram at 2113mhz on rampage extreme with e8600 (q822a435)
i thought i'd see what ramspeed and fsb i could do the everest memory benchmark at , this is using the 400 strap and loose memory subtimings and tref on ram set at 100 and running and on performance level 10 so not mind blowing numbers
Volts used
cpu 1. 392 (1.4 set in bios llc enabled)
northbridge 1.73
vtt 1.40
ram 2.04
cpu pll 1.51 set in bios
upped southbridge voltages to 1.6 (for the 1.5 one) and 1.1 (for the 1.05 one)
http://gbwatches.com/pics/634fsb.jpg
563fsb rampage extreme e8600 samsung hco 4gb kit skewing
ok sold off my rampage 2 extreme
e8600 only
here is the super stable setup for skewing at 563fsb 1800mhz 8-8-8-24 1t 2x2gb samsung hco team xtreem pc3-16000
Code:
AI OVERCLOCK TUNER =========================MANUAL
OC FROM CPU LEVEL ==========================AUTO
OC FROM MEMORY LEVEL UP ====================AUTO
FSB FREQUENCY ==============================564
CPU RATIO SETTING ==========================7-8
CPU CLOCK SKEW =============================Delay 200
NB CLOCK SKEW ==============================Normal
FSB STRAP TO NORTH BRIDGE ==================333
PCIE FREQUENCY =============================100
DRAM FREQUENCY =============================1800
DRAM COMAND RATE ===========================1N
DRAM TIMING CONTROL ========================MANUAL
CAS LATENCY ================================8
RAS TO CAS DELAY ===========================8
RAS PRE TIME ===============================8
RAS ACT TIME ===============================24
RAS TO RAS DELAY ===========================AUTO
REF CYCLE TIME =============================72/88
WRITE RECOVERY TIME ========================AUTO
READ TO PRE TIME ===========================AUTO
READ TO WRITE DELAY S/D ====================AUTO
WRITE TO READ DELAY S ======================AUTO
WRITE TO READ DELAY D ======================AUTO
READ TO READ DELAY S =======================AUTO
READ TO READ DELAY D =======================AUTO
WRITE TO WRITE DELAY S =====================AUTO
WRITE TO WRITE DELAY D =====================AUTO
WRITE TO PRE DELAY =========================AUTO
READ TO PRE DELAY ==========================AUTO
PRE TO PRE DELAY ===========================AUTO
ALL PRE TO ACT DELAY =======================AUTO
ALL PRE TO REF DELAY =======================AUTO
DRAM STATIC READ CONTROL ===================AUTO
DRAM DYNAMIC WRITE CONTROL =================AUTO
DRAM SKEW CONTROL
DRAM CMD SKEW ON CHANNEL A = Normal
DRAM CLK SKEW ON DIMM A1 = Advance 125
DRAM CLK SKEW ON DIMM A2 = Advance 125
DRAM CTL SKEW ON DIMM A1 = Advance 25
DRAM CTL SKEW ON DIMM A2 = Advance 25
DRAM CMD SKEW ON CHANNEL B = Advance 50
DRAM CLK SKEW ON DIMM B1 = Advance 100
DRAM CLK SKEW ON DIMM B2 = Advance 100
DRAM CTL SKEW ON DIMM B1 = Advance 50
DRAM CTL SKEW ON DIMM B2 = Advance 50
DRAM Read/Dynamic Write = Disabled
AI CLOCK TWISTER ===========================MODERATE
AI TRANSACTION BOOSTER =====================MANUAL
PERFORMANCE LEVEL ==========================09
PULL-IN OF CHA PH1 =========================DISABLED
PULL-IN OF CHA PH2 =========================DISABLED
PULL-IN OF CHA PH3 =========================DISABLED
PULL-IN OF CHA PH4 =========================DISABLED
PULL-IN OF CHA PH5 =========================DISABLED
PULL-IN OF CHB PH1 =========================DISABLED
PULL-IN OF CHB PH2 =========================DISABLED
PULL-IN OF CHB PH3 =========================DISABLED
PULL-IN OF CHB PH4 =========================DISABLED
PULL-IN OF CHB PH5 =========================DISABLED
EPU II PHASE CONTROL =======================AUTO
CPU VOLTAGE ================================
LOAD-LINE CALIBRATION ======================DISABLED
CPU PLL VOLTAGE ===========================1.51
FSB TERMINATION VOLTAGE ===================1.29
CPU GTLVREF 0 ==============================+40
CPU GTLVREF 1 ==============================AUTO
CPU GTLVREF 2 ==============================AUTO
CPU GTLVREF 3 ==============================AUTO
NB GTLVREF =================================AUTO
NORTH BRIDGE VOLTAGE =======================1.59
DRAM VOLTAGE ===============================1.9
NB DDRVREF =================================+12.5
DDR3 CHANNEL A VREF ========================+25
DDR3 CHANNEL B VREF ========================+25
SOUTH BRIDGE 1.5 VOLTAGE ===================1.51
SOUTH BRIDGE 1.05 VOLTAGE ==================1.06
CPU SPREAD SPRECTRUM =======================DISABLED
PCIE SPREAD SPECTRUM =======================DISABLED
[/QUOTE]
ram skewing
for 500fsb 1600mhz Cl7-7-7-20-1t
use same skewing except no nbdram /dram A/B = Auto, fsb termination 1.12
dram at 1.67 ....nb = 1.25v
400fsb is the same.
vtt for 563 fsb termination issue .....1.19 for IBT stable
but will fail on my test 3 for orthos .. set blend.. then custom min fft 4096... only fsb termination at 1.29 will pass.
theres other ways to force 1.19 to pass for both but will result in weird irregular issues with usb ports.
