Hay Gk I like your handy work with the HHD bracket, looks really good.
The Lian-Li casters look a bit like there from a skateboard :rofl:
I have been reading up on the Koolance TMS-200 board and Koolance's TMS-EB200 Expansion Board and trying to compare them to the T-Balance mcubed bigNG/miniNGs Expansion Board.
At this stage I have still not made up my mind yet as to which one I will get.
Hi Arthur, I am sorry to hear for your loss, it's a trying time.
I have been through the loss of a family member just some two months ago, keep your head up mate.
Thanks ExA for taking the time to read the testing that Vapor has done, he really has done some excellent work there.
However, I am not sure how you can say I made the HK block " sound like the block was mediocre" I in no means stated or gave the impression in any way that,
"the HK is wastly inferior to the XT".
I do admire your passion for the Heatkiller block. I do admit I was not happy to read that HK had lost the crown,
but are really looking forward to Watercool's new version of the HK when that finally happens.
At this point there is no retailer selling the HK in Australia(that I can find, PCCG did, but don't now) and at this point I will buy the HK block from overseas.
I did state that "thou HK may not be the coolest WC block, temps wise."
The HK is now the second best block for cooling CPUs, first place now goes to Swiftech Apogee XT"
This statement is correct, the HK block is second compared to the XT, as found in Vapor's review.
As to your statement "The sub 1C difference is worth it in my eyes when you consider that the HK is much less restrictive than the XT
Well this is also ture, to a point. In Vapor's graphs the HK is 0.19 GPM more restrictive than the XT. To me that is only a tad less restrictive.
As for the "silicone mod" I to agree it does help the Hk drop about 1C.
It also helps the XT in the same manner, (also found out by Vapor in the 10-20-2009 Swiftech Apogee XT test report) so the silicone mod works just as well for both blocks.
So as I see it the XT is the best block by 1C, but to me it really just comes down to looks with the HK.
As I stated " I still feel its the best looking"
Please feel free to write a reply to what I have written, however as this is GK's work log, with respect to him, I will not be post further comments on this matter.
Looking forward to your next update GK, as for testing the HK on the 775, I also have not seen any, also have not been looking either.
