Yes, I quite enjoy it as well….lol
Actually I’m using the Evga Southbridge fan right now because my 9800GX2 interfered with the fan blades on the EnzoTech SLF-1. Please remember that I was the first to do the modification of using a waterblock on the 9800GX2 without completely removing the outer case. The issue with the mod is that to hold the two sides closed I used a zip tie which ends up being positioned over the southbridge on the 780i. Even now the zip tie pushes down on one side of the EVGA fan making it uneven; this is one of the issues still holding this builds completion back.
I would actually prefer a waterblock solution for the Southbridge as I have a separate loop just for motherboard cooling. This was one of my primary reasons for wanting the EVGA 780i FTW or the 790i FTW (watercooled versions). At this time I’m not aware of any southbridge waterblocks that clear the 9800GX2. If you’re aware of any, let me know!
I would definitely recommend the EnzoTech SLF-1 over the Evercool VC-RE for having better build quality and being more aesthetically pleasing. I can’t comment on performance as I haven’t done any testing with them but I would expect that the EnzoTech SLF-1would offer superior performance.
I’m going to make the following very clear so others will see this as well:
There are NO known issues with using a 9800GX2 with an EK Water block and using the EnzoTech SLF-1, EVGA 680i Southbridge Fan, or Evercool VC-RE on the 780i motherboards. Unless, a modification is done to the 9800GX2 that makes it stick out farther than the original outer case does. ex. My 9800GX2 Mod
Wow, it sounds like you got a pretty slick deal. I remember back when I was first starting out with a D40x; I purchased the DVD’s as well and studied them closely! Lol! Good choice going with both VR lenses; like I always tell customers “It’s like CHEATING”! A friend and I were fooling around with my 18-200mm VR in my kitchen one night and we were able to get the shutter speed down to about a 1/5 or 1/2 of a second which amazed us of course!
I haven’t had much time to play with the D60 but I noticed right away that it was a significant improvement over the D40 and D40x….again Kudos!
The build is still in pieces and all my computer hardware which is currently on the dining room table (it’s been there since 11-07) has to be moved downstairs because the relatives will be coming over, so it may be a few days before any work can be done on this build.
The most recent pictures are posted on my flickr account as usual.
I still have a few questions:
• Does anyone have images of the thermal distribution on the bottom of a DDC pump?
• How does one achieve a flattened area around a port on a circular reservoir? (Like the Ek Reservoirs)
• Some of my koolance fittings have begun to chip; exposing the brass, is this cause for concern? Photos of this are on my flickr..
• What are the two holes positioned closer to the center on the bottom of a DDC for?
• Does Bitspowers G1/4 Thread 1/2" ID x 5/8" OD Compression Fittings fit on a D-TEK FuZion v2 or are they too wide?
