no new ratios
no new ratios
Just wrote this out to Gigabyte....
click here to email Gigabyte with these requests.Quote:
Originally Posted by Written by cool_dude to Gigabyte:
If some people here write the same thing, but with there name on the end hopefully this will get them moving, and doing the requests. :toast:
done :)Quote:
Originally Posted by cool_dude
The biggest issues I want to see fixed with the DQ6 are:
When it restarts after you change your bios settings it will completely power down before starting up again. This keeps switching my compressor on and off quickly which isn't at all healthy.
Also I'd like to be able to boot at more than +0.3vmch, all the way up to the given +0.75 would be nice.
If they could fix these two issues I'd be extremely happy.
+ 1 ! :toast:Quote:
Originally Posted by Kesnel
it would be very nice before i put my E6600 under MachII GT .... :rolleyes:
Same here. Now let's think some other changes and fixes for bios.Quote:
Originally Posted by logigamer
done :fact:Quote:
Nice :) the more people that do it the better :toast:
Yup. There any more problems that we could write to them for another bios update after they've done our requests? :)Quote:
Same here. Now let's think some other changes for bios.
yeah, please continue, as they know about this thread~;)
Firstly they must fix some bugs and issues with overclocking, like these: http://www.xtremesystems.org/forums/...d.php?t=109747
mail sent .
yes, please keep on reporting any bugs/ suggestion to improve!
Select "Boot from USB Floppy" in BIOS?Quote:
Originally Posted by BottomsUp
kenofstephen,
how'd you know that 'they' know about this thread?
clockcatcher,
i saw ur sig and saw u're using 7600GT with DS3...are you facing any problems with OC-ing?
coz I email to them about this thread, I mean.... email to the guys I know...Quote:
Originally Posted by dualshock
not the technical service zone....
what about that PIO mode when using RAID? Im planning to do a all RAID for my SATA hd drives only. The IDE channels will used by DVDRW. I dont want my dvd drive breaking because of this stupid issue that should have been fixed before the first released BIOS.
This has been FIXED with F4c!!! Woohoo! I just setup RAID tonight and it all works perfectly. UltraDMA on my 2 burners!
I haven't got that card yet, but I hope that it doesn't make any problems with OC’ing.Quote:
so now what gfx are you using?Quote:
Originally Posted by ClockCatcher
you tried fixing pcie at 105 and add +0.1v to pcie? vmch should be able to go to +0.75Quote:
is that true, it can only do cl3 with ANY ram ?Quote:
rather than making ALL ram boot at CAS3.
cause this would be kind of hard, as i don`t wanted to buy such expensive ram, that can do cl3.....
this board doesnt make ANY ram boot at cas 3.
i dont know why people say that other than cpu-z reporting the WRONG cas timing.
there isnt any evidence to support the claims that its booting at CAS3
infacti have tested with 3 different types of ram and the system doesnt boot at cas 3 until you run the FSB down below 200.
btw is there a way to change the timings in the bios on the ds3 board? I put it in last night and didn't notice that anywhere
hit ctrl F1. Also like Lestat said th is board don't do that. My G.Skill boots at cas 4 fine and CPU reports it correctly.
Originally Posted by Lestat
yeap, this is likely to be an error in bios showing the setting rather than bios making it always CL3...
CPUz, Everest and so on...
there is not so much ram that would boot @ 490fsb 1:1 with CL 3 ;)
