Originally Posted by
neo_rtr
Hi, I friend mention this page and to be honest I am overwhelmed with the information that is given by you guys.
I looked around and I see that the Rampage Bios can be used on the Asus Maximus formula, which is the board I have. My problems since day one with this M/B is what no matter what I do I can not push it above 3.8Ghz using the QX6700 (did it few times but nothing really stable for long term use)
This thread is giving my hope in terms of doing just that.
Will have to flash my Maximus to Rampage first.
In the mean time.
Following the example of EOD post nr 1605 page 65 “I was running a Q6700 at 3.8GHz at 423 FSB x 9, “
My self was not able to boot. Went few steps up for the the volts in general with no luck.
On the QX6700 bios is 13.2 I have
CPU Ratio Control : Manual 8
- Ratio CMOS Setting :
FSB Frequency : 460
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
CPU Voltage : 1,50625V
CPU PLL Voltage : 1.60V
North Bridge Voltage : 1,63V
DRAM Voltage : 2,02V
FSB Termination Voltage : 1,52v
South Bridge Voltage : 1,075v
Loadline Calibration : enable
CPU GTL Reference : auto
Can you give me a general advise on my existing setup before flashing the maximus to rampage.
Thank you
