nice result...i guess ur VID is lower than mine (1.225)
i had the similar problem a while back, initially cpu was ok, then random bsod, i had to run it at stock, any overclock over 3.2 would blue screen, adjusting gtls helped alot in booting and B/S.
scary part was when screen shows raid array members ofline in red, couldn't boot at all, i was thinking all my data will have been lost. thankfully it returned normal after many hours of reset /clear cmos.
i reinstalled xp on another hdd, in ide mode, problem went, when i set raid in bios problem returned.
i changed for another e8400, so far it boots my raid array overclocked. will see how it pans out.
I've changed MOBO from Abit IP35 to DFI X38 and it's looks a little bit better.
BIOS settings:
vcore 1.36v
NB 1.33v
VTT 1.25v
9x445
Where do i see the VID ?
With 2000 fsb you mean 4x500fsb right? I'm experiencing the same problem a you.
8x500 runs fine but 8x503 to 520 gives me BSOD's during start up or in Windows. 9x466 runs like a charm though
Is this the so-called FSB-hole kicking for me at 8x503 to 525?
For the moment i'm running my E8400 Q746A556 8x500 @ 1.26v :)
http://img175.imageshack.us/img175/1924/4ghz800hp3.jpg
Demon pls give us a prime95 small ffts test with at least 2 hours of running... If it can do it with that voltage, u have a great chip!
I guess many of us had problems with Wolfdale CPU temp and this guy says most of our Wolfdale are shipped with faulty temp sensor:
http://www.cpu3d.com/content/view/4016/16/
How true is this and if it really is faulty, is Intel going to do something about it? This sux!
Is CPU-Z reporting the right CPU voltage?
I am running 500x8 with 1.36v set in BIOS on my Abit X38, but CPU-Z reports about 1.26v, if my memory serves me.
I think my CPU can run small orthos for a few hours no problems, watercooled, I can't remember how long I left it running TBH. I am not a stress test junkie, if it play all my games etc......
I aways assumed CPU-Z was wrong :confused:
Cheers! :D
Unfortunately CPU-Z does not detect the correct Vcore in some cases. Please download V1.44.1 and that should fix it.
I've changed VTT 1.15v and it's working ok.
About my temperatures - I'm waiting for new CPU, because main have got faulty thermal sensor - I'm sure it is not 77 degrees but less - my Heatsink is not even worm.
I run the same board as you,cpu-z will show 1.36v idle and 1.344 under load while bios says 1.36v. Funny thing is that when I use 1.39 in bios, cpu-z/sg show 1.408/1.40 respectively.
I don't believe any of them and think it's time to find my volt meter to take some readings later.
I am on the 02/13/08 Beta bios btw, although I got the same readings off 12/24 like you are running.
Larry
Using the Asus AI Suite, I get temp readings of 35 at idle/53 load using the stock cooler with AS5. That sounds about right to me. Even if the sensors used by Core Temp are a bit wacky, I'm inclined to believe that the AI suite os giving me the proper readings as these are similar to those I got with my E6300 back in the day...
Unfortunately my chip doesn't show the correct temp with Core Temp nor Everest. Earlier on I thought it's a problem with the BIOS or Core Temp but looks like its a faulty thermal sensor.
