cable management is all you need;)
http://i20.photobucket.com/albums/b2...2/HPIM0593.jpg
http://i20.photobucket.com/albums/b2...2/HPIM0592.jpg
http://i20.photobucket.com/albums/b2...2/HPIM0594.jpg
http://i20.photobucket.com/albums/b2...r/HPIM0432.jpg
http://i20.photobucket.com/albums/b2...r/HPIM0467.jpg
http://i20.photobucket.com/albums/b2...HPIM0437-1.jpg
@adidassler: Nice setup! :) how's life in the middle-east? :p:
Adidassler, you should remove that cover from the NB heatsink (the one with asus written), it really messes up the airflow in there..
My latest system, I'm still waiting on another panaflo to replace the current yate loon on the video card... Other than that its complete, for now.
Very clean setup :up:. How's the video card doing with the HR-03 mounted on top? I'd imagine that it would be bending under that much weight... :shrug:
As for me, new case and watercooling is coming soon. Will be posting new rig setup within the next couple of weeks.
DearKook,
Great job man, although there are many great rigs posted recenlty I have been most impressed with yous because it's clean and utilitarian! You did a great job with both the wirring and the sound dampening material (which is not the easiest thing in the world to install)! What are you running for hardware?
Metric - Yeah that heat sink is kinda heavy but the stock heat sink bowed the card much more than the HR-03.. You can still see a very slight warping from it. Good luck with your new rig!
Roger_D25 - Thats what I was going for. :) And yeah that sound dampening stuff was a pain... I had to buy a second box of it because I couldn't get the cuts and or application of it right. As far as whats in the case..
Abit IP35 Pro + HR-05sli, Enzotech copper HS, and home made PWM HS
Intel 6420 @ 3.2 1.3v + Thermalright 120 Extreme Temps 80f Idle / 105f Load
2g Crucial Ballistix PC6400 @ 400fsb 4-4-4-12-2t
Evga 8800gts @ 600core/900mem (Still playing with those.. Can bench @ 697/1010 with slight glitches :( No crashes) + Thermalright HR-03 Plus
2 x Seagate 7200.10 320g Raid-0
Corsair hx620w
4 x Panaflo L1 Low Noise 120mm Fans
Samsung 18x Sata DVD Burner w/LS
Close but not quite --dual Opterons & Supermicro.
Correct - but wrong picture. The northbridge on the H8DCE has a 40mm fan on it like mine.
RAM heat spreaders dissipate heat. Are they effective...possibly. :shrug: But they look leagues better than normal naked RAM sticks.
http://i7.photobucket.com/albums/y26...p/IMG_0537.jpg
http://i7.photobucket.com/albums/y26...p/IMG_0532.jpg
http://i7.photobucket.com/albums/y26...p/IMG_0533.jpg
http://i7.photobucket.com/albums/y26...p/IMG_0540.jpg
http://i7.photobucket.com/albums/y26...p/IMG_0535.jpg
Edit: Before you ask, I have an external optical drive on my desk.
Why did you remove the metal mesh on the side panel?
I thought it looked better without it. I'm considering putting it back in if I can remember where I put it. The side panel fan and mount aren't there because my HR-03 hits it when the side panel is on.
Very nice cabbspapp.
Are you not interested in the Slim Slot drive mod that other Antec 900 users are doing?
my current setup...
http://i30.photobucket.com/albums/c3...l/P1040441.jpg
http://i30.photobucket.com/albums/c3...l/P1040442.jpg
http://i30.photobucket.com/albums/c3...l/P1030884.jpg
my "other" rig.. lol..
scream can u tell me what speakers are u using ? :up:
I second that scream, the Promedia 2.1 is a very decent kit, even for gaming! By the way scream what Ballistix Tracers are you running (PC2-8000 or PC2-8500)? Thanks man!
My TJ07
Mobo Area
http://i191.photobucket.com/albums/z...8/DSC00162.jpg
Psu Area
http://i191.photobucket.com/albums/z...8/DSC00163.jpg
