andressergio
Excellent :up: work, bro
andressergio
This is what I'm currently running; went back to 4x 2GB to speed up some blu ray encodings I'm doing; completely stable:
As usual my luck with getting a good overclocker seems to avoid me.
High vid chip 1.2625 batch number L845B522 with two stuck sensors
Still tweaking, but I don't think there is much left.
Your only using 2+GB of Ram, Vista has Cached the other 6+GB.
I can get that doing nothing at idle.
I just flashed my BIOS, gave my QX9650 a good kicking, got her at 440*10 again - YAY!!! Not stable yet but hey ho
~Bex
^^^ :rofl::ROTF::clap:
Best I have been able to do Prime stable is 4.1ghz-483x8.5. Stock VID is 1.21v. Had some temp issues but think I got it worked out now. Not real pleased with it after seeing what some of these guys are hitting. The boys at Intel must have shown up hungover that Monday, or maybe I still haven't figures it out. Will just have to make the best of it. Going to shoot for high FSB with lower multi I guess.
Armchair quarterbacking is pointless. I had task manager open, available ram was like 7Gbs, started Ripbot264, and watched windows eat the ram to the last drop in less than a minute. Instead of trying to prove something that I know for a fact is wrong, do this: turn of superfetch. run an app, vista keeps it in memory, run another, same happens until system runs out of available ram and THEN vista starts to unload inactive programs from cached memory to make room for the active ones. Superfetch pre-emptively loads programs based on your usage habits into memory, with superfetch off, windows caches programs you've run for as long as there is space in memory for them. With ripbot264, obviously windows is not offloading all the working files to hard drive. This is where the speed factor kicks in because cached ram is 17x faster than a file on a hard drive. With the file sizes and high encoding settings I was dealing with, windows had use for every bit of the 8GBs on the system.
We don't do your type of new football in Scotland.
Also I don't need told how Vista works as I am an officially MS Beta Tester, but going by your screens it does look like its Cached so look at it from anothers point of view. ;)
Also I have tried it and if you have prefetch off and do a clean startup after that it will not Cache any of it, but your still has over 6GB.
Where and when did you guys get those "bad" chips?
Thanks for confirming that; I beta test MS software too. I did try to tell you, prefetch is the culprit. Like I said, you have to look at what I'm doing with the computer, and not just task manager in isolation.
PS: I actually prefer soccer to the football we have here. :yepp:
