ea6gka
ok i have installed F6b in my DS4 and everything is fine , i didnt gain any MHZ or dropped C but i have found that in easy tune you can only adjust CPU fan speed, with my old f5c adjusting the cpu fan speed at 50% for example applied the same %for the power fan connector underneath the last pci . SInce i have a VF900 powered from there i went back to f5c (f6b run the fan at 100% speed)
If you set FanControl Method in Intel QST on F6b your fan Speed is adjustable with Temp or PWM
TheForce81
C2 version isn't better by default, if you have read the article at Anandtech you would know. Also the DS3,DS4,DQ6 have been known to clock good for many other ppl, the P5B and others are also bashed at, all because of the unlucky draw! At least this is my opinion...
No I test it C2 Can do 560+MHz FSB but C1 cant do more than 510 or maybe 530+
