I feel so invisible :eek: a mere 49 posts ago i have P6TD Deluxe crossflashed with 0006 v1 :up:
deachus: If you haven't changed anything in the bios like core voltage then all I can think of is that your core temperatures are a little higher in your recent tests and that's triggering throttling. Bottom line is that bios 0001 hasn't fixed the problem like bios 0006 v1 has done for many happy users.
-=DVS=-: Sorry about that. I've been too busy juggling all these different special bios versions for all these different but very similar P6T boards that I guess I lost track. That's excellent info to know and it's even better that it's at the top of a new page so hopefully other users can find it, 49 posts from now. :D
Well flash tool and bios is deep in the thread , but whoever needs it here is my mirror at megaupload contains AFU236U (flash tool) ,006 v1 bios, and bat file you run to flash or run manually AFU236U /ibeta0006.rom /pbnc /n
What i did was boot to dos from USB stick ( i don't use floppy anymore ) and run the bat , once flashing is over , power down (i did not reset but power off), power up go to bios load defaults .
The only difference that i noticed from v1 bios compared to my original one i got extra section for SAS controller which my motherboard obviously doesn't have so select disable and your done basicly.
Hello .
I just test my mP6TD today but i noticed a problem : a small blue led is always ON near the A1 slot when i turn on my pc . What does it mean : imcompatible ram or everthing is Ok ? :confused:
My ram is : KINGSTON KHX12800D3K3/6GX 6GB 1600MHz DDR3 Non-ECC CL9 (9-9-9-27) DIMM (Kit of 3) XMP .
hai..
need help, did anyone tried the board with the new intel Xeon series such as Xeon E5XXX...
is it compatible, or is it just matter of BIOS version..
thank you...
this board is scary fast
it's missing some timings and i'm not happy that Asus seems to have locked it RAM table to CPUTweaker
Thats just silly
I'll tell them all tomorrow i guess to get that sorted out.....but it's very easy to OC..................decent RAM clocks, CPU MHz, bus, etc all good :up:
http://img22.imageshack.us/img22/420...5s32msuper.png
Can anyone give me a hand helping me get 4.0 stable please.
My cpu is a i7 920 D0 , i have it rock stable at the folowing settings , if i try 20x200 i can only get it stable at 1.294v witch doesnt sound right so mutch more volts for a 200mhz jump :shakes: . Iam watercooled and temps are ok
Stable Settings for 3.8
Advanced Cpu Settings
Cpu ratio Setting ...................[19]
C1E Support .........................[Enable]
Hardware Prefetcher ..............[Enable]
Adjacent Catch Line Prefetch ...[Enable]
Intel Virtualization ..................[Enable]
Cpu TM Function ....................[Enable]
Execute Disable Bit ................[Enable]
Intel HT Tecnology .................[Enable]
Active Processor Cores ...........[All]
A20M .....................................[Disable]
Intel SpeedStep Tech ..............[Disable]
Intel C-State Tech ..................[Disable]
Ai Overclock Tuner ................. [Manual]
CPU Ratio Setting .................. [19]
Intel Speedstep Tech .............. [Disable]
BCLK Frequency ...................... [200]
PCIE Frequency ..................... [100]
DRAM Frequency ..................... [1600mhz]
UCLK Frequency ..................... [Auto]
QPI Link Data Rate ................. [Auto]
DRAM Timing Control: Auto
____________________________________
CPU Voltage ........................ [1.20v]
CPU PLL Voltage .................... [1.82]
QPI/Dram Core Voltage .............. [1.25]
IOH Voltage ........................ [1.10]
IOH PCIE Voltage ................... [1.50]
ICH Voltage ........................ [1.10]
ICH PCIE Voltage ................... [1.50]
Dram Bus Voltage ................... [1.60]
Load-Line Calibration .............. [Enable]
CPU Differential Amplitude ......... [Auto]
CPU Clock Skew ..................... [Auto]
CPU Spread Spectrum ................ [Disable]
IOH Clock Skew ...................... [Auto]
PCIE Spread Spectrum ............... [Disable]
Thanks in advance
USOLDIER, if you go one page back you can see my 920 D0 screenshot 20x200 4Ghz which requires 1.296v to be LinX MaxMem 20 runs / Prime95 Blend 8 hours stable. I would say without a great batch that voltage is accurate for 4Ghz stable. What is your batch# and I see your mem timings are set to Auto? I would set these manually.
Hey , my batch is 3916b089 and yeah my mems are in manual 9-9-9-24 , so this would be ok to use 1.296v at 4ghz , what about QPI/Dram setting would it help anything to use it over 1.25v ?
Ive read some stuff about Qpi/Dram voltage being somewhat "linked" to Dram Voltage but still didnt understand how exactly it works and what QPI/Dram voltage may help with tbh .
Thanks for your reply deachus
Usoldier you can always avoid 20x multiplier and try 21x. There are less problems with 21x multiplier.
heheheh
i hit 5777.1MHz with the core i7 960 live on a tv show
pretty happy with that as it was a pressure bench with a board i havent used on LN2 at all
i was also messing around later and i reckon i could probably stick a 5.6GHz 32M on it too :up: very nice board
Hey guys I have small favor I am getting this board and I am going to be removing the heat-sink and re-TIMing it, I was just wondering if anyone can post some pictures of the back of the board with close ups of the screws or connectors used and if possible if anyone knows offhand the size of the screws.
And if anyone happens to know some links to a pictorial of someone re-timming the chip-set heat-sink that would also be great.
Thanks!
Exact model im getting is: ASUS P6T Deluxe V2
Hey Guys
Can I Set PCIE Frequency Over 110Mhz?
I Can't Get Over 4500Mhz With Core i7 920
I Thinck Quad 775 Must Be Hard To OC But Core i7 Is Tooooo Hard For Me :D
soldering :confused:
i've been using 112MHz boot for higher bclk clocks from bios
Guys Why I Can't Disable QPI Link Data Rate? In Bios I See Just Auto/4***/7***/10*** For This Option And No Have Off
I See Many Friend With Other Board Like Blood Rage Can Pass Test In Higher Frquency With Lower Rated FSB In CPUZ
Please Help Me :(
Whats the max bclk this board can do? Im thinking on getting this over my UD wich does 235,6bclk but droppes turbo when going above that :/
