@ pangingIII ,
I tried the settings and I was able to boot into windows. First time since trying to go to 4GHz, but it BSOD after about 5 min in Prime 95. Looks like this might be teh right path. Any other suggestions?
Thanks for your help,
-Jason
@ pangingIII ,
-Jason
i like to suggest you to always post your letest bios setting if you want to get done with the basic of this particular overclock quicker.
I got 500FSB to run, but it wasn't stable. Turns out my references weren't right. I think if I tweak them a bit more it would be stable.
The vNB was only 1.2v for the 65C temps. I can't add a fan to my NB cause my IFX-14 is in the way :(. But when I get my phase change there will be enough room for a 12cm fan :).
I hope you can do 500FSB stable. And please post pics with stress tests, volts required to do it on your UD3P, and temps. Like those pics I posted.
I see you rocking arround with that phase unit on your quad :)
You will have a blast!
1.2vNB and 65C NB temp is a NO NO. You should really try to add a fan there.
We are on page55 of the thread, and there is an option to go to page 56 already!
Crazy forum bugs...
Yeah i'm really looking forward to getting my phase change.
Also yeah that forum glitch seems to happen quite a bit in this thread :shrug:.
I'll see today if I can add a 92mm fan some how.
Sorry about that....
Here are my settings, I used what you suggested and I was able to boot into Windows, but BSOD in Prime 95 Blend...
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto <===
CPU Clock Ratio .......................: 9 <===
Fine CPU Clock Ratio...................: 0.0 <===
CPU Frequency .........................: 4.05 GHz (450X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 450
PCI Express Frequency (Mhz) ...........: Auto <===
C.I.A.2 ...............................: [Disabled] <===
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 700mV <===
PCI Express Clock Drive................: 700mV <===
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: [Turbo] <===
Extreme Memory Profile (X.M.P.)........: [Auto] <===
(G)MCH Frequency Latch.................: [333MHz] <===
System Memory Multiplier ..............: 2.4B <===
Memory Frequency (Mhz) ................: 1080
DRAM Timing Selectable ................: [Manual] <===
Standard Timing Control
CAS Latency Time.......................: 5 <===
tRCD ..................................: 5 <===
tRP'...................................: 5 <===
tRAS...................................: 15 <===
Advanced Timing Control
tRRD...................................: 4 <===
tWTR...................................: 4 <===
tWR....................................: 12 <===
tRFC...................................: 68 <===
tRTP...................................: 4 <===
Command Rate (CMD) ....................: Auto <===
Driving Strength Profiles
Driving Strength ......................: Auto <===
Channel A
Static tRead Value.....................: 8 <=== or [AUTO]
tRD Phase0 Adjustment..................: [AUTO]
tRD Phase1 Adjustment..................: [AUTO]
tRD Phase2 Adjustment .................: [AUTO]
tRD Phase3 Adjustment..................: [AUTO]
Trd2rd(Different Rank).................: [AUTO]
Twr2wr(Different Rank).................: [AUTO]
Twr2rd(Different Rank).................: [AUTO]
Trd2wr(Same/Diff Rank).................: [AUTO]
Dimm1 Clock Skew Control...............: [AUTO]
Dimm2 Clock Skew Control...............: [AUTO]
DDR Write Training.....................: [Disable] <=== or [AUTO]
Channel B
Static tRead Value.....................: 8 <=== [AUTO]
tRD Phase0 Adjustment..................: 0 [AUTO]
tRD Phase1 Adjustment..................: 0 [AUTO]
tRD Phase2 Adjustment .................: 0 [AUTO]
tRD Phase3 Adjustment..................: 0 [AUTO]
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enable]
CPU Vcore..............................: 1.250v <===> 1.325v then try lowering this value down
CPU Termination........................: 1.26V <=== then try lowering this value down to 1.24, 1.22, 1.20
CPU PLL................................: 1.50V <===
CPU Reference..........................: [AUTO] <===
MCH/ICH
MCH Core...............................: 1.26V <=== then try lowering this value down to 1.24, 1.22.
MCH Reference..........................: 0.740v <===
MCH/DRAM Ref...........................: [AUTO] <===
ICH I/O................................: 1.500V <===
ICH Core...............................: 1.100V <===
DRAM
DRAM Voltage...........................: 1.9v <===
DRAM Termination ......................: [AUTO] <===
Channel A Reference....................: [AUTO] <===
Channel B Reference ...................: [AUTO] <===
Does anyone have any ideas how I could mount a 92mm fan to cool my NB?
http://i292.photobucket.com/albums/m...2/BILD0433.jpg
okay i just finished reading your posts, i myself not able to write and read good english, it looks like yours is much better.
anyway, it seems like you want to compare board to board, also seems like you want to know into detail. and i say it also seems like you want to discredit just about every things about UD3's P45 board and everyone's idea of having to happen to own and/or about to own one of this UD3's P45 board.
so i think if you're my real world friends i would give or buy you one of these board since it will be much easy for you to have the another board (that you want to compare it with) with you,
and you will have plenty of time to work with your project and have plenty of information to write and to tell the world about what you found out on this UD3's P45 board.
Is there any way to get this board to a higher FSB with a quad without insanely high VTT?
And what is this board doing on auto.
I cannot get thing remotely stable or even to POST at a high FSB unless i use most everything auto.
Here's what i just did.
Q9550 @ 7x477 (way below it's max OC)
1.4vcore
AUTO VTT (ET6 reads 1.5)
AUTO CPU reference (ET6 reads 0.76)
1.59pll
AUTO MCH everything (ET6 reads as 1.2)
AUTO MCH reference (ET6 reads as 0.76)
It runs P95 blend stable, & IBT 5 passes stable.
So i go into BIOS & change VTT to 1.5 manual + GTL to 0.76 (both values same as being reported AUTO), & the damn board cannot POST.
So wtf magic is AUTO doing?
I don't want to be pumping 1.5vtt into my chip...i only needed 1.34v on my P5Q-D.
I assume ET6 is reading things wrong...
Any ideas would be great.
Hey n7 try jor3lBR's template, worked wonders for me. Only thing i changed was memory to 1:1 and set to to 4-4-4-12 pl9. I'm using a little lower vcore also. (1.40 bios 1.36 windows) I primed for 8hrs overnight no errors.
I just ordered a kit of gskill 2x2 9600's to replace these gskill cl4 8000's.
I can hardly wait for them to arrive. I moved from a TRUE to a good CPU only water loop yesterday and i know with good memory i can maybe get 4600mhz+ 24/7. Max temps now at 1.4bios 1.36windows Small FFT after 4 hours was 60c on all 4 cores.
Thanks again for the template.
Nice job with that Q9650, 4.4 @ 1.36, you gotta love that! Nice monster system, it's gonna rock especially with that GTX295, not much gonna get in your way! :shocked:
Nob question...How do I post my bios setting template like everyone else is doing?
Thanks Nugzo I decided to set down a bit to help people with AIR. So I had fun trying to figure out best stable options for 45nm Quads. :up:
No problem mate I'm glad I could help.
I'm afraid this board is not optimized for 2 sticks of 4Gb I'm having a hell of a deal to get my G.Skills runing smoth above 500fsb 1200+.
Hopefully I have a bad ram because I expect more from it. Give me a reply if you have luck with those rams and no MCH volt bug because I have it with 2 sticks of 2Gb's but not with 1Gb's.
Guys justa reminder of golden rule to stability on this board (at least for Quads).
MCH Reference has to be above default at least one or two 'houses'. And CPU Ref 1 lower for 45nm Quads.
Set VTT to Default 1.20v then CPU Ref and MCH Ref to their defaults. Set your desired VTT and after that raise the MCH Ref one time or two.
Keeping the default will give you Memtest #7 errors on Ram and then instability. :up:
I tried to get the max. Fsb out of my RAM OCZ Reaper 1066 rev.3.
Every thing above this 535 FSB results in Errors in the Memtest.
I also tried to get pl9 to run but this results in a no boot situation.
Has any one advice for me,
here is my bios template.
This is the situation in vista with a long mem test in this settings.PHP Code:******Gigabyte EP45 UD3R******
e8400 535 X 7,5 4000+MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 7 ]
Fine CPU Clock Ratio............................[ 0.5 ]
CPU Frequency 4.35GHz...........................[ 535 x 7.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 535 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 700mv ]
PCI Express Clock Drive.........................[ 700mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance [Turbo]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 333MHz ]
System Memory Multipler.........................[ 2.00B ]
Memory Frequency 1066...........................[ 1070 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 18 ]
******Advanced Timing Control******
tRRD............................................[4]..[ Auto ]
tWTR............................................[4]..[ Auto ]
tWR.............................................[8]..[ Auto ]
tRFC............................................[72]..[ 72 ]
tRTP............................................[4]..[ Auto ]
Command Rate (cmd)..............................[0]..[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 11 ] ................[ 10 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.2500 ]...................[ 1.40000 ]
CPU Termination [ 1.20 ]...................[ 1.22 ]
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ 0.772 ]
MCH Core [1.1 ]...................[ 1.280 ]
MCH Reference [0.760 ]...................[ 0.692 ]
MCH/DRAM Refernce [0.900 ]...................[ 1.080 ]
ICH I/O [1.500 ]...................[ 1.500 ]
ICH Core [1.100 ]...................[ 1.100 ]
DRAM Voltage [1.800 ]...................[ 2.160 ]
DRAM Termination [0.900 ]...................[ 1.180 ]
Channel A Ref [0.900 ]...................[ 1.180 ]
Channel B Ref [0.900 ]...................[ 1.180 ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Disabled ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
http://www.abload.de/thumb/xtr4emeramissueoj45.jpg
and this is what ET6 shows with these settings
http://www.abload.de/thumb/535vvista7lgk.jpg
I got a prime large run 3h which shows no errors @ 545 but memtest -> error
http://www.abload.de/thumb/primelarge545nuqw.jpg
I always need a lower mch ref to get a boot. Every thing above 0.76 will result in a no boot or errors in apps in windows. I think this is a problem with the ud3r
I have exact same problem with you, MCH ref is a big problem in UD3 for C2D and cannot got certain stability, I can go test prime no error above 2 Hrs with 533x8 E8600 for proper ET6 voltage that should be (Mch ref 0.70)
but once again I go restart computer and then go test in desktop I have got instability with same voltage setting I do in previos......damm
I see many people got success stable with Quadcore 45 nm ,may C2D can't go above high FSB or..... we need to wait new BIOS
@Jor3lBR
on your post #1383.
you quoted wrong person or something, i was never writing the comment that you quoted.
Well, seems this board is pretty nice for 2x2 once you figure out GTLs.
But very :banana::banana::banana::banana:ty for 4x2 GB. :mad:
I got 8x485 running P95 Blend just fine once i got lucky with the GTLs.
CPU Vcore [ 1.2500 ]...................[ 1.42500 ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU PLL [ 1.50 ]...................[ 1.590 ]
CPU Reference [ 0.766 ]...................[ 0.871 ]
MCH Core [1.1 ]...................[ 1.300 ]
MCH Reference [0.760 ]...................[ 0.926 ]
MCH/DRAM Refernce [0.900 ]...................[ AUTO ]
ICH I/O [1.500 ]...................[ AUTO ]
ICH Core [1.100 ]...................[ AUTO ]
DRAM Voltage [1.800 ]...................[ 2.000 ]
DRAM Termination [0.900 ]...................[ AUTO ]
Channel A Ref [0.900 ]...................[ AUTO ]
Channel B Ref [0.900 ]...................[ AUTO ]
I was pretty happy, since that means i can do over 4 GHz, depending on how much voltage i am willing to put into my Q9550.
(8.5x471+ stable as per CPU volts).
But then i put back my other 2x2 GB (identical kits, just took one out to test initially).
And with 4x2 GB, things went to crap.
Cannot even POST past 465 with the 2.00D ratio/strap. :mad:
If i switch to 2.00B i can POST higher than that, but so far, cannot get over 467 in P95 Blend w/o errors.
I've upped VTT/MCH to 1.4v, but still instant errors.
It's not the RAM either; it can do DDR2-1050+ stably, & i've even tried Memtest86+ to be sure; it's more than fine.
Seems NB is crapping out w/ 8 GB...?
I finally got the pl9 to boot within 535fsb. I changed strap from 2.00B->2.00D. But when i reboot it makes the on-off move and resets the OC settings. maybe i need 2 adjust pll or mch.
Update a termination v 1.26 solved it i also changed Mch/Dram ref 0.89 but no stability tests yet
http://www.abload.de/thumb/plboots8bfw.jpg
Hello All,
The following settings give me a BSOD before entering Windows:
I am using BIOS F7c
Now, if I just change the the FSB to 400 and manualy enter my RAM timings and keep everything else on auto. I can boot into Windows and am prime stable for 3 hours...?
What do you think?
There are so many variables.
Robust Graphics Booster ...............: FAST
Fine CPU Clock Ratio...................: 0.5
CPU Frequency .........................: 3.80GHz (400X9.5)
Clock Chip Control
CPU Host Frequency (Mhz) ..............: 400
PCI Express Frequency (Mhz) ...........: 100
CPU Clock Drive........................: 800mV
PCI Express Clock Drive................: 900mV
Performance Enhance....................: [STANDARD]
Extreme Memory Profile (X.M.P.)........: [Disabled]
(G)MCH Frequency Latch.................: [AUTO]
System Memory Multiplier ..............: 2.66D
Memory Frequency (Mhz) ................: 1066
tWR....................................: 5
tRFC...................................: 62
Command Rate (CMD) ....................: 2
Driving Strength ......................: 1066
Channel A
Static tRead Value.....................: 10
Trd2rd(Different Rank).................: 8 [AUTO]
Twr2wr(Different Rank).................: 8 [AUTO]
Twr2rd(Different Rank).................: 7 [AUTO]
Trd2wr(Same/Diff Rank).................: 9 [AUTO]
DDR Write Training.....................: [AUTO]
Channel B
CPU
Load-Line Calibration..................: [Disabled]
CPU Termination........................: 1.240V
CPU PLL................................: 1.570V
CPU Reference..........................: 0.760V [AUTO]
MCH/ICH
MCH Core...............................: 1.240V
MCH Reference..........................: 0.760v [AUTO]
MCH/DRAM Ref...........................: 0.900V [AUTO]
ICH I/O................................: 1.570V
ICH Core...............................: 1.200V
DRAM
DRAM Termination ......................: 0.900V [AUTO]
Channel A Reference....................: 0.900V [AUTO]
Channel B Reference ...................: 0.900V [AUTO]
Advanced Settings
Limit CPUID Max. to 3..................: [Disabled]
No-Execute Memory Protect..............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support...................: [Disabled]
x C4/C4E State Support.................: [Disabled]
CPU Thermal Monitor 2(TM2) ............: [Disabled]
CPU EIST Function......................: [Disabled]
Virtualization Technology..............: [Disabled]
Integrated Peripherals
Legacy USB Storage Detect .............:[Enabled]
