Here it is. Just find this on your everest, and you will be able to configure your OSD (I don't know if on english versions, it is called OSD too...)
http://img413.imageshack.us/img413/7120/osdvo1.jpg
Hope it helps,
[]'s
Simps
Hope it helps,
[]'s
Simps
The only bad thing is that the Everest I have doesn't read the volts on the UD3P :(
That is strange. It should. Go to OSD items or so. There are a lot of OSD items you can add. Maybe your voltages are just not selected there...
I found the place were I select what I want to display, but it doesn't detect my volts, it doesn't detect them in the senors tab either :(. I could get a BETA version that does, but its a trail edition.
Your version is probably old, or limited. Everest is cheap, you can go for the 4.60 ultimate version. That is a must. That is the only program I use to monitor my pc / overclock. I does everything.
I have version 4.6.
how do you manually set pl level? is there a way besides changing that one setting from turbo to extreme?
545 seems stable at 1.22cpu term and 1.26nb but its pl 11 lol.. help !
here are some results with my ud3r.....im selling this e8400 pm me if you want it http://www.xtremesystems.org/forums/...1&d=1227678191
Why are u selling ur E8400?
im just thinking of going quad or maybe i7 got a few p4,s lying around to hold me over till i decide what im doing....remember those 2 sticks of cellshocks i was selling..ask radaja about em he put em side by side with his other 2 sticks cellshocks on his ud3p and all 4 sticks booted to 1200mhz with out any change of the bios......i only sell good stuff just like this cpu i can give any one the bios settings i used on my ud3r and this bad boy will fire up at 4.45 ghz at 3.44 volts on any ud3r or p...and with only 3.44.v theres more overclocking head room left in this chip and could be good for bench marking
I'd buy ur E8400 but...
I have a E8500 on its way (with my phase change) and I had to borrow the money for that so...
You're welcome and thanks for the info.
i personally never think these UD3P/R boards overvolt the vdimm settings so i never checked it with a DMM, but this mostly because one of my friend has already checked it and told me back when we first got our first boards.
as for vdimm voltage that are reported by software, which i use Everest's or ET6's HW monitor,
one of my UD3R has, for example, if i set vdimm 2.28V at bios i will see during idle in Windows 2.26xxV,
but my another UD3R will be 2.30V in Windows. and since i believe the boards don't overvolt the vdimm settings i really don't concern much on the real vdimm voltage value.
anyways, i'm still interested to know about the G.Skill 9600 PI kit under this UD3P or R board,
can you please check and see if you can overclock this ram kit to DDR1200 and using its rated voltage spec (or lower) and if possible, please try it all, at 375fsb, 400fsb, 450fsb and 480fsb?
I just woke up, stop priming and got this on my Maximus II Formula.
Anyway, can some of you guys with quads help on the comparison?
quadcore 500FSB
7h prime blend + 20 IBT loops on max stress
http://img80.imageshack.us/img80/5244/new50013wu3.jpg
[]'s
Simps
i supposed that's looking good.
but why you post that in here? lol.
The following settings give me a BSOD before entering Windows:
I am using BIOS F7c
Now, if I just change the the FSB to 400 and manualy enter my RAM timings and keep everything else on auto. I can boot into Windows and am prime stable for 3 hours...?
What do you think?
There are so many variables.
I also tried the settings listed a page or so back and could not get it to POST.
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: FAST
CPU Clock Ratio .......................: 9
Fine CPU Clock Ratio...................: 0.5
CPU Frequency .........................: 3.80GHz (400X9.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 400
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 800mV
PCI Express Clock Drive................: 900mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: [STANDARD]
Extreme Memory Profile (X.M.P.)........: [Disabled]
(G)MCH Frequency Latch.................: [AUTO]
System Memory Multiplier ..............: 2.66D
Memory Frequency (Mhz) ................: 1066
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
tRRD...................................: 4
tWTR...................................: 4
tWR....................................: 5
tRFC...................................: 62
tRTP...................................: 4
Command Rate (CMD) ....................: 2
Driving Strength Profiles
Driving Strength ......................: 1066
Channel A
Static tRead Value.....................: 10
tRD Phase0 Adjustment..................: 0 [AUTO]
tRD Phase1 Adjustment..................: 0 [AUTO]
tRD Phase2 Adjustment .................: 0 [AUTO]
tRD Phase3 Adjustment..................: 0 [AUTO]
Trd2rd(Different Rank).................: 8 [AUTO]
Twr2wr(Different Rank).................: 8 [AUTO]
Twr2rd(Different Rank).................: 7 [AUTO]
Trd2wr(Same/Diff Rank).................: 9 [AUTO]
Dimm1 Clock Skew Control...............: [AUTO]
Dimm2 Clock Skew Control...............: [AUTO]
DDR Write Training.....................: [AUTO]
Channel B
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Disabled]
CPU Vcore..............................: 1.250v
CPU Termination........................: 1.240V
CPU PLL................................: 1.570V
CPU Reference..........................: 0.760V [AUTO]
MCH/ICH
MCH Core...............................: 1.240V
MCH Reference..........................: 0.760v [AUTO]
MCH/DRAM Ref...........................: 0.900V [AUTO]
ICH I/O................................: 1.570V
ICH Core...............................: 1.200V
DRAM
DRAM Voltage...........................: 1.9v
DRAM Termination ......................: 0.900V [AUTO]
Channel A Reference....................: 0.900V [AUTO]
Channel B Reference ...................: 0.900V [AUTO]
Advanced Settings
Limit CPUID Max. to 3..................: [Disabled]
No-Execute Memory Protect..............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support...................: [Disabled]
x C4/C4E State Support.................: [Disabled]
CPU Thermal Monitor 2(TM2) ............: [Disabled]
CPU EIST Function......................: [Disabled]
Virtualization Technology..............: [Disabled]
Integrated Peripherals
Legacy USB Storage Detect .............:[Enabled]
you can try this and post back.
Robust Graphics Booster ...............: Auto <===
CPU Clock Ratio .......................: 9 <===
Fine CPU Clock Ratio...................: 0.0 <===
CPU Frequency .........................: 4.05 GHz (450X9)
Clock Chip Control
CPU Host Frequency (Mhz) ..............: 450
PCI Express Frequency (Mhz) ...........: Auto <===
C.I.A.2 ...............................: [Disabled] <===
CPU Clock Drive........................: 700mV <===
PCI Express Clock Drive................: 700mV <===
Performance Enhance....................: [Turbo] <===
Extreme Memory Profile (X.M.P.)........: [Auto] <===
(G)MCH Frequency Latch.................: [333MHz] <===
System Memory Multiplier ..............: 2.4B <===
Memory Frequency (Mhz) ................: 1080
DRAM Timing Selectable ................: [Manual] <===
CAS Latency Time.......................: 5 <===
tRCD ..................................: 5 <===
tRP'...................................: 5 <===
tRAS...................................: 15 <===
tRRD...................................: 4 <===
tWTR...................................: 4 <===
tWR....................................: 12 <===
tRFC...................................: 68 <===
tRTP...................................: 4 <===
Command Rate (CMD) ....................: Auto <===
Driving Strength ......................: Auto <===
Channel A
Static tRead Value.....................: 8 <=== or [AUTO]
tRD Phase0 Adjustment..................: [AUTO]
tRD Phase1 Adjustment..................: [AUTO]
tRD Phase2 Adjustment .................: [AUTO]
tRD Phase3 Adjustment..................: [AUTO]
Trd2rd(Different Rank).................: [AUTO]
Twr2wr(Different Rank).................: [AUTO]
Twr2rd(Different Rank).................: [AUTO]
Trd2wr(Same/Diff Rank).................: [AUTO]
DDR Write Training.....................: [Disable] <=== or [AUTO]
Channel B
Static tRead Value.....................: 8 <=== [AUTO]
CPU
Load-Line Calibration..................: [Enable]
CPU Vcore..............................: 1.250v <===> 1.325v then try lowering this value down
CPU Termination........................: 1.26V <=== then try lowering this value down to 1.24, 1.22, 1.20
CPU PLL................................: 1.50V <===
CPU Reference..........................: [AUTO] <===
MCH/ICH
MCH Core...............................: 1.26V <=== then try lowering this value down to 1.24, 1.22.
MCH Reference..........................: 0.740v <===
MCH/DRAM Ref...........................: [AUTO] <===
ICH I/O................................: 1.500V <===
ICH Core...............................: 1.100V <===
DRAM
DRAM Voltage...........................: 1.9v <===
DRAM Termination ......................: [AUTO] <===
Channel A Reference....................: [AUTO] <===
Channel B Reference ...................: [AUTO] <===
I have ordered a few motherboards 'open-box'. The only problem with openbox boards is sometimes you get an early revision of the boards. Does this board have any early revisions, and were they terrible? i'll only save $40 bux; but hey, $40 bux is $40 bux.Ive always had good luck; but I would hate to get a crappy overclocker or something like that.
I will be getting a q9650 to put on it. I would appreciate any feedback. Thanks
Has anyone tried the UD3 with a 9800GX2? If so, please can they post up 3DM03 screenies with score breakdowns and clockspeeds?
Ideally around 4GHz 720/1100. I can interpolate the scores a bit if they're close to those levels.
Cheers!
@Simps
Yesterday I gave 500FSB a go, but I couldn't get it to load Windows :(
I'v run 515FSB before, so I don't know what setting I had wrong, but i'll give it another go in a few hours when I wake up.
I was just running Intel Burn test at 3.6GHz (400x9) and my NB temp was 65C, is that to high?
About the 500FSB not booting, it is probably related to:
mem speed (lack of vdimm)
strap
vPLL
vFSB (vtt)
vNB
About 65C NB, yes I think it is hot. Try to add a fan to the NB heatsink. Don't let it run passive. What was your vNB for that?
