check out this thread: http://www.xtremesystems.org/forums/...ad.php?t=82109
images gone, but the story tells me that this 0524vpmw chip, could crack some stuff. :)
0524 vpmw will sucks...this was also with my 0524 vpmw 3700+ :(
yeah.. right... i leave it... day to day there comes more hardware for the session and i have to watch that i can overclock my amds... :D
lol: right sold my 3400+ Venice WR chip. for once i get more money than i've paid for...
Hehe you are a luck man right now :D
0524 VPMW was seen by me at ebay in the past but I didn´t buy some because of my horrible 3700+ CBBWE 0524 VPMW :(
I tried a whole bunch of 4000+'s and 3800+'s last night, no 4000+ did more than 3200mhz/1.47v stable on air. So no WR's I guess, but I think I have a chip for the guy who wanted a decent one.
However, a 4000+ KABYE did 3ghz @ 1.5v, I have a feeling that one has the mopst potential lol.
4000+ 3dmark03 screen attached. Look at the memory clocks!:D NO artifacts in 3dmark01 or 03 (ran both a few times). Damn Rivatuner won't go higher than 1200mhz, I wonder what the real max is:)
when you get dice for these chips?
Are there any volt mods on that HD2900 Pro, bruce ?
On Friday I hope:D But I can't imagine these are WR killers.
A 3800+ lbbwe 0547 was also pretty good. 2.9ghz @ 1.63v stable, and 370mhz htt. Don't think it's good enough for a WR, though. I also tested 2 CBBLE chips, 0512 and 0513. Coldbug HARD, max htt on air was only 330mhz lol.
I can adjust the voltage in atitool (which suddenly worked lol), but I need to use rivatuner to make the fan run at full speed - and it's a PITA to switch from one program to the other etc so I'll just leave it at 850/1200 for now.
The memory can't do much more than 1200mhz. Maybe 1230 or so 8tried with atitool just now), not more than that on the stock cooler. Not sure if more cold will help, either.
Are you referring to me? If so, I have a few question:
With regards to the 4000+(s) that did 3.2GHz stable at 1.47v
1. What kind of air cooling were you using?
2. What were you ambient temperature?
3. Do you think they'll do 3GHz stable 1.35v stock cooler 23c ambient?
4. How much would you want for one?
With regards to the 4000+ that did 3GHz at 1.5v
1. That's a joke, right? The others did 200MHz more at a lower voltage yet that's your most promising 4000+? Do the others cold bug badly? Does this one scale really well with voltage? Or am I missing something? Cause in my books 3.2GHz 1.47v >>>>>>>>>>>>>> 3GHz 1.5v :confused: Your lack of a smiley such as :D or :p: leads me to believe that you're not joking. I'm very confused...
EDIT:
Just saw the "lol", so you were joking:shrug:
B1's are never great with sub-zero temps, but the BY's can work nicely down to at least -30-40c. And if the difference is only 200mhz between the 2 chips I think tha with optimal temperature, the BY cip I got to 3 ghz has a little bit more potential than the KAB1E's. But argh, I doubt I will see more than 3.8ghz on any of these anyway - if the BY doesn't scale VERy nicely with voltage and temps.
Air cooling, but low ambient. I didn't notice while I was testing. When the ambients were higher I had to turn it down to 3150 for it to be game stable (ran orthos for 1h @ 3120 without any problems as well).
I'll test the one I'm using now @ 3ghz / 1.35v with high amibents (I have no idea how hot it is in here atm but definately well above 20c.).
Like I said, 40 euro + shipping (need to find out how much that is, forgot to check, sorry). But you have paypal, or?
Yeah, PayPal's fine. I was so proud of my 3700+ at 3GHz 1.525v semi stable :(
3ghz 2h10min screen attached. Need to play a little bit now, so I must stop the test;)
Ooooh please keep me updated! Are you on stock cooling? MORE OR LESS, what is your ambient?
I've been offered a Venice 3500+:
Hardly astounding, but is there any potential?Code:ADA3500AA4BW
CAB2E 0608APWM
1423249B60401
new max frequency of K8:
http://valid.x86-secret.com/show_oc.php?id=308132
it is AM2, but it is so high ;)
That is very hard !!!! :eek:
@ oj101
Sounds good, APMW and CAB2E together will rocks but sucks if it goes under coldness.
There is one D missed in the first line ;)
:shocked:
very nice... :D
i have one x2 3800+ Toledo core with LCBQE stepping. it's stable @ 2.6Ghz with 1.5V. seems too high V for 2.6GHz. Max that I do with this Toledo was 3004Mhz but totaly unstable (i can run windows for 20sec :D ) @ 1.65V.
But I was searching and found out that that stepping isn't so bad and i've se a lot of cpu's over 3.0GHz with that stepping... i have bad luck or?
Which step ? 05XX or 06XX ? I had one X2 3800+ Manchester @ 2,6 Ghz @ Single stage and prime :D Did 2,26 ghz and prime with air cooling and default vcore...was 0526upbw
@ OJ101
here is a list of my cpus for sell:
3000+ Winchester D0: CBBGD 0439 MPMW, LBBID 0512 BPMW
3200+ Winchester D0: CBBFD 0441 MPMW, CBBID 0509 CPLW
3000+ Venice E6: NBBWE 0602 APAW ( not for sell now )
3200+ Venice E3: LBBLE 0543 VPAW
3400+ Newcastle CG: CABEC 0430 WPMW ( 2x )
3400+ Venice E6: LBBWE 0539 CPAW, NBBWE 0613 AAC
3500+ Newcastle CG: CBAUC 0421 RPMW, CBAEC 0427 WPMW, CBAXC 0431 UPBW
3500+ Clawhammer CG: CAA2C 0507 BPMW
3800+ Newcastle CG: CBASC 0417XPMW
3800+ Venice E3: LBBLE 0521 DPMW
4000+ San Diego E4: KAB1E 0624 GPMW, KAB1E 0626 FPMW, KAB1E 0630 MPMW, KAB1E 0631 APMW ( not for sell now )
4000+ San Diego E6: LCBBE 0633 BPMW
FX-53 Clawhammer CG: SAASC 0407 TPMW, CAAXC 0432 UPMW
Opteron 146 Venus E4: CACJE 0604 GPBW
Opteron 150 Denmark E6: CABGE 0532 MPMW ( 3x )
Opteron 170 Denmark E6: CCBWE 0550 VPMW, LCBQE 0724 RPMW ( not for sell now )
X2 3600+ Manchester E4: CDBFE 0712 WPMW
Thats all :D Some cpus I still have to test with prime...
So how would you rate the 3500+ I've found?
stunned_guy, please tell me a bit about the 4000+s?
knopflerbruce, I'll PM you regarding your chip later, looks like a winner to me - bench stable much higher than I can SS :D
Look at post 1369 there is my opinion for the 3500+.
The 4000+ did the following:
KAB1E 0624 GPMW: 3 GHz @ default vcore @ prime @ air; 3.43 GHz @ 1.568 v @ ss
KAB1E 0626 FPMW: 3.06 GHz @ default vcore @ prime @ air
KAB1E 0630 MPMW: 2.96 GHz @ default vcore @ prime @ air
KAB1E 0631 APMW: 3.11 Ghz @ default vcore @ prime @ air; 3.65 GHz @ 1.568 v @ ss !!!
Of course not ;)
OMW!!! 3.1GHz STABLE ON STOCK VCC?? What are your ambients though?
EDIT: C'mon, name a price... Please...
EDIT Part 2: gianni, I know you offered large amounts for both of these - Opteron 170 CCB1E 0550VPMW , Athlon FX-55 CABCE 0516WPMW - to a guy in South Africa, do you really think they're that special? I got the FX-55, I just need a HSF for it, I'll be sure to post results :D
