:rolleyes:
if you get to the windows splash screen then windows has loaded and your chip is good at that multi:up:
What if you get to the windows XP splash screen (with the bar thing moving), and then the computer just restarts?
(I tried to boot at x54 with 1.5v BIOS, LLC1, and Windows would have no part of it, just restarted on the XP splash screen (I got past the OS choices selection menu of course). Does that mean it needs more vcore?
L038A660 *A1241 53 max not bother to try max Mhz
L045B021 *A1943 53X
L050A853 *A2927 54X and Mhz wall @ 5506
3049A330 *A0174 52X max
3050A749 *A1961 52X max
3101A201 *A2247 53X max
3101A201 *A2242 54X and Mhz wall @ 5470
3101A201 *A1499 56X and Mhz wall @ 5650
All on ss cooling, seem like 3 batches need less vcore comparo to L0 batches
Um, on the gigabyte boards, you can set how many cores to use, like 1-4.
I don't know if you can MANUALLY choose which core is disabled by setting a multiplier to 0...never thought about that...I would think there is a minimum multiplier allowed, though?
So I take it that the 3101A201 with the SN# closest to A1499 would probably OC better? I haven't checked the local MC yet, but I think they still haven't sold out the tons of 2600K CPUs with the usual batch I have seen for the past three months or so yet. And even so, I may still not be able to buy one until my 14-day "Day Between Purchase" expires, which should be another week and a half. What a stupid policy, they are here to sell, so why care who buys how many times as long as they have the money to spend, right? That's the stupidest policy I have seen yet.
Is it normal to have one core (core 0 maybe) be cooler than the other three? After a day of benching and stress testing my max temps (linx) were:
c0 63c
c1 71c
c2 72c
c3 70c
Batch is 3103B302; Costa Rica.
-sfxs
Nice cpus guys, we havent even got C batches here in Aus yet, let alone 3 batches .... we have no hope down here ..... :shrug:
Can someone chime in on how consistent temp is among all the cores for the Costa Rica-based batch when idle? I know the Malaysia-based batch have a very consistent temp when idle (ie: core0 28, core1 28, core2 28, core 3 28). When stressed, each core may have a different temp.
new batch on my new 2600K #L040B307
testing multi on my Asus P8P67 Pro bios 1503
x50 ok
x51 ok
x52 ok
x53 ok
x54 ok
x55 ok
x56 ok <--- booted up to win7 logo then start freeze
x57 ok <--- booted up to win7 logo then start freeze
x58 ok <--- booted up to win7 logo then start freeze
3101A201 *1531 53X max, 5.47Ghz mhz. wall.
Damn heat problem :( just booted up X56 and lower bclk
http://img195.imageshack.us/f/x56multi.jpg/
ahh 2 cores active... need dry ice or ln2 now :D seems same problem with X57-X58 to and this chip are crazy
did i get rare chip :)??? seems so but to hot it is on air
OMG!!! I'm going to kill myself for sure. Just exchanged an L051B138 for a 3103B332 and it's not even stable at 4.6Ghz using 1.350v (the B138 was completely stable then)!!! It's getting worse!
:eek:
sigh....
if i weren't already committed to giving my friend my 2600k (and buying him a UD4), I'd just sell you my first 2600k for half price (the one that does 5 ghz at 1.5v) and does X49 with PLL disabled (didn't try booting to win at x49, just BIOS, but x50 PLL disabled is immediate overclock failed, same as my second chip).
Sorry about the luck you're having.
I got up on my feet, gathered my courage and took that suckee CPU back and exchanged it for yet another same batch with a different SN. This one is at least stable at the initial 4.6Ghz using 1.350v. Max bootable into Windows is 52x @1.550v, but far, far from stable. It would BSOD almost instantly when Prime95'ed. Tried 50x100 using 1.50v, but seems like it's not stable either with "processor [x] stopped" message. Not worth using 1.550v for a 5Ghz speed (heat and CPU life degradation). Man, CPU binning is the flakiest thing I have ever done. Never have so many bad luck in my entire life!
