lol 1.75V qpi... talk about stressing the chip. :p:
Ok, I'll try 1.4 Qpi/Vtt and if that doesn't work, I'll come back and post my system specs as well as bios settings. Hopefully, someone out there will be able to tell me where I've gone wrong.
I've had to go back down to 195 - 200 bclk since I really didn't like those voltages.
Yeah i wouldn't go over 1.5v while testing max qpi / bclk etc. One reason is because that's a sort of limit i set myself based on what i've seen and another is that i already know i can get up to 216bclk with 1.44v stable, and that i won't be wanting to go that high on my final OC anyway.
Really have to play your own game with voltages, for example i'm stable @ 4.3ghz with 1.456v, but i now know i'm also stable @ 4.2ghz with 1.37v (perhaps less, not finished testing). So there's no way i'm going to set a whole .08v higher for only 100mhz extra when the clock is already so high that it won't make a difference to me personally.
Please do post your bios settings though, can't figure out why you need such ridiculous VTT. When i started to find max bclk all i did was:
Bclock 200 (my starting point as i knew it was stable already)
CPU Multiplier 12x
Uncore Multiplier 12x
QPI Multiplier 18x (36x in bios)
Memory Multiplier 6x
Vcore 1.275v
VTT 1.46v
Vdimm 1.64v
Then i started raising bclk until i hit walls. Under this setting your roof is only going to be how high your QPI clock tops out - meant to be around or just under 4ghz.
I'll give this a shot as well. Iirc I did try it when I first got the chip and I couldn't go over 200 Bclk with 1.46vtt. I then raised it to 1.55 and was able to hit 205.
Anyways, I'll try this again, maybe I missed something
I am running 6 x 2GB memory, so would that require a higher vtt?
I'm wondering if anybody here has written a guide/tutorial about overclocking the core i7 :D:yepp:
Plenty tips kicking around:
http://www.xtremesystems.org/forums/...=205688&page=4
http://www.linustechtips.com/how-to/...clocking-guide
Not sure, maybe someone else running the same can comment. I wouldn't think it would need a whole lot more juice. Maybe at higher (1600mhz?) clocks, but for now try reducing memory multi to remove that bottleneck and see what bclk / QPI / Uncore you can get :up:
No, there is no definitive guide yet. I think it is still to early for a stick guide. We are all still testing, trying to find the holy grail. I think more so, we are all waiting to see if any chips die/degrade, and if they do, what was the cause.
He he, I hear ya. I've been begging for a step by step for a while. I guess if nobody else makes one I'll go ahead and document and photograph my entire experience when I OC here in a few days. Only problem is that its my 1st OC, so I'm not so sure how professional of a source I'll be. ;) I've been trying to do my homework though. From what I can tell it involves lossening everything up (to maybe 12) and then seeing how high you can safely get youe bclock... then you keep that and start tightening the next component. Does that sound right guys?
his is only $500
Most of my components are in my signature. I have been meaning to start a thread of my build, and will do so tomorrow - my package for performance pc's is scheduled for delivery tomorrow. Once I have it, I am going to do my final build.
I am also patiently awaiting the RMA of my 4870x2 I sent to Asus on the 8th. Haven't heard anything thus far, but am trying their live chat right now...
edit: I sent it 2-day air, yet they are claiming they didn't get it until the 16th. Such BS. Asus is trying my last nerve... I very well may sell of all my asus components and boycott.
Ok guys, as promised. I tried booting into windows at 1.35 up until 1.69 until I was finally able to do so..
I went with the following setup to remove memory and CPU votages out of the equation.
CPU Multi 13x
Qpi Multi 36x
Uncore Multi 15x
Memory Multi 6x
Let me see what else
Turbo Off
HT off
Performance - Standard
any ideas?
One source said some bclk's would max out at 190's, some 200's other ~220. Mine has a very sharp cut off at 215.
With multi 15, QPI 36, UC 16x, mem 8x, Vcore 1.4, Qpi/Vtt 1.4, DRAM 1.66, HT on, my max bclk is 215, and can run spi there. 216 will not boot.
Then I can take it outside in 5C air, UC 14, mem 6x, Vtt 1.68, +/- DRAM 1.8+, and +/- red line all other volts, bclk will then go to 217 barely load windows then freeze. no higher regardless of settings. I walked both Vtt and DRAM up and down, (one poster said got high bclk with increasing dram volts +vtt both despite low mem setting, is why I walked DRAM up +/- vtt nothing worked.
your bclk seems to go from 205 to 211 like mine goes from 215 to 217. I think both are just near their limits.
Yep. I can run 200 Bclk on <1.4 Qpi/vtt, but for me to run 205, I need about 1.55-1.65. I can't remember off the top of my head, but somewhere within that range. You saw what it took to get 211 so for me, I'll have to settle with 200 x 21 for now.
Btw, when it "hang" and doesn't boot, the bios error code that I get is 6F which on the Gigabyte EX58 Extreme says:
1. Initialize Floppy Controller
2. Setup Floppy related fields in 40:hardware.
I don't have a floppy connected. lol.
Sounds like you're limited by your chip after all then lukee. What's with all those other settings though, cpu pll etc? I've hit pretty high clocks without having to touch that stuff (not even sure what it does), i wonder if they're high enough to cause instability.
I agree if you want to 'challenge' someone to a benchmark create a thread for it. Alternatively, there are probably a hundred reviews by now detailing how much faster i7 is than penryn at any given task..
4.3 prime stable 10 hours - HT off, unlikely I will get 4.4 on air but must try!
The spread sheet was rge's design - good approach!
I think 4.3 on air is the max for me - 4.32 @ 1.55v is way to hot!
Interesting that it actually got through linpack x5.
On real temp - when it reaches 100C - thermal status goes to "HOT" for that proc.
