double post.. --- edited.
Code:CPU Feature
Thermal Management Control: Disabled
PPM(EIST) Mode: Disabled
Limit CPUID MaxVal: Disabled
CIE Function: Disabled
Execute Disable Bit: Enabled
Virtualization Technology: Enabled
Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: Auto
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9.5x
Target CPU Clock: 3800MHz
CPU Clock: 400MHz
Boot Up Clock: Auto
DRAM Speed: 266/667
Target DRAM Speed: 1003MHz
PCIE Clock: 110MHz
PCIE Slot Config: 1x 1x
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU ViD Control: 1.2875V (1.32V)
CPU VID Special Add: Auto
DRAM Voltage Control: 2.19V (2.16V)
SB Core/CPU PLL Voltage: 1.510V
NB Core Voltage: 1.35V (1.33V)
CPU VTT Voltage: 1.100V (1.10V)
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45V
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disabled
DRAM Timing
Enhance Data transmitting: Fast
Enhance Addressing: Fast
T2 Dispatch: Enabled ( better if u dont mess with the MCH latencies.. cause infact this reduces the latencies but setting mch latencies to 1.. is like setting it disabled.. from the readings i got in everest)
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: More Aggressive
DIMM 1 Clock fine delay: Current
DIMM 2 Clock fine delay: Current
Ch 1 Command fine delay: Current
Ch 1 Control fine delay: Current
Ch1 Command fine delay: Current
Ch2 Clock Crossing Setting: More Aggressive
DIMM 3 Clock fine delay: Current
DIMM 4 Clock fine delay: Current
Ch 2 Command fine delay: Current
Ch 2 Control fine delay: Current
Ch2 Command fine delay: Current
Ch1Ch2 CommonClock Setting: More Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 18
All Precharge to Act: 5
REF to ACT Delay (tRFC): Auto ( Since OCZ recommended that)
Performance LVL (Read Delay) (tRD): 7
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
Channel 1 Phase 0 Pull-In: Disabled
Channel 1 Phase 1 Pull-In: “
Channel 1 Phase 2 Pull-In: “
Channel 1 Phase 3 Pull-In: “
Channel 1 Phase 4 Pull-In: “
Ch2 Read delay phase (4~0)
Channel 2 Phase 0 Pull-In: Disabled
Channel 2 Phase 1 Pull-In: “
Channel 2 Phase 2 Pull-In: “
Channel 2 Phase 3 Pull-In: “
Channel 2 Phase 4 Pull-In: “
MCH ODT Latency: Auto ( Tested.. no diff .. infact latencies drop occur on 2-3)
Write to PRE Delay (tWR): 14 ( memtest shows 13)
Rank Write to Read (tWTR): 11( memtest shows 10)
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 5
Ranks Read to Read (tRDRD): 5
Ranks Write to Read (tWRRD): 5
Read CAS# Precharge (tRTP): 3 ( Memtest shows 4)
ALL PRE to Refresh: 5
hmm for 400fsb ram at 1000mhz CL5 tRD 6.. 2gb kit i need around FSB 1.35
Cl4 tRD 5 on 4x1gb need around NB 1.4
that is major bump when 800 CL3 trd 6 is still okay on default NB voltage..
yes i get that too ..the cold boot issue.. its freaking random
even though occt 12 hours/ memtest86 overnight/ wdmt 5 passes says stable.
once in a while restart/ minor changes in bios/ once in every 4 times of powerup.. it wont boot .. until i reboot it the second time...
hmm ure voltage is kindda low.. for lower trd, high bandwidth on ram, increasing multi and lower bus.. u need more vdimm.. compare to 1:1 500fsb..
dunno this is my take so far.. on this..
wheres the PWMIC(System) sensor on this board?
Will that 04/08 BIOS for the UT work on the LT board?
Are they not the same boards but with different cooling?
Got me a UT coming thursday :D
DFI LANParty UT X48-T2R
http://www.edgeofstability.com/image.../box_front.jpg
http://www.edgeofstability.com/image...d/box_rear.jpg
http://www.edgeofstability.com/image...box_rear_a.jpg
http://www.edgeofstability.com/image.../board/acc.jpg
http://www.edgeofstability.com/image...rd/board_h.jpg
http://www.edgeofstability.com/image...rd/board_a.jpg
http://www.edgeofstability.com/image...rd/board_b.jpg
DFI LP UT X-48
http://www.edgeofstability.com/image...rd/board_e.jpg
http://www.edgeofstability.com/image...rd/board_g.jpg
http://www.edgeofstability.com/image...oard_piper.jpg
http://www.edgeofstability.com/image...board_rear.jpg
http://www.edgeofstability.com/image...rd/board_d.jpg
http://www.edgeofstability.com/image...rd/board_c.jpg
DFI UT X48-T2R, Post 1 Of 3
E8400 04/02 BIOS
All Default Settings Except VCORE And FSB
2x2GB OCZ PC2 9200 Flex2
XFX8800 GTS (G92)
Air Cooled - 120 Extreme
http://www.edgeofstability.com/image...ios/main_s.jpg
http://www.edgeofstability.com/image.../voltage_s.jpg
http://www.edgeofstability.com/image...s/dram_1_s.jpg
http://www.edgeofstability.com/image...s/dram_2_s.jpg
http://www.edgeofstability.com/image.../clock_1_s.jpg
http://www.edgeofstability.com/image.../clock_2_s.jpg
http://www.edgeofstability.com/image...os/phase_s.jpg
http://www.edgeofstability.com/image.../feature_s.jpg
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU N/2 Ratio.............................Disabled
CPU Clock.................................450 MHz
Boot Up Clock.............................Auto
DRAM Speed................................Auto
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................Auto 1.2200V
CPU VID Special Add.......................111.57%
DRAM Voltage Control......................1.904V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.265V
CPU VTT Voltage...........................1.100V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................110
CPU GTL 0/2 REF Volt......................110
North Bridge GTL REF Volt ................110
DRAM Timing Page
Enhance Data Transmitting.................Auto
Enhance Addressing........................Auto
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................Auto
RAS# to CAS# Delay (tRCD).................Auto
RAS# Precharge (tRP)......................Auto
Precharge Delay (tRAS)....................Auto
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................Auto
Performance Level.........................Auto
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................Auto
DIMM 1 Clock fine delay...................Current 67ps
DIMM 2 Clock fine delay...................Current 445ps
DIMM 1 Control fine delay.................Current 512ps
DIMM 2 Control fine delay.................Current 267ps
Ch 1 Command fine delay...................Current 779ps
Ch2 Clock Crossing Setting................Auto
DIMM 3 Clock fine delay...................Current 67ps
DIMM 4 Clock fine delay...................Current 378ps
DIMM 3 Control fine delay.................Current 356ps
DIMM 4 Control fine delay.................Current 345ps
Ch 2 Command fine delay...................Current 779ps
Ch1Ch2 CommonClock Setting................Auto
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
DFI UT X48-T2R, Post 2 Of 3
E8400 04/02 BIOS
XFX8800 GTS (G92)
XP SP3
http://www.edgeofstability.com/image...prime_xp_s.jpg
http://www.edgeofstability.com/image..._3d06_xp_s.jpg
http://www.edgeofstability.com/image...0x9_crysis.jpg
http://www.edgeofstability.com/image.../450x9_ut3.jpg
3dx Max w/V-ray
Time to render: 14min 20sec
http://www.edgeofstability.com/image...chmark_680.jpg
http://www.edgeofstability.com/image...x9_everest.jpg
DFI UT X48-T2R, Post 3 Of 3
E8400 04/02 BIOS
XFX8800 GTS (G92)
Vista 64 Bit SP1
http://www.edgeofstability.com/image...prime_64_s.jpg
http://www.edgeofstability.com/image..._3d06_64_s.jpg
http://www.edgeofstability.com/image...ntage_64_s.jpg
http://www.edgeofstability.com/image...crysis_64_.jpg
http://www.edgeofstability.com/image...x9_ut3_64_.jpg
3dx Max w/V-ray
Time to render: 15min 37sec
http://www.edgeofstability.com/image...everest_64.jpg
Can you tell me please if with the UT stock cooling,does the NB heat up a lot under overclocking environment or not?
Should I get the HR-05 SLI IFX extra for the NB?
@Praz
can you play please with some 4x2Gb memory?
Is it worth waiting for the T3R? (Other than for the privilege of paying more for memory ;)). Any significant speed advantage?
I don't think I have 8gb of DDR2 here close enough to each other, even by redoing the SPD, that will play nice together. I'll check
Won't know till some of us have the board. One would think there would be some type of advantage as the chipset was designed for DDR3 but with DDR2 support built in. But that may or may not translate to a real world difference.
i just received my LT today, i will do full testing against my maximus formula on sunday w/ exact same hardware (doing a motherboard transplant)
my goal is to exceed my 24/7 that I am at currently. reason being, i feel that asus could have implemented better gtl control over the cpu on the maximus/rampage and didnt on purpose, thus this is my limiting factor atm w/ acceptable volts temps. see sig for specs, im just hoping to same memory bandwidth as well once tweaked.
what do you guys think? is this do-able? or did am i going to be returning a mobo.
wasup, any one know what happen with Clunk's forum :confused:
He's rebuilding/upgrading a few bits of the site and hopes to get the site back up this evening.
Regards
BS
man not sure if i should grab one of these or wait for p45 .. i have a x38 now.... hmmm desicions ..
hmm good point forgot about that..i just dont know if ill gain anything over the x38 by going with this ... doesnt seem i will real world wise??
