Originally Posted by
n00b 0f l337
I'm putting a fan grill of sorts on the lower right to allow the phase unit to exhaust air not into the case, what do you want to do Russian?
I would simply painters tape the entire thing, draw out carefully (and measure twice) your window. Start in the area you'll be throwing out, if you have like a 1.5" holesaw, drill a hole, then jigsaw from their. If you have a dremel, just start after the tape and design go cutting, be ready to file afterwards. Or, if you have a full holesaw set, use them as tracers for your windows curves if any, and then use them to remove all said curves, and jigsaw/hacksaw/dremel to remove the non bend sections.
