I guess my nuts on my hsf are pretty tight then lol
First, I would like to say thanks to Eva and all the gurus here for this complete thread. It has help me a lot.
But here is the reason of this post:
I was testing my beloved L629B when I come to this strange (at least for me) behavior on this motherboard.
Fsb at 413 x 9 I got 3717
Fsb at 414 x 9 I got 3312 :confused:
Fsb at 415 x 9 I got 3735
tested twice, fsb set in bios. For some reason at 414, the multi switchs to 8 by itself.
I need some feedback on this, Is anyone else getting this issue? Is this some kind of strap thing or something related?
Bios is 311, I have all the options at the cpu menu at disabled, only PECI is enabled.
I had a similar thing with a P5WDH.. at 414 and 416 it booted ok, but at 415 was a no go.
It's nothing to do with the tightness of the thermal grease, more the fact that it ensures that the board isn't warped, so that the whole of the CPU ICH is flush with the cooling block, not just a corner of it.Quote:
it has something to do with the tighness or the thermal grease
A bolt thru kit can have as much impoact as lapping, but fixes different raft of issues.
Very likely:DQuote:
`danny
You are right monza1412 !
The same here :
Fsb at 413 x 9, I got 3717 with np
Fsb at 414 x 9, I got 3312 (9 x 368) !!!!
Fsb at 415 x 9, I got 3735 with np
Also at (414 x 9) = 3312 (9 x 368) with static read control enabled : not boot !
These trials with bios 311, later I will try with 501.
Very strange issue ! :confused:
Edit : exactly the same with 501 bios [at 414 x 9, I got 3312 (9 x 368)]
Is there a way to change the Fsb speed to 1333 on a Asus P5K Deluxe,when using a Q6600??
What is this enable\disable ME on p5k deluxe board? it is missing the jumper pins. but it can be manipulated with conductive paint i belive. but what is it ?
it is placed above blue pci-e 16x port and end of DELUXE name.
Actually, it's not stability.... I'm having the same issue as well. Have a look see here though! ;)
http://support.microsoft.com/kb/936686/en-us
Is raid 0 working properly on this board? Any other issues I should know about before buying one?
Those peeps with SATA II, were having probs if I am correct.
*edit sorry I thought it was pointing the premium, so far I didnt experienced any SATA( raid) probs really on the deluxe
i have one of this mobo, but i'm using a e6850, overclock nice with stoc vcore, but my temps are too slows, anyone have a problem like this ? :s
look this, it's a fresh instalation of vista, i try too in xp 'n have the same temps :confused:
http://img367.imageshack.us/img367/7...idlerv3.th.jpg
this is on xp @ 3.6
http://img521.imageshack.us/img521/7...0a36xt4.th.jpg
You need to down load the latest core temp Beta 0.95.4 or add 15 deg to your current core temp. See here. Downlaod core temp 0.95.4 Or here I think the link is broken though.:(
I was bored today and I did some spi runs just to see the DRAM Static Read Control / Transaction Booster options influence in memset and in the superpi score. All test were done with 5.5.5.15 timings at 1:1 (the others sub-timings at AUTO - Command Rate at 2T - bios 311).
first run: DRAM Static Read Control DISABLED / Transaction Booster DISABLED (Relax0)
http://www.subirimagenes.com/imagene...00disabled.JPG
second run: DRAM Static Read Control DISABLED / Transaction Booster ENABLED (Boost level 1)
http://www.subirimagenes.com/imagene...00 trans 1.JPG
At boost level 0, the performance level went to 11
third run: DRAM Static Read Control ENABLED / Transaction Booster DISABLED (Relax0)
* leaving DRAM Static Read Control AUTO / Transaction Booster AUTO gave the same results
http://www.subirimagenes.com/imagene...073800auto.JPG
Also changing the relax options shows changes in the performance level in memset, the others subtimings remains the same
Relax 0 - Performance level 8
Relax 1 - Performance level 9
Relax 2 - Performance level 10
Relax 3 - Performance level 11
So, as it has been said before, the Dram Static Read Control option has more influence in performance/bandwith gains than the transaction booster option.
ok tnks Crossg i try this version, but this link are broke, i try to download later, and tnks Severance i go to install AI Suite now...... :up:
I also made this
nice work chessman :up: . I was shocked with the vdrop in this board, from 1.3 in bios to 1.208 load. The voltage damper option should come enabled by default and not at auto that its the same as disabled.
But I really dont have any serious complain about this mobo, it has all that I didnt find in my P5WDH.
