Originally Posted by
a573573
That is ONLY because ET Shows the .xx % of Vtt of what you set in the BIOS. The Default Value of MCH Ref is .63% of Vtt at stock of 1.20V, which is .756 (.76)
The Ref Settings in the BIOS are .xx % values of/X Vtt so this tends to throw off many users when they set something and then compare to EasyTune. So you need to keep the % amounts in mind when changing these Ref voltages, and it is easiest to do it at stock Vtt and then raise your Vtt back up to where you want to run it. If you Make any deviation from the stock % for MCH Ref of .63% the value will be reflected in ET
Here is Four Common examples of this, all using MCH Ref, and 1.30 Vtt (Termination). All of these but the last WILL Change what you see for MCH Ref in EasyTune as well. This way I hope you can see how this works, and then maybe better find your way to tuning your Ref voltages
*** Examples Below using 1.3 Vtt ***
(MCH Ref .68% AKA .68 in ET)
For example if you set 1.3 Vtt and .884 MCH Ref, ET would show .68 MCH Ref as .884 would be .68% of Vtt.
(MCH Ref .70% AKA .70 in ET)
Another example if you set 1.3 Vtt and .91 MCH Ref, ET would show .70 MCH Ref as .91 would be .70% of Vtt
(MCH Ref .72% AKA .72 in ET)
Another example if you set 1.3 Vtt and .936 MCH Ref, ET would show .72 MCH Ref as .936 would be .72% of Vtt
STOCK MCH Ref VALUES at .63% (To Help show how ET Seems to always show .76 for users)
First Example shows stock values for Ref used, .63%. That would be MCH Ref manually set but Value unchanged (.76) and then Vtt Raised to 1.3, or manually set to .819 and Vtt Manually set to 1.3..........
(Stock MCH Ref W/ 1.3 Vtt / .76 in ET)
If you set 1.3 Vtt and .819 MCH Ref ET would show .76 MCH Ref as .819 would be .63% of Vtt
This Example shows Stock Vtt and Stock MCH Ref used.........
(Stock MCH Ref W/1.20 Vtt or .76 in ET)
If you set 1.2 Vtt and .756 MCH Ref ET would show .76 MCH Ref as .756 would be .63% of Vtt.
That is just ONE example, and how to manipulate it, of the Many Ref Voltages in the BIOS Vs. what you see in Easytune.
Here are all the values affected by other Values in the BIOS and their respective Percentages.
CPU Termination (Vtt) Automatically changes the following if manually set >>>
CPU Reference Voltage (.63% of Default Vtt/1.20)
CPU Reference2 Voltage (.67% of Default Vtt/1.20)
MCH Reference Voltage (.63% of Default Vtt/1.20)
DRAM Voltage Automatically changes the following if manually set >>>
MCH/DRAM Reference Voltage (.50% of Default Dram Voltage)
DRAM Termination Voltage (.50% of Default Dram Voltage)
Channel A Reference Voltage (.50% of Default Dram Voltage)
Channel B Reference Voltage (.50% of Default Dram Voltage)
If you want a higher or lower than stock % / Value for any of the above settings you will find it easier to set the Dram Voltage or Vtt back to stock (Or above or below to find and be able to choose alternate % Values), then adjust desired setting to the % / Value you wish to use.
Then once you have selected a % range you want to use for said setting then go back and raise your Vtt or Dram Voltage back to what you choose to use and the corresponding settings will self adjust and still be set to the .xx % amount that you set them to.
