Wow... some cable management there maybe.. lol jk jk Not bad at all. and I see why your 280 stays cool. It has those 2 fans blowing 150CFM of air into it.. or more lol.
cool. I want the TRUE
Yes. The project managers assign points to different kinds of work that they distribute. And these points are subject to change over time. They know that most folders will configure their rigs to maximize PPD so they assign more points to the types of work (work units, or "WU's") that are the most important to the project at that time. Sometimes this is just for beta test results - as they are testing a new client or WU they may temporarily assign higher points to get high participation until they work the kinks out. Bear in mind, this may change. The risk of going out and buying/building a farm that's geared towards a certain WU or client or project is that the PPDs may change, or the and leave you hanging... the other thing that many of us look for is PPD/$ or PPD/watt or whatever. Check out the F@Hinfo database. Interesting effort to track F@H scores on particular setups.
You've come to the right place :yepp:Quote:
I've spent all this time and money getting this thing up, and just like you guys have said. OK. I've finally got over 19k in Mark06.. now what...
Many of us have lost loved ones to the diseases that F@H and other DC projects aim to cure. It's the best way I know to contribute directly to the greater good. It's that sense of doing something bigger than ourselves that make this such a great community and a rewarding project.Quote:
And yes, my grandpa was very close to me. He was the nicest man I've ever known.
You pretty much control this. There are several different versions of the F@H client, with varying demands on system components. And just as with overclocking, how hard you push it, and how cool you can keep everything has the most to do with component lifespan and failure rates. There is no doubt that folding is intensive work, and as U&G says, "stable rigs are happy rigs". Power consumption does go up, but with some of the newer clients (like the nvidia GPU client), you can get a whole lot of points with relatively low power consumption.Quote:
Also, I'm not trying to sound mean, Selfish...I've spent ALL this money on this...Learned so many things. use it daily. Something like a 100% 12/7 or 24/7, or even 24/5 loading up the computer.. that would severely shorten the life of the system right. What type of wear and tear does folding add to your system overall.. Oh and here is even a better question. How much did your power bills rise with running this.
HTH!
If you want to do a cheap farm, forget CPU folding...
Get an althlon x2, something that can handle vista without giving you a head ache, 2 gigs of ram.
Now for the important stuff.
Mobo: 4 pci-e slot, like the msi k9a2
PSU: something that'll handle 4 cards, like corsair 750watt psu. :up:
Cards: 9600gso's or 8800gs (if you can find it) x4
That system will put out about 20K points for relatively low cost.
Ya I bet it would.. 4 cards even if GS models would push a lot. the eVGA 9600 GSO is at newegg.com for 35 bucks after MIR.. great deal. I almost got one for a backup. that would be a good deal to get for a farm.
and to coo coo, Thanks for the info there. yea I can see how this can really push your system. but Mines stable as can be at 4.0 Ghz so I'm ok for that. Although I have not installed the CPU folder yet.
the GPU2 seemed to run fine. my card only got to about 59c after about 2 hours of folding so thats not bad at all.
I do have a question. I let it go and went to sleep. I get up this morning and it's finished. but it never sent, and my net was down. I had to restart to get it back. That never, ever happens. was that cuz the folding? and how can I send it now and get the points and start my next. In Fahmon it's yellow and says finished.. (6380 PPD on just the GFX card. is that good for it at stock speed.) I can run this GTX from 576 Mhz to 740 in games fine. So I could probably do that while folding..
So what do I do. I restarted and it's still in Fahmon. but how do I send it now?
Edit* Now it restarted. the same one is going again. Now back to the beginning. it's at 9% already. Is it going to redo the entire one I already did? I'm confused a little here. Can't seem to figure out how to send it.
it probably sent, it should be in your log. but you need to gto control panel power options and set it to high performance, so your system and nic wont goto sleep and shutdown the client. you can set your screensaver to turn the monitor off, that's fine. just not the rest of the system.
this is what it looks like when it send, it does it on it's own. all you have to do is start the client and keep your system and internet connection running.
[18:46:01] Folding@home Core Shutdown: FINISHED_UNIT
[18:46:04] CoreStatus = 64 (100)
[18:46:04] Sending work to server
[18:46:04] Project: 5013 (Run 7, Clone 363, Gen 93)
[18:46:04] + Attempting to send results [October 12 18:46:04 UTC]
[18:46:26] + Results successfully sent
[18:46:26] Thank you for your contribution to Folding@Home.
[18:46:26] + Number of Units Completed: 800
and then after a while when you turn in some units and eoc can track your points..
you can check the team page here http://folding.extremeoverclocking.c...php?s=&t=36362
click on users list and find your name, then you can use that sig image link I gave you in the other thread and put it in your sig.
but I'd give it a day before eoc sees you as a new user. just make sure you're running the client and it's not going to sleep and stopping everytime you leave the pc alone.
Ya I just saw that about 10 mins ago.. I restarted my system. and opened fahmon and then GPU2 started on it's own something else. I looked in the log and it shows it not sending and all the retry's. then it trying to get a new WU and failing. but then after I restarted system I think it sent it as I saw that farther down now I restarted it.
After restart this is what my log says:
[18:44:35] + Attempting to send results [October 12 18:44:35 UTC]
[18:44:36] - Presenting message box asking to network.
[18:44:50] + Results successfully sent
[18:44:50] Thank you for your contribution to Folding@Home. <--- (thats what I'm lookin for right)
[18:44:50] + Starting local stats count at 1
[18:45:05] + Attempting to get work packet
[18:45:05] - Connecting to assignment server
[18:45:05] - Successful: assigned to (171.xx.xx.xxx).
[18:45:05] + News From Folding@Home: GPU folding beta
[18:45:05] Loaded queue successfully.
[18:45:06] + Could not connect to Work Server
[18:45:06] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry. (did like 7 retries then finally started. Not sure what thats about. It did that after it finished last night also. and then when no WU started it stopped working and PC went to sleep. Oh and It's already set to Performance in the Power options, but thanks for the idea. So ya, looks like the first one went then. and this second one is doing much better now I added the OC'd profile to my GTX260 so far it's saying 7425 PPD.. but it's been rising this entire time. What can I expect from this 260?
shader is where you'll se the most gain in folding.
but you need to watch that log and make sure it completes from 1%-100% without spitting out an unstable machine before it gets to 100%. if it is, your oc is too high.
dont' worry about all the retries , that's stanfords servers getting busy and not allowing your client too connect. it puts you in line to wait and spits out that retry message until it's your turn to get a wu or send one.
the most imprtant thing is making sure it can go from 1-100% without errors.
also in fahmon, goto preferences and set to calculate ppd on last frame only and it wull give a quicker ppd averages.
this is what successful wu's looks like, notice I have some busy reties near the end also. those are fine. but if you cant get a 1-100% completion, then you need to back off the oc.
Code:
--- Opening Log file [October 9 09:35:45 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.20r1
http://folding.stanford.edu
Launch directory: C:\Users\Mike Hudson\AppData\Roaming\Folding@home-gpu
[09:35:45] - Ask before connecting: No
[09:35:45] - User name: mikeb12 (Team 36362)
[09:35:45] - User ID: 504D8E7326393487
[09:35:45] - Machine ID: 3
[09:35:45]
[09:35:45] Loaded queue successfully.
[09:35:45] Initialization complete
[09:35:45]
[09:35:45] + Processing work unit
[09:35:45] Core required: FahCore_11.exe
[09:35:45] Core found.
[09:35:45] Working on queue slot 07 [October 9 09:35:45 UTC]
[09:35:45] + Working ...
[09:35:46]
[09:35:46] *------------------------------*
[09:35:46] Folding@Home GPU Core - Beta
[09:35:46] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[09:35:46]
[09:35:46] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:35:46] Build host: amoeba
[09:35:46] Board Type: Nvidia
[09:35:46] Core :
[09:35:46] Preparing to commence simulation
[09:35:46] - Looking at optimizations...
[09:35:46] - Files status OK
[09:35:46] - Expanded 45554 -> 246249 (decompressed 540.5 percent)
[09:35:46] Called DecompressByteArray: compressed_data_size=45554 data_size=246249, decompressed_data_size=246249 diff=0
[09:35:46] - Digital signature verified
[09:35:46]
[09:35:46] Project: 5506 (Run 6, Clone 113, Gen 161)
[09:35:46]
[09:35:46] Assembly optimizations on if available.
[09:35:46] Entering M.D.
[09:35:52] Will resume from checkpoint file
[09:35:52] Working on p5506_supervillin_e1
[09:35:53] Client config found, loading data.
[09:35:53] Resuming from checkpoint
[09:35:53] Verified work/wudata_07.log
[09:35:53] Verified work/wudata_07.edr
[09:35:53] Verified work/wudata_07.trr
[09:35:53] Starting GUI Server
[09:35:53] Verified work/wudata_07.xtc
[09:35:53] Completed 42%
[09:37:18] Completed 43%
[09:38:41] Completed 44%
[09:40:04] Completed 45%
[09:41:26] Completed 46%
[09:42:49] Completed 47%
[09:44:11] Completed 48%
[09:45:35] Completed 49%
[09:46:58] Completed 50%
[09:48:20] Completed 51%
[09:49:43] Completed 52%
[09:51:05] Completed 53%
[09:52:28] Completed 54%
[09:53:50] Completed 55%
[09:55:13] Completed 56%
[09:56:38] Completed 57%
[09:58:02] Completed 58%
[09:59:31] Completed 59%
[10:00:55] Completed 60%
[10:02:19] Completed 61%
[10:03:44] Completed 62%
[10:05:07] Completed 63%
[10:06:32] Completed 64%
[10:07:55] Completed 65%
[10:09:19] Completed 66%
[10:10:43] Completed 67%
[10:12:08] Completed 68%
[10:13:32] Completed 69%
[10:14:56] Completed 70%
[10:16:20] Completed 71%
[10:17:43] Completed 72%
[10:19:08] Completed 73%
[10:20:41] Completed 74%
[10:22:16] Completed 75%
[10:23:52] Completed 76%
[10:25:22] Completed 77%
[10:26:46] Completed 78%
[10:28:08] Completed 79%
[10:29:31] Completed 80%
[10:30:53] Completed 81%
[10:32:16] Completed 82%
[10:33:40] Completed 83%
[10:35:04] Completed 84%
[10:36:30] Completed 85%
[10:37:55] Completed 86%
[10:39:18] Completed 87%
[10:40:43] Completed 88%
[10:42:08] Completed 89%
[10:43:31] Completed 90%
[10:44:54] Completed 91%
[10:46:17] Completed 92%
[10:47:39] Completed 93%
[10:49:03] Completed 94%
[10:50:27] Completed 95%
[10:51:52] Completed 96%
[10:53:27] Completed 97%
[10:55:01] Completed 98%
[10:56:37] Completed 99%
[10:58:11] Completed 100%
[10:59:11]
[10:59:11] Finished Work Unit:
[10:59:11] - Reading up to 34800 from "work/wudata_07.trr": Read 34800
[10:59:11] trr file hash check passed.
[10:59:11] - Reading up to 1128228 from "work/wudata_07.xtc": Read 1128228
[10:59:11] xtc file hash check passed.
[10:59:11] edr file hash check passed.
[10:59:11] logfile size: 125267
[10:59:11] Leaving Run
[10:59:16] - Writing 1289367 bytes of core data to disk...
[10:59:16] ... Done.
[10:59:16] - Shutting down core
[10:59:16]
[10:59:16] Folding@home Core Shutdown: FINISHED_UNIT
[10:59:20] CoreStatus = 64 (100)
[10:59:20] Sending work to server
[10:59:20] Project: 5506 (Run 6, Clone 113, Gen 161)
[10:59:20] - Read packet limit of 540015616... Set to 524286976.
[10:59:20] + Attempting to send results [October 9 10:59:20 UTC]
[10:59:41] + Results successfully sent
[10:59:41] Thank you for your contribution to Folding@Home.
[10:59:41] + Number of Units Completed: 7
[10:59:45] - Preparing to get new work unit...
[10:59:45] + Attempting to get work packet
[10:59:45] - Connecting to assignment server
[10:59:46] - Successful: assigned to (171.64.65.20).
[10:59:46] + News From Folding@Home: GPU folding beta
[10:59:46] Loaded queue successfully.
[10:59:47] + Closed connections
[10:59:47]
[10:59:47] + Processing work unit
[10:59:47] Core required: FahCore_11.exe
[10:59:47] Core found.
[10:59:47] Working on queue slot 08 [October 9 10:59:47 UTC]
[10:59:47] + Working ...
[10:59:47]
[10:59:47] *------------------------------*
[10:59:47] Folding@Home GPU Core - Beta
[10:59:47] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[10:59:47]
[10:59:47] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:59:47] Build host: amoeba
[10:59:47] Board Type: Nvidia
[10:59:47] Core :
[10:59:47] Preparing to commence simulation
[10:59:47] - Looking at optimizations...
[10:59:47] - Created dyn
[10:59:47] - Files status OK
[10:59:47] - Expanded 44054 -> 244433 (decompressed 554.8 percent)
[10:59:47] Called DecompressByteArray: compressed_data_size=44054 data_size=244433, decompressed_data_size=244433 diff=0
[10:59:47] - Digital signature verified
[10:59:47]
[10:59:47] Project: 5016 (Run 4, Clone 58, Gen 101)
[10:59:47]
[10:59:47] Assembly optimizations on if available.
[10:59:47] Entering M.D.
[10:59:53] Working on 576 p5005_supervillin_e1
[10:59:54] Client config found, loading data.
[10:59:54] Starting GUI Server
[11:01:19] Completed 1%
[11:02:45] Completed 2%
[11:04:12] Completed 3%
[11:05:35] Completed 4%
[11:06:59] Completed 5%
[11:08:22] Completed 6%
[11:09:48] Completed 7%
[11:11:22] Completed 8%
[11:12:57] Completed 9%
[11:14:28] Completed 10%
[11:15:58] Completed 11%
[11:17:24] Completed 12%
[11:18:48] Completed 13%
[11:20:17] Completed 14%
[11:21:44] Completed 15%
[11:23:11] Completed 16%
[11:24:38] Completed 17%
[11:26:06] Completed 18%
[11:27:39] Completed 19%
[11:29:14] Completed 20%
[11:30:49] Completed 21%
[11:32:25] Completed 22%
[11:34:00] Completed 23%
[11:35:36] Completed 24%
[11:37:09] Completed 25%
[11:38:36] Completed 26%
[11:40:03] Completed 27%
[11:41:30] Completed 28%
[11:42:57] Completed 29%
[11:44:23] Completed 30%
[11:45:49] Completed 31%
[11:47:19] Completed 32%
[11:48:55] Completed 33%
[11:50:30] Completed 34%
[11:52:05] Completed 35%
[11:53:40] Completed 36%
[11:55:13] Completed 37%
[11:56:47] Completed 38%
[11:58:23] Completed 39%
[11:59:54] Completed 40%
[12:01:22] Completed 41%
[12:02:57] Completed 42%
[12:04:26] Completed 43%
[12:05:53] Completed 44%
[12:07:21] Completed 45%
[12:08:48] Completed 46%
[12:10:17] Completed 47%
[12:11:49] Completed 48%
[12:13:24] Completed 49%
[12:14:59] Completed 50%
[12:16:35] Completed 51%
[12:18:10] Completed 52%
[12:19:45] Completed 53%
[12:21:09] Completed 54%
[12:22:36] Completed 55%
[12:24:12] Completed 56%
[12:25:48] Completed 57%
[12:27:24] Completed 58%
[12:29:00] Completed 59%
[12:30:27] Completed 60%
[12:31:55] Completed 61%
[12:33:22] Completed 62%
[12:34:49] Completed 63%
[12:36:16] Completed 64%
[12:37:41] Completed 65%
[12:39:07] Completed 66%
[12:40:33] Completed 67%
[12:42:00] Completed 68%
[12:43:27] Completed 69%
[12:45:02] Completed 70%
[12:46:38] Completed 71%
[12:48:07] Completed 72%
[12:49:37] Completed 73%
[12:51:07] Completed 74%
[12:52:34] Completed 75%
[12:54:02] Completed 76%
[12:55:29] Completed 77%
[12:56:59] Completed 78%
[12:58:35] Completed 79%
[13:00:06] Completed 80%
[13:01:36] Completed 81%
[13:03:09] Completed 82%
[13:04:45] Completed 83%
[13:06:14] Completed 84%
[13:07:40] Completed 85%
[13:09:06] Completed 86%
[13:10:31] Completed 87%
[13:11:56] Completed 88%
[13:13:21] Completed 89%
[13:14:46] Completed 90%
[13:16:12] Completed 91%
[13:17:37] Completed 92%
[13:19:02] Completed 93%
[13:20:32] Completed 94%
[13:22:02] Completed 95%
[13:23:32] Completed 96%
[13:24:58] Completed 97%
[13:26:26] Completed 98%
[13:27:53] Completed 99%
[13:29:20] Completed 100%
[13:30:20]
[13:30:20] Finished Work Unit:
[13:30:20] - Reading up to 34800 from "work/wudata_08.trr": Read 34800
[13:30:20] trr file hash check passed.
[13:30:20] - Reading up to 1130420 from "work/wudata_08.xtc": Read 1130420
[13:30:20] xtc file hash check passed.
[13:30:20] edr file hash check passed.
[13:30:20] logfile size: 124127
[13:30:20] Leaving Run
[13:30:23] - Writing 1290419 bytes of core data to disk...
[13:30:23] Done: 1289907 -> 1157587 (compressed to 89.7 percent)
[13:30:23] ... Done.
[13:30:23] - Shutting down core
[13:30:23]
[13:30:23] Folding@home Core Shutdown: FINISHED_UNIT
[13:30:27] CoreStatus = 64 (100)
[13:30:27] Sending work to server
[13:30:27] Project: 5016 (Run 4, Clone 58, Gen 101)
[13:30:27] - Read packet limit of 540015616... Set to 524286976.
[13:30:27] + Attempting to send results [October 9 13:30:27 UTC]
[13:30:46] + Results successfully sent
[13:30:46] Thank you for your contribution to Folding@Home.
[13:30:46] + Number of Units Completed: 8
[13:30:50] - Preparing to get new work unit...
[13:30:50] + Attempting to get work packet
[13:30:50] - Connecting to assignment server
[13:30:51] - Successful: assigned to (171.64.65.20).
[13:30:51] + News From Folding@Home: GPU folding beta
[13:30:51] Loaded queue successfully.
[13:30:52] + Closed connections
[13:30:52]
[13:30:52] + Processing work unit
[13:30:52] Core required: FahCore_11.exe
[13:30:52] Core found.
[13:30:52] Working on queue slot 09 [October 9 13:30:52 UTC]
[13:30:52] + Working ...
[13:30:52]
[13:30:52] *------------------------------*
[13:30:52] Folding@Home GPU Core - Beta
[13:30:52] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[13:30:52]
[13:30:52] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:30:52] Build host: amoeba
[13:30:52] Board Type: Nvidia
[13:30:52] Core :
[13:30:52] Preparing to commence simulation
[13:30:52] - Looking at optimizations...
[13:30:52] - Created dyn
[13:30:52] - Files status OK
[13:30:52] - Expanded 44059 -> 244433 (decompressed 554.7 percent)
[13:30:52] Called DecompressByteArray: compressed_data_size=44059 data_size=244433, decompressed_data_size=244433 diff=0
[13:30:52] - Digital signature verified
[13:30:52]
[13:30:52] Project: 5016 (Run 0, Clone 265, Gen 97)
[13:30:52]
[13:30:52] Assembly optimizations on if available.
[13:30:52] Entering M.D.
[13:30:59] Working on 576 p5005_supervillin_e1
[13:30:59] Client config found, loading data.
[13:30:59] Starting GUI Server
[13:32:24] Completed 1%
[13:33:58] Completed 2%
[13:35:34] Completed 3%
[13:37:10] Completed 4%
[13:38:45] Completed 5%
[13:40:20] Completed 6%
[13:41:55] Completed 7%
[13:43:30] Completed 8%
[13:45:05] Completed 9%
[13:46:41] Completed 10%
[13:48:16] Completed 11%
[13:49:51] Completed 12%
[13:51:26] Completed 13%
[13:52:54] Completed 14%
[13:54:18] Completed 15%
[13:55:42] Completed 16%
[13:57:06] Completed 17%
[13:58:29] Completed 18%
[13:59:53] Completed 19%
[14:01:16] Completed 20%
[14:02:37] Completed 21%
[14:04:01] Completed 22%
[14:05:24] Completed 23%
[14:06:48] Completed 24%
[14:08:13] Completed 25%
[14:09:35] Completed 26%
[14:10:57] Completed 27%
[14:12:20] Completed 28%
[14:13:42] Completed 29%
[14:15:04] Completed 30%
[14:16:26] Completed 31%
[14:17:49] Completed 32%
[14:19:11] Completed 33%
[14:20:33] Completed 34%
[14:21:56] Completed 35%
[14:23:20] Completed 36%
[14:24:43] Completed 37%
[14:26:08] Completed 38%
[14:27:36] Completed 39%
[14:29:04] Completed 40%
[14:30:31] Completed 41%
[14:31:58] Completed 42%
[14:33:24] Completed 43%
[14:34:51] Completed 44%
[14:36:19] Completed 45%
[14:37:46] Completed 46%
[14:39:13] Completed 47%
[14:40:38] Completed 48%
[14:42:03] Completed 49%
[14:43:31] Completed 50%
[14:44:58] Completed 51%
[14:46:23] Completed 52%
[14:47:48] Completed 53%
[14:49:13] Completed 54%
[14:50:38] Completed 55%
[14:52:06] Completed 56%
[14:53:31] Completed 57%
[14:55:03] Completed 58%
[14:56:36] Completed 59%
[14:58:09] Completed 60%
[14:59:41] Completed 61%
[15:01:14] Completed 62%
[15:02:46] Completed 63%
[15:04:18] Completed 64%
[15:05:50] Completed 65%
[15:07:23] Completed 66%
[15:08:52] Completed 67%
[15:10:17] Completed 68%
[15:11:43] Completed 69%
[15:13:10] Completed 70%
[15:14:37] Completed 71%
[15:16:05] Completed 72%
[15:17:32] Completed 73%
[15:19:02] Completed 74%
[15:20:35] Completed 75%
[15:22:07] Completed 76%
[15:23:39] Completed 77%
[15:25:11] Completed 78%
[15:26:44] Completed 79%
[15:28:14] Completed 80%
[15:29:39] Completed 81%
[15:31:04] Completed 82%
[15:32:30] Completed 83%
[15:33:56] Completed 84%
[15:35:22] Completed 85%
[15:35:44] + Working...
[15:36:49] Completed 86%
[15:38:15] Completed 87%
[15:39:43] Completed 88%
[15:41:15] Completed 89%
[15:42:47] Completed 90%
[15:44:19] Completed 91%
[15:45:51] Completed 92%
[15:47:23] Completed 93%
[15:48:56] Completed 94%
[15:50:27] Completed 95%
[15:51:54] Completed 96%
[15:53:20] Completed 97%
[15:54:47] Completed 98%
[15:56:14] Completed 99%
[15:57:44] Completed 100%
[15:58:44]
[15:58:44] Finished Work Unit:
[15:58:44] - Reading up to 34800 from "work/wudata_09.trr": Read 34800
[15:58:44] trr file hash check passed.
[15:58:44] - Reading up to 1126976 from "work/wudata_09.xtc": Read 1126976
[15:58:44] xtc file hash check passed.
[15:58:44] edr file hash check passed.
[15:58:44] logfile size: 126631
[15:58:44] Leaving Run
[15:58:49] - Writing 1289479 bytes of core data to disk...
[15:58:49] Done: 1288967 -> 1154138 (compressed to 89.5 percent)
[15:58:49] ... Done.
[15:58:49] - Shutting down core
[15:58:49]
[15:58:49] Folding@home Core Shutdown: FINISHED_UNIT
[15:58:52] CoreStatus = 64 (100)
[15:58:52] Sending work to server
[15:58:52] Project: 5016 (Run 0, Clone 265, Gen 97)
[15:58:52] - Read packet limit of 540015616... Set to 524286976.
[15:58:52] + Attempting to send results [October 9 15:58:52 UTC]
[15:59:11] + Results successfully sent
[15:59:11] Thank you for your contribution to Folding@Home.
[15:59:11] + Number of Units Completed: 9
[15:59:15] - Preparing to get new work unit...
[15:59:15] + Attempting to get work packet
[15:59:15] - Connecting to assignment server
[15:59:15] - Successful: assigned to (171.64.65.106).
[15:59:15] + News From Folding@Home: GPU folding beta
[15:59:15] Loaded queue successfully.
[15:59:16] + Could not connect to Work Server
[15:59:16] - Attempt #1 to get work failed, and no other work to do.
[15:59:30] + Attempting to get work packet
[15:59:30] - Connecting to assignment server
[15:59:30] - Successful: assigned to (171.64.65.106).
[15:59:30] + News From Folding@Home: GPU folding beta
[15:59:30] Loaded queue successfully.
[15:59:31] + Could not connect to Work Server
[15:59:31] - Attempt #2 to get work failed, and no other work to do.
[15:59:47] + Attempting to get work packet
[15:59:47] - Connecting to assignment server
[15:59:48] - Successful: assigned to (171.64.65.106).
[15:59:48] + News From Folding@Home: GPU folding beta
[15:59:48] Loaded queue successfully.
[15:59:48] + Could not connect to Work Server
[15:59:48] - Attempt #3 to get work failed, and no other work to do.
[16:00:23] + Attempting to get work packet
[16:00:23] - Connecting to assignment server
[16:00:23] - Successful: assigned to (171.64.65.106).
[16:00:23] + News From Folding@Home: GPU folding beta
[16:00:23] Loaded queue successfully.
[16:00:25] + Closed connections
[16:00:25]
[16:00:25] + Processing work unit
[16:00:25] Core required: FahCore_11.exe
[16:00:25] Core found.
[16:00:25] Working on queue slot 00 [October 9 16:00:25 UTC]
[16:00:25] + Working ...
[16:00:25]
[16:00:25] *------------------------------*
[16:00:25] Folding@Home GPU Core - Beta
[16:00:25] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[16:00:25]
[16:00:25] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:00:25] Build host: amoeba
[16:00:25] Board Type: Nvidia
[16:00:25] Core :
[16:00:25] Preparing to commence simulation
[16:00:25] - Looking at optimizations...
[16:00:25] - Created dyn
[16:00:25] - Files status OK
[16:00:25] - Expanded 45349 -> 246249 (decompressed 543.0 percent)
[16:00:25] Called DecompressByteArray: compressed_data_size=45349 data_size=246249, decompressed_data_size=246249 diff=0
[16:00:25] - Digital signature verified
[16:00:25]
[16:00:25] Project: 5506 (Run 5, Clone 732, Gen 32)
[16:00:25]
[16:00:25] Assembly optimizations on if available.
[16:00:25] Entering M.D.
[16:00:31] Working on p5506_supervillin_e1
[16:00:32] Client config found, loading data.
[16:00:32] Starting GUI Server
[16:01:58] Completed 1%
[16:03:29] Completed 2%
[16:05:02] Completed 3%
[16:06:36] Completed 4%
[16:08:09] Completed 5%
[16:09:42] Completed 6%
[16:11:14] Completed 7%
[16:12:43] Completed 8%
[16:14:10] Completed 9%
[16:15:35] Completed 10%
[16:17:04] Completed 11%
[16:18:31] Completed 12%
[16:19:59] Completed 13%
[16:21:26] Completed 14%
[16:22:52] Completed 15%
[16:24:20] Completed 16%
[16:25:48] Completed 17%
[16:27:20] Completed 18%
[16:28:53] Completed 19%
[16:30:26] Completed 20%
[16:31:59] Completed 21%
[16:33:32] Completed 22%
[16:35:05] Completed 23%
[16:36:38] Completed 24%
[16:38:11] Completed 25%
[16:39:40] Completed 26%
[16:41:07] Completed 27%
[16:42:35] Completed 28%
[16:44:02] Completed 29%
[16:45:30] Completed 30%
[16:46:59] Completed 31%
[16:48:31] Completed 32%
[16:50:04] Completed 33%
[16:51:37] Completed 34%
[16:53:10] Completed 35%
[16:54:43] Completed 36%
[16:56:16] Completed 37%
[16:57:49] Completed 38%
[16:59:22] Completed 39%
[17:00:55] Completed 40%
[17:02:27] Completed 41%
[17:04:00] Completed 42%
[17:05:33] Completed 43%
[17:07:07] Completed 44%
[17:08:40] Completed 45%
[17:10:11] Completed 46%
[17:11:38] Completed 47%
[17:13:06] Completed 48%
[17:14:33] Completed 49%
[17:16:01] Completed 50%
[17:17:28] Completed 51%
[17:18:56] Completed 52%
[17:20:23] Completed 53%
[17:21:51] Completed 54%
[17:23:18] Completed 55%
[17:24:45] Completed 56%
[17:26:13] Completed 57%
[17:27:41] Completed 58%
[17:29:08] Completed 59%
[17:30:36] Completed 60%
[17:32:03] Completed 61%
[17:33:30] Completed 62%
[17:34:58] Completed 63%
[17:36:26] Completed 64%
[17:37:54] Completed 65%
[17:39:21] Completed 66%
[17:40:48] Completed 67%
[17:42:16] Completed 68%
[17:43:43] Completed 69%
[17:45:11] Completed 70%
[17:46:39] Completed 71%
[17:48:06] Completed 72%
[17:49:34] Completed 73%
[17:51:01] Completed 74%
[17:52:28] Completed 75%
[17:53:55] Completed 76%
[17:55:23] Completed 77%
[17:56:51] Completed 78%
[17:58:19] Completed 79%
[17:59:46] Completed 80%
[18:01:13] Completed 81%
[18:02:41] Completed 82%
[18:04:08] Completed 83%
[18:05:36] Completed 84%
[18:07:03] Completed 85%
[18:08:31] Completed 86%
[18:09:58] Completed 87%
[18:11:26] Completed 88%
[18:12:53] Completed 89%
[18:14:20] Completed 90%
[18:15:48] Completed 91%
[18:17:16] Completed 92%
[18:18:43] Completed 93%
[18:20:11] Completed 94%
[18:21:38] Completed 95%
[18:23:05] Completed 96%
[18:24:33] Completed 97%
[18:26:00] Completed 98%
[18:27:28] Completed 99%
[18:28:55] Completed 100%
[18:29:55]
[18:29:55] Finished Work Unit:
[18:29:55] - Reading up to 34800 from "work/wudata_00.trr": Read 34800
[18:29:55] trr file hash check passed.
[18:29:55] - Reading up to 1129264 from "work/wudata_00.xtc": Read 1129264
[18:29:55] xtc file hash check passed.
[18:29:55] edr file hash check passed.
[18:29:55] logfile size: 76739
[18:29:55] Leaving Run
[18:30:00] - Writing 1241875 bytes of core data to disk...
[18:30:00] ... Done.
[18:30:00] - Shutting down core
[18:30:00]
[18:30:00] Folding@home Core Shutdown: FINISHED_UNIT
[18:30:03] CoreStatus = 64 (100)
[18:30:03] Sending work to server
[18:30:03] Project: 5506 (Run 5, Clone 732, Gen 32)
[18:30:03] - Read packet limit of 540015616... Set to 524286976.
[18:30:03] + Attempting to send results [October 9 18:30:03 UTC]
[18:30:23] + Results successfully sent
[18:30:23] Thank you for your contribution to Folding@Home.
[18:30:23] + Number of Units Completed: 10
[18:30:27] - Preparing to get new work unit...
[18:30:27] + Attempting to get work packet
Cool, Ya i can up the shaders even farther. I'm not sure how high of a load my card can handle. so right now I'm runnin it at 650 Mhz core, usually game around 740 Mhz os sometimes less.. but thats not 12 hours or more straight like I am with this. so I'll turn it up later if I see this runs great. I can always load the shaders though. I know the limit there for this card.. it's aanything over 1550 it starts strugglin.
So how long Do GPU's generally last if properly cooled. I mean this is a great card. I'd hate to kill it by running 24/7 folding.. If I'm runnin that on this card at like 62c max like it's at now.. Would that be ok. Maybe I'll just do 12/7 instead..
What I really wanna do is use my old Q6700 and build a Folding rig. so I don't have to worry about all my good new stuff in this rig.. would my spare 250w PSU be enough to handle a Q6700 and a 8800GS. not a GT.. or no. that might not be enough power.. I can get a dsl3 gigabyte board and a Antec Noepower 430w PSU all for $109 as a bundle. maybe I should do that. throw my Q6700 in it. my spare 1GB of ram. although might need 2 for vista. then somehow get a 8800/9600.. Maybe I can find somewhere to donate one.. since it will be a 24/7 folding rig. It's a good cause and not me begging for something. there'd be results of my PPD. lol. Just a thought. I'll look into maybe getting it built. we'll see.
either way, thanks for helping me get this all going.
for folding you can leave core and ram at stock, shader is the only thing that matters.. and it doesn't produce heat like core does..
to find your max folding shader.
1. start the client and fahmon.
2. up your shaders 50mhz at a time and watch the client in fahmon for 5 minutes for errors (keep refreshing fahmon).
3. when you you try a 50mhz shader hop and the client errors within 5 minutes, back it down 100mhz. this is your folding shader oc. core and ram stay stock.
your gaming oc can be different. whatver. but that's what your folding oc needs to be. it'll put the least stress on your card and maximize ppd.
I don't know of any GPUs having a shortened life due to folding, as long as the temps are in check. I've never had a CPU/GPU fail from folding. I've popped a couple caps in some PSUs and burned out some fans but that's about the extent of the damage on my end :p:
250W PSU won't handle the Q6700 and 8800GS. The 430W could though more than likely.
A really strong 250w psu might handle a non overclocked Q6700 and 8800gs but I doubt it could handle folding on both maybe 1 but not both and you would risk EUE's due to starving the computer of power under heavy load. As SparkyJJO said I would go to at least a 430w psu if not bigger. I used to fold on my Shuttle with its 250w psu on a overclocked Q6600 but no video card and the Shuttle psu's are noted for being very robust they are server psu. I am having problems trying to fold on both a E8400 and a 8800gt in a shuttle with a 300w psu without any overclocking I can fold on one or the other but not both I am waiting on a 110w supplemental psu to help power the card which should be here sometime this week.
I would say anything that utilizes hw to 100% all the time will have a negative impact on it's lifespan. Everything has an MTBF. and this is always related to the conditions it's working under.
But as far as killing hw that wasn't about to die doing something else then folding ( let's say gaming for instance :) ). naw I don't think so. Or I should say, yeah sure it will but the chanche of you being able to tell the difrence between it failing due to prolongated 100% use through folding in comparison with it dying of natural causes are slim to none. Every gpu will die eventually. It's like a car, every car has a service period, after which you need to bring it in for checks on whatever, if you drive the car on it's limits all the time, you could shorten that timespan, but at no time it should make the car stop running completely ( as you're still only using the product for it's intended purposes, driving ).
The car analogy doesn't really hold up, as in a car you have components you can exchange which will extend the MTBF. Maybe adding some caps to smoothen out the voltages ( and knowing that folding seems to brings along very fast current switching, faster then for instance normal gaming that could very well help. )
Short answer, don't have any... sorry :)
To put it in short terms - yes it will reduce lifespan, but odds are not by enough to worry about. Like overclocking a CPU can reduce lifespan by a couple years but when the CPU lasts for 10+ years already anyway I hope you aren't still using the same CPU that long down the road. Similar with a graphics card I'm sure. Of course, those with lifetime warranties on their cards should have no issues at all :D
That's a good short one :)
Sparky here is also a master in replacing caps, maybe it would be a nice test ( you do have two identical 9600gso's right? ) to maybe cap mod one and leave the other stock, and watch if anything will happen to either one..
I'm more leaning towards believing that with f@h, the gpu itself isn't going to die quickest but the other components on the card ( eg the power circuitry ).
Well My point of view is different, If I didn't use the component it could die in 3 years , which is in EU out of warranty but F@H makes sure it will die sooner = dead card or anything = RMA still in the 2 years of warranty = New Card for me ! :hehe:
Lol that one is very true to!
Would be nice if you had, it's always fun to be able to compare data with eachother and look at what the discrependancies are caused by, but I think this one might even be to clear from the start to be really fun.
I noticed one fascinating thing guys ... When I wake up I power my PC on with my feet [ must be feet ! ] log in start the SMP and GPU client and go to work , I usually leave my doors open and when I return it's freaking hot in that particular room, so I heat it until I go to bed and in the morning it's still warm ... I don't need an A/C or the central heating ! The GTX is simply amazing, I need another one for a couple more degrees.
I do something for the ill and still spare a lot because I'm not using the heating , and the electricity is freaking cheap here, 1$ = 3kW
Kondik, sell that gtx! Get two 9800gx2s. You'll be bumping out 22k AND you can heat your entire house for nothing! :up: ;)
Nyeh , never, I love the GTX 200 series, I'm amazed by them ... raw power, it chews and spits out single GPU card like a V8 Chevy sucks and eats european trolleys [ you call it cars ?! ] ... I'm amazed by big things , faliure or no, the ATI simply doesn't lick with me ... and what doesn't lick with me licks agains me :hehe:
As for the GX2 , nuuh ... two old sandwitch cards, Because I don;t care abotu the price I'm fine with it even through the R4870 is better bang for bucks but it sucks at folding, and folding its what the PC does when the lord is not at home :hehe:
And for gaming ... I have 60 FPS at 1680x1050 in everything [ cept Crysis and MS X ] and I use Vsync so if I have 60 with GTX280 or 60 with 4870X2 or 4870 does it count ? Nyeh ...
I thought you meant you had an 8800gtx still! :p:
Nah Gave it away , GAVE it I repeat GAVE it for free .. I'm such a douchebag ...
