I was just about to order myself a R3E EK block when I noticed that it doesn't even cover the mofsets properly... bit of a silly design isn't it?
EDIT: Sorry I think I mean VRMs, I'm very tired atm so don't take the p***. lol
yep normally you cool the mosfets....
Judging by this picture it isn't doing that then?
http://i696.photobucket.com/albums/v...ek/ekfull5.jpg
LOL, westokyo, on June 14th I told you to look at the pins under the cpu because I thought for sure you had bent cpu socket pins. I have a electronics component magnifying glass i use just for this procedure. I'm impressed you bent them back yourself, nice work man :up: glad you got her fixed....
http://www.xtremesystems.org/forums/...&postcount=881
You'll be fine IMO. :up:
My PSU also has 1x8pin + 1x4pin. I plugged 8pin up and 4pin down leaving bottom half empty. No problems so far. Not even using molexes.
Do you really think EK would make such a mistake?
Those are not MOSFETs, those are solid chokes AFAIK. They don't need to be cooled. Heat sink is over them cause it needs to be relatively large to cool MOSFETS.
Here is the picture:
I did my LN2 runs with just 1x 8-pin CPU power and it worked fine.... If you have an extra 4-pin CPU power connector it wouldn't hurt to plug it in. :p:
That WB is made for the motherboard and cools all of the chipsets. :up:
mine are just warm, never get hot not even under extreme load, so I don't see the point in cooling them.
Is everybody turning the QPI Line Load Calibration on or off (the one that requires using the jumper on the mb)?
most ppl who run over 4.0 use 100% yep
Another question from a relative new-comer to this board ... I want to get some new memory and I am looking at some of the RAM from Mushkin. What speed should I get for this board? I really like Mushkin and just need to know what would be the best to get for this board for a 24/7 stable 4.4GHz overclock?
:welcome:
Check this out: Asus Rampage III Extreme - results thread
You can find a lot of my BIOS settings. As you see in my sig I'm using Mushkin memory and that is 998691. For 24/7 you can use 1680 mem (210x8) if you want 4410 core, or for summer days 1600/2000 mem (200x8/x10) if you need to drop to 4200 core.
BTW, is it you looking at Aurora Borealis on your avatar?
Hey donmarkoni~ I have been to i4memory site before ... great site!! Haven't been there in a long time though. I remember eva2000 from DFI days ... :up:
I have looked at this memory from Mushkin: Mushkin Enhanced Redline
That product number is 998805 ... where did you get yours?
And no, that is not me ... but I have been known to stand out in the cold and look at the Northern Lights for long periods of time! ;)
donmarkoni ~ I see that maybe Mushkin have re-released that Enhanced Redline as later product number (998805) ... I have ordered that stuff from the 'Egg.
Looks like same stuff as yours ... :up:
Just thought I'd pop some extra pictures on here,
re-routed the water, and changed some cable locations, gave it a full clean inside.
still unsure about the fans, thinking maybe some acryan red glow fans??
Great job there Kortas
looks great m8 well done
The 0.602 bios fixed my 4.2 Ghz BSODs :)
http://img197.imageshack.us/img197/2905/4200.png
Thats nice and stable now, except for my freaky core 1, but its nowhere near that bad when playing games.
Pics again:
http://img9.imageshack.us/img9/8553/dsc00573vs.jpg
http://img193.imageshack.us/img193/9315/dsc00571sa.jpg
http://img688.imageshack.us/img688/1850/dsc00580h.jpg
http://img215.imageshack.us/img215/7448/dsc00593xu.jpg
My wonderful SE K850i..... what a failure camera it is :rofl:
Just got my R3E / 980X , but under XP ( 32bit i think ) , i cant change the multiplier with the Evo program in windows XP, is that known or? bclock changing does work.
Quick question, I am going to find my modest 24/7 oc here soon and want to know what would be best, as in most stable and safe. I am looking at 4ghz 24/7 and wondering should I work at 19x210, 20x200, 21x190 or should I just do something not so high for 24/7. Any ideas what would work best as a stable gaming platform? Thanks
