OLDTIMER: HT link is impressive! Can u test winrar bench with this setings?
Dave the one thing that seemed to help with the higher HTT was to keep the HTL (HT link) and NB speed matched. Maybe I just got lucky hitting the settings the chips wanted but when I tried to boot with high HTT when the HTL was running at a lower speed than the NB it wouldn't boot. When I matched the speed it booted then when in windows turboV could take the HTT on up from there. This method worked on two different chips (thubans). I don't know if bios 801 is better than 905 for high HTT or not as I didn't try high HTT on 905?
The CHIVF is off the bench now so I can't run that bench test right now but I have a CB-10 and CB-11.5 + other bench tests @High HTT I can post up if you want?
:):rofl::rofl::rofl::ROTF::rofl::ROTF::yepp:
I may need to run sets of three tests at the same settings then average those three results to get a better idea why the score is so different when comparing NB/memory clocks? In my SS’s CB-10 score higher at a lower NB/relaxed memory timings but CB-11.5 scores higher with the higher NB/tighter memory timings?
http://i262.photobucket.com/albums/i...faultvolts.png
nice, nice, NB clock too impressive!
From looking at your SS's OT, I think you meant keeping the HTLink and IMC matched... :p: :shrug:
I've been an advocate of that since the 9500's, at least to me, it always seemed to help on the older chips.
I actually stuck with that pattern when I first got my 1055, but the Thubans IMC was so much stronger, that I thought maybe the HTLink was getting too high so I dropped it to 9x and left the IMC @ 10x...
Either way, it didn't help, and for some reason I'm stuck with a max HTRef ~300.... :(
I hate to sound like a conspiracy theorist, but I'm wondering if maybe AMD didn't intentionally cripple HTRef clocks on the 1055's just so they couldn't smoke the 1090T's..... :D
BTW: Kennedy WAS shot from the Grassy Knoll.... :rofl:
:nuts:
Yeah, I realized later what I did (typed that I matched the HTT rather than the CPU/NB).:yepp: I didn't make it back to fix it though. I didn't figure many people were reading what I was posting up anyway.
If I had a 1055 I'd test your theory about the HTRef clocks?
Behind the fence at the grassy knoll maybe?:shrug:
Hey gang, I think I hear crickets here :)
I finally finished my refresh build:
http://www.xtremesystems.org/forums/...d.php?t=257170
Hopefully I'll soon find time to push my 1055t and 5850 in their new home. Maybe this thread will pick up again in the fall.
sweet rig grinder :)
i thought about this thread a few times but never bumped it cause its been pretty hot here lately = not best possible OC :p:
Thanks cd. I expect you are right, fall and winter are definitely more oc friendly for those of us that only have access to ambient!
I can see wanting to set up my external rad with longer tubing in order to hang it out the window this winter. Easier than lifting the whole system up there like I did last year :cool:
You know I will be putting my Garage Loop back in play this winter for sure :D
i sort of expected the masters of OC to be bang on the C3 revision, you know K|ngp|N, macci, SF3D and Massman, but i cant seem to find anything,
roll on the condensation charged, lol
It started to be an issue last year, but my insulation did the trick. :p:
For fun guys, Im interesting, how it is doing on your side and if some oldschool guys are still here and fine :-) Happy New Year :)
https://i.imgur.com/gjyeWMZ.jpeg
Happy new year Flanker.
Unfortunately this is a dead land that nobody is visiting anymore.
So sad considering the place this once was.
At least, you are here :)
Old school is the best school ;-)
Hey Dudes! Flank3r!! how have you been brother?? I have been running ryzen 1600 system since it came out. just ordered a 9700x, b650 tomahawk, 32gb 6000mhz c36, pcie5 m.2 :)
I have some 1090T's here that Simon sent me back in the day. results are scattered on here, but they were excellent overclockers if anyone is still overclocking am3?? also have supertalent 2200mhz c8 sticks, some of the best ddr3 there was.
