Looking good dude. Can't wait to play with the head you make
Kayl
What is your opinion on operating 24/7 and operating 12hrs/day ie switch off and on? There are a lot of different opinions and success on mounting, these seem to depend upon evap mounting as well, ie how well they trap cold. Can phase really be used relibly?
Like here prob on condensation http://www.xtremesystems.org/forums/...ad.php?t=98201l
and evap mounts like here
http://www.xtremesystems.org/forums/...d.php?t=103256 etc.
What type of mount do u use for your units? Are you putting anymore development into those? Will those be suitable for dual cpu board?
It seems that the biggest prob is to ensure air tight seal around CPU socket, with comments being posted that more difficult on LGA775. Have you got a preferred method or is that MOB dependent and / or try it and see?
i have the same question also...
hope it serves ya well, is that a unit ya making or one graymole did?Quote:
Originally Posted by Pete
Originally Posted by gazzoom
if your gonna use 24/7 its very important that you make the socket airtight. any little air gaps mush be filled either grease or enclosed foam. remember any air gaps the cold is gonna draw the moisture out of that air and form condensation.
i currently fill my socket with dielectric grease and thats it.
FOr the 775 socket its very important that you dont let the cooler reach say -45c or colder before booting as the 775 socket is very tight and not much room for insulation. If you load the board you have no issues as the caps around the socket get really hot and act like a heat plate.
here ya can see eva2000 using a system i made on an AMD fx60 system
he runs his up to 24hrs sometime no issues.
http://www.xtremesystems.org/forums/...d.php?t=102470
if the mount plate has hose for the Xeon so no reason why couldnt use dual heads. FOr cascades and auto cascades its important again you dont let the system get too cold before booting, ie -45c i would boot mine at once at -100c the mobo should be warm and stop the creep of the insulation
this is how i insulate my mobo, air tight so no condensation.;)
http://img225.imageshack.us/img225/9530/18ax.th.jpg
http://img225.imageshack.us/img225/7006/21tl1.th.jpg
http://img122.imageshack.us/img122/5...74438hn.th.jpg
http://img132.imageshack.us/img132/1243/cpu1xh.th.jpg
KAYL! what's going on with those caps at the top of the image?!Quote:
Originally Posted by kayl
Gonna need your help insulating my new mobo when I get it :D
Also I am wanting to acoustically insulate the bottom chamber of the V2000 as much as possible so if you can recommend some REMOVABLE foam (static/suction instead of adhesive) That would be awesome :) Otherwise I'll use magnetic tape... damn aluminium is non-magnetizable though.
Originally Posted by Nephilim
The 775 sockets are real tight, ie the caps are very close to the socket. The caps with those little dents in are where I have screwed the enclose exact square with mobo and the enclosure rests against it. I now just off set the evap enclose a small amount so it doesn’t come into contact with the caps any more. The hole of the CPu does make contact with the evap head though. In my next revision evap head enclosure ill be fixing that and adding the AMD2 holes as well
Sorry I cant recommend REMOVABLE foam, when ya come around gonna have to show me what ya mean and see what we can come up with. Yeah it is a pitty magnets don’t stick to aluminium.:mad:
i noticed this on sunday and ordered a new supply.
high current draw on my 500w psu that connector couldnt handle it i guess. and only with a pci gpu as well no sli cards or crossfire.
http://img391.imageshack.us/img391/3...7966jf6.th.jpg
so i replaced it with this
http://img195.imageshack.us/img195/6...7963pw7.th.jpg
http://img195.imageshack.us/img195/9...7964lj2.th.jpg
got the gfroster working today.
http://img182.imageshack.us/img182/8...7980ke4.th.jpg
http://img195.imageshack.us/img195/8...7981si0.th.jpg
wiring
http://img391.imageshack.us/img391/2...7975rq6.th.jpg
http://img195.imageshack.us/img195/1...7972xj9.th.jpg
OMG kayl maybe you should get thermaltakes newest invention before you toast that one also http://www.thermaltake.com/product/P...0130/w0130.asp
Wow Kayl iam really impressed. The system looks REALLY clean. Guess you gave up on the duct tape and wood :D
Originally Posted by JSU
thanxs man, aerotape is alot better than what i use to use:toast:
got some new compressors to ty today.
Theres a 1/4 hp same as in last build and a 1/3Hp r404/507 LBP compressor to try @ 12cc/rev. Strange the 1/4Hp has 14.1cc/rev but is physically smaller. Its just a r12 compressor though.
http://img96.imageshack.us/img96/683...8142nb5.th.jpg
dual head unit, im prity sure its gonna be a nb/cpu ;)
http://img174.imageshack.us/img174/8...8638yi1.th.jpg
http://img264.imageshack.us/img264/6...8646mp4.th.jpg
http://img174.imageshack.us/img174/5...8647km8.th.jpg
http://img115.imageshack.us/img115/3...8649aa7.th.jpg
r290/r507/r410a blend on 1/4hp kirby
first turn on for day takes 3mins to reach -42c settling at -44c ilde until loaded.
aroud -40c after that. load 2001 -37 -36c.
dual prime for 1 hour -33c.
http://img68.imageshack.us/img68/231...8704gq8.th.jpg
http://img68.imageshack.us/img68/503/dsc08703dw5.th.jpg
Nice looking unit ;)
thanks
thanxs little devil
well finally finished this unit, i justed ended up taking out the gfroster Xe1.2 controller as it doenst work, still waiting on parts to fix the broken controller.
start up issues (trips) and character display errors.
So i just installed a basic temp probe that reads to -50c.
1/4Hp kirby with r290/R507 I glued some sound proofing inslation to the enclosure to quieten it up a tad more.
http://img85.imageshack.us/img85/3867/1rl1.th.jpg
http://img68.imageshack.us/img68/3096/12vi9.th.jpg
http://img85.imageshack.us/img85/2169/11ay6.th.jpg
http://img118.imageshack.us/img118/6529/14ul7.th.jpg
http://img160.imageshack.us/img160/9...4096uo7.th.jpg
http://img160.imageshack.us/img160/9...5mhzhp2.th.jpg
green SS 3dmark05 -42c average -39c max
4050mhz 1.7bios 1.61 real, -37c load dual prime -44c idle.
http://img431.imageshack.us/img431/9...8757gg1.th.jpg
http://img232.imageshack.us/img232/9...8759sb0.th.jpg
http://img157.imageshack.us/img157/4...4050ns4.th.jpg
http://img219.imageshack.us/img219/4...1secyo5.th.jpg
Kayl it time for you to buy a box & pan brake and a metal jump shear. make your own cases for the cost of the metal, about 20.00 dollars a little higher if alluminium,
Yo Kayl where you get all those damn cube condensers? They're like a rarity in the USA, and i've got 4 in my workshop and havent seen another for sale in weeks.
it would be fun but alot of work wdrzal. I dont mind getting cases made, my new case is gonna have studs for compressor, studs for gfroster controller and also pems for the sinde pannels and compressor base to screw unit together. no more tapping holes :stick: .Quote:
Originally Posted by wdrzal
would you belive thes are are a few years old. i got them back when chilly first got them, i also bough a bunch off drewminister ages back.Quote:
Originally Posted by n00b 0f l337
I still got 2 left :toast:
working on the dual head project hoping to finish next :toast:
first take off the nb, seems that one corner of my core is missing heatpaste.
Nb suction line finished.
http://img159.imageshack.us/img159/439/nbuy0.th.jpg
http://img423.imageshack.us/img423/8...losebi3.th.jpg
http://img149.imageshack.us/img149/5...lineeh6.th.jpg
http://img149.imageshack.us/img149/8...atedme6.th.jpg
assembled just got to do the last insulating on mobo before i can bench tonight.
http://img197.imageshack.us/img197/9526/1mq9.th.jpg
http://img153.imageshack.us/img153/245/2ee0.th.jpg
http://img153.imageshack.us/img153/4055/3zd4.th.jpg
http://img153.imageshack.us/img153/5481/4hn8.th.jpg
http://img302.imageshack.us/img302/4...8847ka7.th.jpg
Final check to make sure die is centre then insulate and bench.
-35c cpu head and -20c nb for 3dmark o1 bench.
290/507/410a
i didnt have a back plate on the cpu head, im getting some more made soon.
cpu was unstable for dual prime.
but with a 8x i still couldnt get past 457fsb, i think mobo doesnt like this ram cpu combo?
http://img175.imageshack.us/img175/320/1ve7.th.jpg
http://img175.imageshack.us/img175/7738/2wv7.th.jpg
http://img444.imageshack.us/img444/2385/3yj8.th.jpg
nice work kayl =D
thanxs gkiing ;)
idle -40c cpu and -15c NB.
funny for 3dmark05 NB sits around -25c cpu -38c
spi the NB is a little cooler again cant remember
orthos loads the cooler tones more and temps even out at around -32c cpu and NB -34c.
and all test on 3dmark 01 -35c cpu and -20c NB
seems really heavy load the NB gets alot cooler:toast:
after a few hours the NB idle gets to -25 but it takes a hour or so
http://img167.imageshack.us/img167/4...8932hg6.th.jpg
http://img149.imageshack.us/img149/8...8934hz3.th.jpg
http://img303.imageshack.us/img303/4...8945ug2.th.jpg
http://img371.imageshack.us/img371/9...8943xk4.th.jpg
http://img461.imageshack.us/img461/9...8946st8.th.jpg
great :)
