Hehe, the original design he had for this had a 120mm in front and people suggested it get changed :D
If you are watercooling the machine, the only source of heat in there will be the hard drives and possibly the chipset. I doubt even a pair of 120mm fans is inadequate for that, and this already does better :D
Very true, I also had suggested this gets turned 90 degrees to allow people to stuff extra cabling in the cavity, your idea would work better than mine !
I have a RAID0 stripe of two 500GB drives ? Mind telling me where it is ? because I never knew I had one.
Except that a large storage machine is kept up all the time to allow all the users on the network to access it. Which takes less power, a small dedicated NAS box, or an overclocked, triple SLI, watercooled, machine with a dozen fans and lights and such ? My point was that you could now shut off the 180Watt power hog of a gaming machine, and leave just the 35Watt NAS up and running.
