The score I saw was 39.750 and I just looked again. His math is fine, I get the same 17.8% increase in spi time.
I'm just not getting my hopes up, I'd love B2 to be much better, but if I don't get my hopes up then there isn't the chance of me crashing to the ground in case my hopes were in vain.
It was set to dual channel in the bios, CPU-Z seems to be reporting it wrong (as it is the HT link as well).
Then let me tell you in advance, it will :DQuote:
Perkam
Yep, I finally saw it. I was just looking at the screen shots. Not totally sure he's actually running dual channel as cpu-z show single. It could be that cpu-z needs an upgrade for Barcelona. The difference in times may be just fluctuation in the spi test. We'll find out soon I suppose.
3.88 speeup on cinebench.. is it good enough compare to c2q?
That's 108% scaling. Its incorrect because you're not working out percentages here, but percentage change. The formula is as follows
Maths:
http://www.gcseguide.co.uk/percentages.htm
http://mathforum.org/library/drmath/view/63055.html
New - Old / Old x 100 = Percentage Change
For single channel it's 39.750s for dual channel its what you said: http://www.xtremesystems.org/forums/...22&postcount=1Quote:
Originally Posted by MR_SmartAss
For simplicity, we swap the top figures around or it would become a minus change this time because of importance is decreasing values, not increasing (which is practically untrue i.e. to us 7 sec dropped is not 7 disadvantage but 7 advantage). The base always stays the same as its "new" relative to "old". What matters is the change.
38.968s - 32.672s (change) / 38.968s (relative to old) x 100 (percentage) = 16.157%
If you use that first general formula it would be -16.157% change which is perfectly true from the original time. But to us that's a +16.157% performance gain.
Now we can use a simple percentage formula:
16.157 / 20 x 100 = 80.8% scaling.
It is unreachable for С2Q. The main reason is Core2 shared cache.
This is also one of the main reasons for excellent single-threaded performance of Core2 cpu's, which -in turn - is unreachable for comparatively clocked K10, regardless of stepping.
The net result is that C2Q is excellent CPU with very high SMP performance. It's
"untrue" nature does not hurt its performance to any noticeable extent. No reason for Intel to hurry up with "native" solution -at least, not from performance stand point.
FELIX kindly pointed out to me about K10's memory controller:)
According to AMD's document, BIOS and Kernel Developer’s Guide,
K10's has 2 DCTs(DCT: Dram ConTroller!?), and it can work different two mode, i.e.,
(1) to behave as a single dual-channel DCT; this is called ganged mode;
(2) to behave as two single-channel DCTs; this is called unganged mode.
My understanding is:
Ganged mode reads or writes with 2 DCTs at the same time.
Unganged mode also can reads with 1 DCT and writes with another 1 DCT at the same time,
if the system requests as so.
Unganged mode is more flexible than ganged mode,
and ganged mode is equal to "conventional" dual channel mode.
Then, I noticed the BIOS setting, "Unganged Mode support".
http://222.151.153.254/c-board/file/...S_unganged.jpg
So I tried SuperPI 4M in 3 case as below, and results:
with 1 memory module: 3m27.141s
with 2 memory modules, ganged mode: 3m24.438s
with 2 memory modules, unganged mode: 3m22.953s
and we can see CPU-Z and FELIX's test program properly detects
"conventional" dual channel mode:up:
Default BIOS setting is "Unganged Mode = Enabled", and at least,
unganged mode looks faster than ganged mode for SuperPI.
http://222.151.153.254/c-board/file/...m_unganged.png
http://222.151.153.254/c-board/file/...mem_ganged.png
And these are latecy test results with Everest Ultimate v4.20:
at 2.0G=200x10: 76.0ns
at 2.2G=220x10: 69.0ns
at 2.4G=240x10: 63.4ns
The latest Everest detects Barcelona properly:)
http://222.151.153.254/c-board/file/...10_latency.png
Thanks to everyone for many comments and suggestions:)
...but don't be bullying poor small AMD, hipro5:D (yeah, just kidding;) )
Please calm down about scaling for SuperPI time...
I'll try it again, with K8 Opteron 2212 and K10, with same OS:yepp:
We are all calm. Somebody just needs to learn their math lessons, thats all :)
It is much more interesting to see multi-threaded scores of dual-cpu K10 system,
as it is there AMD is going to compete and win against Intel -not on single-socket platform.
ny chance of a pifast bench? That was always more favourable to AMD than SuperPi and also seemed a bit more relevant to general useage.
Regards
Andy
Wow, not bad actually. I get 32sec @ 2.9ghz on opty 165. So that means a 3ghz barc. should do around 25 sec, not bad at all.
Interesting though, how a 6000+ A64 is par with a C2d 6600 model in real time performance but in SuperPi the 6600 smokes it. But in this case a 2.4ghz Phenom should smoke the hell out of the 6600 out the water in real time applications.
how about kribibench?
http://www.xtremesystems.org/forums/...89#post2476489
Great results kyosen. Keep 'em coming. :)
can you do same comparison on the memory mode with 64bit cinebench
These are quite promising, Thanks aswell Kyosen
