Where is my good old armor case hope u like it.
@ Solu: top of your case is absolutely beautiful, good job ;)
Thx Logos4 :up:
Hello to everybody.
Here are some pictures of my watercooling setups :cool:
There few of them and another one is coming soon.
1. Chieftec case.
http://img78.imageshack.us/img78/3083/wcstareph5.jpg
The setup was DFI LanParty nF4 with X2, 1GB ram and X1800GTO@XTX
2. TT Matrix case
TT Matrix case, (not so good for WC/LC setups, too small)
http://img103.imageshack.us/img103/671/wcrew3ef4.jpg
http://img296.imageshack.us/img296/521/dscf0405wk6.jpg
3. CM 690
It's last revision before changing PC
http://img146.imageshack.us/img146/4093/dscf1291rp5.jpg
http://img146.imageshack.us/img146/7126/dscf1298ft3.jpg
http://img146.imageshack.us/img146/3859/dscf1297sa6.jpg
http://img146.imageshack.us/img146/8586/dscf1269mo7.jpg
http://img146.imageshack.us/img146/8716/dscf1300ei0.jpg
4. BETA CM Stacker case
There was a change in case and in PC.
C2d e6300@3GHZ, DFI p35LT 4GB 1000MHz, X1950pro
http://forum.purepc.pl/index.php?act...=post&id=20627
http://forum.purepc.pl/index.php?act...=post&id=20628
http://forum.purepc.pl/index.php?act...=post&id=20629
http://forum.purepc.pl/index.php?act...=post&id=20630
http://forum.purepc.pl/index.php?act...=post&id=20755
http://forum.purepc.pl/index.php?act...=post&id=20878
Waterblocks are from www.watercooling.com.pl
F3D cpu
F2NB NB&SB
F2GPU
rad 2*120mm with Fander fans
Liang with OClabs
O-tank 250mm
There is a lot of work to do with that setup:
-painting, cable management, some modifications for case.
mib fatter tubes please ! And u right...correct cable management mate :)
Keep going ^^
So do it :) In this LC it will be look very nice.
Oh yeah, I'm RED DEVIL's Fan :) And I'm proud of ithttp://img181.imageshack.us/img181/4...dbannertb4.gif
Just finished my watercooling setup a couple of days ago. Hope you like it.
http://i24.photobucket.com/albums/c3...P1010326-s.jpg
http://i24.photobucket.com/albums/c3...P1010328-s.jpg
http://i24.photobucket.com/albums/c3...P1010330-s.jpg
http://i24.photobucket.com/albums/c3...P1010332-s.jpg
Hi mib :D fajnego masz sponsora ;)
:cool:
I cant belive it, 2 systems in the last two pages with bad fusion orientation just after it was mentioned,
Daidalos : I think you should rotate your block, it will help bleed air bubbles and stop air getting trapped inside, i like your set up though :)
@taylormsj: I know about the orientation but the system bleed completed with no issues. This position helps have a cleaner look i think.
some pics of the outside of my build. not sure what to do about the graphics loop. put my 8800gt under water until the 4870x2 comes out or wait.:shrug:
also should i go for a different shade of blue or a different colour
your right lyl ill post some picks of her inside today. Just realized that after i read your post.
Some miscellaneous pictures of my old setup on different hardware... Still waiting for parts on the new one. Needless to say i'm anti-high-flow :D
http://www.allsinclair.com/project/intel19.jpg
http://www.allsinclair.com/project/intel10.jpg
http://www.allsinclair.com/project/intel18.jpg
http://www.allsinclair.com/project/intel25.jpg
http://www.allsinclair.com/project/intel11.jpg
Heh, yeah elbows-r-us in there :D
Next system will be different, way less restrictive and with pneumatic connectors. Poor LAING cannot show its potential there :p:
EDIT: No, it's not 10/8 tubing, it's EVEN LESS 8/6 tubing. Don't really feel the need for high-flow as the temperatures are as low. Why take chances with pressure?
does anybody else see drinking straws? hehe
Hehe, that is alot of elbows!
My new project - Koen Server:
http://i2.photobucket.com/albums/y32...0Server/06.jpg
http://i2.photobucket.com/albums/y32...0Server/07.jpg
http://i2.photobucket.com/albums/y32...0Server/08.jpg
http://i2.photobucket.com/albums/y32...0Server/11.jpg
Mod Log can be found here
