Try the above plz... I can boot and be stable at 227 Bclock with my crap 950... no other board has done that here (not Xpower, not UD9)
Out of all the chips tested this is the 2nd best so far... http://i43.photobucket.com/albums/e3...t/06630ghz.png
Very impressive Bodar,
my word you must have pumped some cash into your machine, how many chips do you now own?
I must admit I really want one of these 980's what's the secret and the best to look out for?
Thanks man! I decided to basically test 20 chips total.. Not all where 980x's A couple x5660's and a xeon w3680 as well.. This time I tried to get the same batch number for all 980x's.. This batch is great! So far the
lowest clock I've seen on this batch is 6400mhz.. There's 2 chips that I really like but I'll probably sell the rest.. Just decided to go nuts this time.. Hope to make a little money back once I sell them. cheers!! -Beaux
Sorry I referred to you as Austin instead of Bodar, I was looking at your location and it stuck in my mind lol.
I assume you are using LN2 to cool these chips at that speed?
Don't think there's any other way to go over 6ghz with a GT...
try first Prime95, set to 8 threads and run Custom 20-20K set... this to determine CPU stability first..., then we will move on from there... if it reboots you need more Vcore...
Can you post your BIOS settings for 4.4Ghz with the 920 and 0704 Bios ?
I am at 4.33Ghz now :
http://img72.imageshack.us/img72/2321/433z.jpg
No POST for over 222 BCLK:confused:
Just one H20:
http://img822.imageshack.us/img822/591/eksb.png
http://img267.imageshack.us/img267/309/dsc02403v.jpg
But I bet I have the sexiest case of any R3 owner ;)
http://img245.imageshack.us/img245/9656/dsc02338q.jpg
http://img33.imageshack.us/img33/2268/dsc02321m.jpg
Pretty impressed with this board:up:
255 bclck was impossible on my RIIE...Vtt was only 1.4 v
thats just amazing 1.4 vcore to get that 4.8 got your self a great chip there i cant even get 4.3 stable at 1.37 vcore.
anyone else having trouble with 704, I get corrupted bios reflashed twice now.
0704 works fine for me, have not OC'd the 980 yet with it, will see if I can get the 255 bclck as well
flashed to 704 using ez flash yesterday from 534 worked fine thankfully :)
Single Stage
Splave Im all good on 0704, not sure what to suggest sorry !
Kortas, you are very welcome my friend, glad your all up and stable.
Ive ended up at 4.2 stable with my 920 , cant run to the 980 as Ive done my cash for now on a couple of C300s ( raid 0 on the Marvell) very pleased with them so far :-)
Rick
I think its the 5984 bios on my bios chip 1 that is messing it up when I go back and forth. Will try flashing both to 704
Ok just updated my bios to 0704 all went well so i tried 200x21 for 4.2 and vcore at 1.375 it just would not boot into windows BSOD!!!Can some1 plz post some bios settings for me to try dying to get this 980x stable at 4.2 or 4.3 that will do me.But having problems geting there
i have added a template i have copied would like to know what to set it at for 4.2 or 4.3ghz.
Target CPU Frequency 4410MHz
Target DRAM Frequency 1683MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Auto]
BCLK Frequency [210]
PCIE Frequency [100]
DRAM Frequency [1683]
UCLK Frequency [3789]
QPI Link Data Rate [7579]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 6 [6]
RAS# to CAS# Delay 7 [7]
RAS# PRE Time 6 [6]
RAS# ACT Time 18 [18]
RAS# to RAS# Delay 4 [4]
REF Cycle Time 72 [72]
WRITE Recovery Time 12 [10]
READ to PRE Time 6 [6]
FOUR ACT WIN Time 24 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 1N [1N]
Round Trip Latency on CHA 60 [60]
Round Trip Latency on CHB 62 [62]
Round Trip Latency on CHC 64 [64]
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 18 [Auto]
READ To WRITE Delay(DD) 7 [Auto]
READ To WRITE Delay(DR) 7 [Auto]
READ To WRITE Delay(SR) 7 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 8 [Auto]
WRITE To WRITE Delay(DR) 8 [Auto]
WRITE To WRITE Delay(SR) 18 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [1000kHz]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage 1.415 [1.41250]
CPU PLL Voltage 1.812 [Auto]
QPI/DRAM Core Voltage 1.310 [1.31250]
DRAM Bus Voltage 1.654 [Auto]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.244 [Auto]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
plz not above settings are just copied from another site and the settings on it will not work for me as of my ram is dominator gt 2000mhz.Anyone with simular spec to mines can u post your settings thanks .
