Originally Posted by
KTE
Here's the first inaccuracy which is going to make everything else flawed. That's not even close to stable Achim and I know this because I can get very low VIDs and high MHz 30min passed. If you test proper stability, you'll get accurate figures to put into your formula. Stable means hiccup free, smooth at all times no matter what you do. Pick two separate low settings, as you chose below and stability test them properly, I mean game and run software etc, then try this formula below again. ;)
Wait a minute.. you didn't have any options for CPU/IMC voltages last I recall? The only thing you were manipulating was CPU and NB VID, right? :confused:
What are these values below exactly and did you measure VCore voltage with DMM to match these figures?
Your board doesn't give IMC voltage, so that can't be correct, unless you're talking about Voltage Identities?
Here's my lowest stability:
CPU - 2300MHz 1.175VID 1.160V Idle/1.152V Load
IMC - 1800MHz 1.050VID
Now tell me, IDK the IMC voltage, I only can know my VID which is not the voltage... so which two values are you going to use for CPU/NB in your equation?
