microcode already put in since F3b bios.:)
Can someone re upload F6x please?
edit: Nevermind, got it from TT.
Hello everyone.
I recently bought this motherboard with i7 930 and 6gb gskill ram running on f5 bios.
Haven't yet tried to Overclock anything since I like to get the system running prefectly before playing with it.
Two things have caught my attention:
1st in bios it says my multiplier is at oem 21x which would mean 2.8ghz but once I exit out of the bios and press tab on the black screen it shows 2.93ghz x22 and on cpuz in windows it shows 2.93 x22 also?
2nd some lights are on, I checked the manual and they really did a crappy job explaining and defining what the lights mean, so I figured someone in here might be able to help me out. the nb phase/ddr load only comes on when I set my ram to run at factory 1600.
http://i10.photobucket.com/albums/a117/90tegra/x58.jpg
*****EDIT***** I fixed teh led for ddr/phase by manually setting the voltage to 1.5. But that temp for cpu and nb is still lit.
A little side note on the mod shot, the brown "resistor" is no resistor. The brown SMD components are capacitors. The measured resistance there is the currents through the surrounding other SMD parts/chip.
Not meaning to be a smartass, but everybody seems to think they are resistors.
On a side node, if we are referring to Gulftowns here, do we speak of the 32 nm hexcores?
Are there any 32 nm quadcores out yet, like Xeons? Any planned release dates for 32 nm quadcore i7s yet in the rumor mill?
I just don't want to shell out like 900 Euros for a hexcore whose performance I can't even remotely take advantage of on an all days basis...
Saw this at MicroCenter, http://www.microcenter.com/single_pr...uct_id=0331303 kind of hard to pass up. I may grab one next week.
New bios F6 Final:
http://america.giga-byte.com/FileLis...58a-ud7_f6.exe
Bloody heck! Gig are throwing those bioses out faster than a really fast thing being chased by a cheetah! Not that I'm complaining.
DiscoTech, there really wasnt much difference between the 2 mobo's, max blck and voltage are more cpu dependant I think, (no real gains in cpu OC) finding that golden cpu is more important. But the UD7's better phase power design suggests it delivers smoother constant power to the cpu, (the reason I bought it) I find it more stable under extreme OC, but is this all a placebo effect?
Is that F6 BIOS any good? I just updated to F5 and I must say I'm not impressed. POST takes a bit longer and I no longer hear any beeping at all, WTF....
old F6a and F6x worked well for me but the newer F6a dated 8 March was unstable once I put it, I got a black screen after the welcome screen with just the cursor moving after I put my old stable settings on first boot, didn't happen with any bios before. I hope the official F6 is not same as the F6a dated 8 March. I will just stick with F6x for now.
Hi everyone,
I recently bought this motherboard with i7 920 and am aiming for 4.2 stable on air (TRUE)
it is stable, however if i completely power off/ shut down I get cold boot multi restart failures- however when its running warm its fine.
what do i need to tweak to stablise this?
curently:
vcore 1.35
qpt/vtt 1.335
cpu pll 1.88
ioh/ich 1.3
dram 1.64
bclk 200
bios f5/f4
thanks
yes thats exactly what i mean
HOWEVER ,,,
then when I enter the bios it gives a red warning saying: overclock failed etc current values may be different from those represented...
and sure enough when it finally boots to windows (if i let it continue)my cpu speed is 2.8 ghz
clearly it indicates a failure to boot and its resetting to safe values......
edit it does it on 4.0 ghz too
please note my 4.2 ghz is linx and prime stable, memtest normal
edit after testing a lot seems like LLC is the culprit! (load line calibration) when set to standard it boots normally!
Hi all,
My standard v core value showing in the bios has always been 1.23125, but yesterday I suddenly noticed it had changed to 1.15000, and now today it has changed again all by itself to 1.14375. Does anybody know why this is happening. Anybody else had the same thing? I use dynamic v core - a great feature, but has this somehow gone funny and responsible for the random change in v core standard value?
The only other changes i made prior to this happening was I changed pcie to 101 and disabled turbo mode on the chip itself as I wanted to do a straight overclock without turbo.
Any ideas whjats going on here? Currently using bios F4.
Mark
Thanks for the reply. How stupid of me - should have thought of that doh!!!!
Mark
Hang on a minute though. Surely just enabling or disabling turbo mode on the chip itself should not change static v core value - I can understand that
when turbo is active then more v core needed and vice versa when not. Perhaps I am missing something???
FrenchPcdiga,
if your memory is G.Skill F3-12800CL8T-6GBPI-B ,adjust latency and VDimm.
Read this thread:
http://www.xtremesystems.org/forums/...d.php?t=212624
