Psu is fine, it powers the gtx280 in the second slot no problem? any more ideas ??
Hello, I have a Q9450 (8*358Mhz) I wonder if I can increase the multiplier to 9?
I apologize in advance if this has already been posted in this excellent 300+ page thread. Did ASUS ever release a BIOS after version 2004 that allowed you to increase the multiplier for an extreme edition CPU (QX67000)?
Hi guys, can anyone help me please? :confused:
I've just swapped out my E6600 for a Q9450 and updated my BIOS to 2801. I'm trying to install Vista but I keep getting 'memory management' BSOD and sometimes it just restarts after a BSOD (too quickly to read the exact errors).
I've ran the Memory Diagnostics tools and it says my memory is fine. I even replaced the RAM with another pair but still it crashes. I was reading this thread and someone suggested trying to increase the voltage on the RAM so I increased it to 2.0v but still no joy :( .
Is there a way of knowing whether it's the CPU or the BIOS that's causing the problem?
So far I know it's not the GPU, RAM or HD.
I'm using:
P5W DH Deluxe (2801)
Q9450
2GB OCZ
320GB HD
7800GTX
Thanks in advance guys! :)
Since things are going badly, take the time to do that again with the battery pulled. Even if it doesn't help, it's one less thing to wonder about later.
My Q9450 worked OK with most stuff at AUTO, but I *believe* I put the memory setting back to the 4-4-4-12 manual that I had been using at 2.1V. Perhaps you also need to set the FSB at 290 like I have to. However, my PC rebooted after a few minutes running Windows, not right at the start like you...
Not having a lot of luck on the support front. Each time I contact a new support technician (up to #3 now), I hear encoraging talk of how the 1.02G issue will be looked into, then nothing. If I had to guess, the eager support people go ask about 1.02G then they are told it would be expensive to admit the problems and to ignore any questions.
I'll wait another week on the current guy, then seek another way to get ASUS to at least tell us that the 1.02G version is no longer supported and to please go buy another ASUS board...
I have a q9550 along with an asus p5w dh of course. Everything is fine except it always stays at 2.83ghz even when at idle. My old q6700 would adjust depending on system demand. I have set Current power plan to balanced and auto settings on all in the bios. Anything else I need to do or any suggestions??
Oh, running vista 64, sp1
Are these 3 techs at the same level or have you tried a supervisor? I don't envy you going through this hassle but I sure hope your persistence pays off.
Maybe I'm naive but I think since ASUS already declared P5WDH BIOS support for new processors they should follow through.
They are just the guys that answer the phone (eventually) when you call for tech support. They keep going off to ask about the issue, then I never hear from them again.
And yes, one of them DID say that not being able to run the Q9450 reliably at stock settings was grounds to replace the motherboard, but I'm now thinking that I will be told otherwise by someone who knows how much that policy will cost given the number of 1.02G boards out there...
I'd like to ask whether rev. 1.03g has also problems with adjusting voltage below 1.4V ?
Thanks in advance
omg keep this board going guys...
: D
http://www.tomshardware.com/reviews/...ress,2095.html
New and I think the last review of our P5W DH.
They compare perfomance of i975 in Crossfire to new P45 and X48. And perfomance of i975 memory controller is very strong outperforming X48-DDR2 :)
So in many cases it makes P5W to be a leader even with lowered Crossfire bandwith on it, then 8x PCI-E slot is 4 times slower than 16x PCI-E 2.0 on X48.
Hi,
I try to update my bios on my P5WDH and it fails
2004 to a more recent version (i tried with all versions and last 2801)
Because i want to update my CPU.
I try by 3 methods
Alt - F2 and a usb key with P5WDH.rom
result : Failed to flash
form bios with Ez utility 2:
result : bios data does not match the file content
from cd-rom .iso (afudos)
result : block data does not match file 0x000F0000
Can you help me ?
Best regards
Allan
N.B sorry , i am not sure that it is the good place for this question, but i wish that a expert can reply :)
Oh somebody please reply! I am trying to same thing, going form 2206 to 2801 and have failed both Alt - F2 and EZ Utility 2 methods with a USB Flash drive!
I just updated the BIOS today to 2801 from a USB flash drive by using the EZ flash utility. I'm not sure which BIOS was present - perhaps 2704? However, the BIOS upgrade did not solve my problem. :(
I am using an E7200 on the P5W DH 1.04G. Unfortunately there is no way to change the core voltage with this CPU to anything but "AUTO." Default core voltage is 1.05V so OC > 3GHz is impossible. The same CPU runs fine in other boards at 3.6-3.8 GHz. The CPU I previoulsy used in the P5W is an original E6700 from 2006. That CPU works fine and it is possible to change the core voltage. Is it just impossible to change the voltage because the E7200 is too new a CPU for the P5W DH? Thanks.
EB-1, this is a frequent issue with our board. You should flash using this procedure:and then remove both battery and jumper to have full CMOS clear. I think this should help you.Quote:
EITHER Flash using AFUDOS and the tags "afudos /i****.rom /p /b /n /c" (without quotes) , then clear cmos as the manual describes [Credit - OPB] OR Disable Speedstep and Enhanced C1 Control in the Cpu Configuration section of the BIOS. [Credit - DjLeco]
I have a P5W DH Deluxe rev 1.02G board and recently acquired an E8600 cpu. After flashing to 2801 and installing the chip I noticed i was also unable to set lower voltage values in the bios.
Then I downloaded and installed the latest Asus AI Overclock utility. To my surprise I was able to set lower voltage values through the utility than through the bios. After re-booting the system posted 4ghz as if it was taking the new lower voltage. I went into the bios and notice the voltage value was 1.4 (not the value I set) but it was highlighted differently. My system was not stable but I have yet to do any further tweaking.
I would think the bios should at least report the values set by their overclocking utility. Is the utility a backdoor to setting up the bios on these older rev boards? Is it advisable to continue down this road?
