Originally Posted by
hartigan
I'm hitting 40*C with the North Bridge at 1.696V under load. So far . . . it's stable with that setting but, I've only run p95 for 10 minutes. I'll update more with that later.
One thing that is weird (and I don't think I can fix it) is that my Core 0 and Core 1 always report 10 degrees lower than Core 2 and Core 3. It doesn't matter what monitoring prog. I use (CoreTemp, RealTemp, Everest, etc.).
Also CoreTemp and Everest report 63* and 73* for cores 0,1 and 2,3 respectively. Whereas RealTemp reports them as 53* and 63* From what I've read, that has something to do with the TJ Max settings being different.
I'm comfortable with the temps reported in RealTemp (53* and 63*) as long as they are the most realistic temps. I just hope that I'm not surpassing the 70* limit mentioned for these processors.
If anyone has any thoughts on my 10* discrepancy between cores, I'd be curious to hear them. From what I've read, the best diagnosis is a stuck thermistor on the core that has 0 and 1 on it.
Thank you very much for your help Zucker2K!! I owe you.
