Originally Posted by
r4st4m4n
I just downloaded it yesterday and tested the spike created when idle Vcore is 1.2V. But it seems Crysis demo make the voltage going higher than Aquamark 3 :rolleyes:
I've also tested 3dmark01 and the test 8 or 9 (can't remember exactly the name) is what makes the voltage going higher by far. While any other test including Crysis bench only make the voltage go up to +0.055, this test make the voltage jumps up to +0.08 :eek:
I'll try tonight to set idle Vcore at 1.35V and run the 3dmark01 test, if it doesn't make the OCP kick in, I think nothing else will and I'm not willing to go higher on voltage anyways.
Yesterday I was a little bored to run benchmarks, so I tested the stability by playing Crysis. So far it seems 784/1944 is stable at 1.2V. At least it is after 1+ hour of Crysis. :up:
