i wish i could have gotten my Q9650 to do 9x500@4500 ddr1200.i can do it with my E8400,but i would love to have done it with a Quad.
i bet it the system just screams
just grab a L828A446 and you will mate ;)
you can feel the speed took me a long time to get the system this fast and i love it, i was so anxious that i just cut the tubes and installed it, i was going to remove all plasticidez tygons but i couldn't lol, i just wanted to try this beast :D
Cheers radaja
Sergio
"just grab a L828A446 and you will mate"
easier said than done:rolleyes:
theres not many people willing to sell the good ones:(
a new one mate...you can find it on ebay we brought it from Canada all L828A446 are ALL vid 1,15to 1,1875 that's why i say so, of course such a low vid for me in summer i have to forget about 4400 or 4500 (i don like cores IDLE at 47C) but in winter its a pleasure :D
Sergio.
damn, 47 even on water, im guessing you dont have AC
Q9650@4,40ghz prime stable on water
http://www.abload.de/img/44ghzmqmc.jpg
i found out why my boot screen went all screwie, i installed a temp operating system using the gsata, then when i swapped it to the intel sata i got a screwed screen, swapped it back and now its fine, kinda strange.
Andrew
Nice overclock guys, I'm quite happy with mine at 4Ghz on air with a Zalman 9700NT cooler, does a pretty good job as well.
Hi Guy's i'm looking for some help i have a Asus P5Q deluxe with the Q9650 VID 1.2375 on water, can't seem to get it any higher then 3.9 with 465 bus. here are my settings hope you can help me get in the 4's with a good bus.
AI tweaker
CPU RATIO 8.5
FSB FREQUENCY 465
PCIE FREQUENCY 101
FSB STRAP TO NB 400MHZ
DRAM FERQ DDR2-930MHZ
ALL DRAM SKEW'S AUTO
DRAM TIMING CONTROL AUTO
DRAMSTATIC READ CONTROL AUTO
DRAM READ TRAINING AUTO
MEM. OC CHARGER AUTO
AI CLOCK TWISTER AUTO
AI TRANSACTION BOOSTER AUTO
CPU VOLTAGE 1.275
CPU GTL VOLTAGE REF 0/2 .68
CPU GTL VOLTAGE REF 1/3 .68
CPU PLL VOLTAGE 1.58
FSB TERMINATION VOLTAGE 1.34
DRAM VOLTAGE 1.96
NB VOLTAGE 1.36
NB GTL REF .67
SB VOLTAGE AUTO
PCIE SATA VOLTAGE AUTO
LOAD LINE CALIBRATION ENABLED
CPU SPREAD SPECTRUM DISABLED
PCIE SPREAD SPECTRUM DISABLED
CPU CLOCK SKEW DELAY 100 PS
NB CLOCK SKEW DELAY 200 PS
CPU MARGIN ENHANCEMENT OPTIMIZED
ADVANCED TAB
CPU RATIO 8.5
C1E SUPPORT DISABLED
MAX CPUID VALUE LIMIT DISABLED
INTEL VIRTUALIZATION TECH ENABLED
CPU FUNCTION ENABLED
EXECUTE DISABLE BIT ENABLED
HOPE YOU CAN HELP!!!!!!!!!!
My system's att 4,4Ghz now. Only adjusted the vcore and the vtt. Vcore 1.40v vdrop to 1,38v and vtt 1,44v. Anyone have any suggestions on settings for ram timing\volt, NB SB volts.. It's not prime stable, but stable enough to play games and run 3dmark. Anything that can be adjusted so i might get to oc the 4870x2 some.. Just abit of oc and i get fragmets. Tried 4.5 just for fun but no go..
Put the volt up to 1,435vcore 1,48vtt.. Time to get a one of these maybe :D
1 - extreme
2 - dq6
3 - ud3p
http://img.photobucket.com/albums/v2...r/system-2.jpg
Try this out.
AI tweaker
CPU RATIO 9.0
FSB FREQUENCY 456
PCIE FREQUENCY 100
DRAM FERQ DDR2-912MHZ
CPU VOLTAGE 1.30
CPU GTL VOLTAGE REF 0/2 .635 - .645
CPU GTL VOLTAGE REF 1/3 .635 - .645
CPU PLL VOLTAGE 1.54
FSB TERMINATION VOLTAGE 1.30
DRAM VOLTAGE 1.96
NB VOLTAGE 1.36
NB GTL REF .665
SB VOLTAGE AUTO
CPU CLOCK SKEW DELAY 0 PS
NB CLOCK SKEW DELAY 0 PS
because i have it prime stabil many hours Q9650@4,40ghz :D
http://www.abload.de/img/44primestabilxgd7.jpg
Thanks Hoss331 it works gr8, is there anything eles i can do?
hey guys
i keep playing with my Q9650 and the GTX285 awesome card keeps going up and up, i also played with the Q9650 at 510x9
http://img30.imageshack.us/img30/804...vgaoc3xp32.jpg
Cheers
Sergio
Have you checked to see if its stable yet? Your chip may or may not need that much vcore so if thats stable try raising the fsb more. On my Dlx. for that FSB I used 1.2312vc, 1.54pll, 1.26vtt, 1.28nb, cpu gtls @ .635, nb gtl at .665. I was only using 4gb of ram so you probably wont be able run the nb I did but you may be able to lower it some. Also if you havent set the PL you should be able to lower it 2 steps down from auto.
I made stable 4320 Mhz with my new Q9650 . Batch L826B006 VID 1.20
[IMG]http://img198.imageshack.us/img198/5276/9x480.jpg[/IMG]
I think it can reach 4600 Mhz (9x511) but I do not have a clue how to do it. So please can someone to post a template for MIIF .
Guys whats the limit for fsbvtt for 24/7 use with our q9650?
I need arround 1.5 real for 500fsb, is it ok?
Here is my "achievement":)
http://img25.imageshack.us/img25/5386/skrmklippl.jpg
http://img25.imageshack.us/img25/9559/skrmklipp2.jpg
just noon here and already past 80+F ambient
http://img32.imageshack.us/img32/5056/97572449.th.jpg
ep45-extreme/thermalright ifx14/2x low rpm fan/fully loaded system
holding up pretty cool.. so much for summer temps :)
Sergio, nice card you have there. The clocks on that 285 are very impressive.
Here comes some goood stuff:D
http://img5.imageshack.us/img5/9289/skrmklippcrazy.jpg
i decided to burn everything i have :rofl:
Great clocks with that GTX andressergio!!!
greg.m,very nicely done:D
nice going mate :toast:
unmodded evga gtx 285 2gb ftw stock/air cooling.. all air cooling
http://img507.imageshack.us/img507/1084/50575655.jpg
Hey guys, finally winter is aproaching and i started playing with the Q9650 :D
http://img190.imageshack.us/img190/51/spi10w.jpg
Cheers all :up:
Sergio
andressergio,that is just awesome!your going to have some fun now(now that winter is coming).i cant wait to see what clocks you get next.
P.S you have got a great cpu:D
http://i306.photobucket.com/albums/n...anie1/PIWR.jpg
Lots of fun to overclock these CPUs.:up:
Too bad that Jor3lBRs run is marked invalid, I need a new goal now.:(
http://www.hwbot.org/result.do?resultId=843116
yeah too bad he made the mistake to not show the run completely (I did that too wit the E7400 bummer), he can redo that bench prolly... I would still try to beat that score mate, Jor will be back :)
You can still try a full sweep, pifast, pi32Mb etc
I am running q9650 with a asus P5E3 Deluxe at 4 GHz and v core of 1.42v in BIOS and CPU-z shows 1.4v on idle. prime 95 stable. I'm a bit worried about running the v core at 1.42v. Do you think it's safe? I tried to use load line calibration but it won't boot into Windows over 3.6 GHz. If anyone is running the same processor i would unappreciated if they could post their BIOS settings so I can see what I'm doing wrong. On other forums people are getting 4 GHz at lower voltages. please help.:help:
I got mine stable at 1.367V though some people got theirs stable with lower volts but I'm happy with it. 1.4V does seem a little high though, maybe it depends on your chipset and motherboard.
is 1.367v in bios or in windows in cpu z? Are you using load line calibration? i tryed 1.367 v but not stable in a prime 95 test. i get to much v core drop.
it is a bit to high and load line calibration won't won't work above 3.6gzh. this never happned with my q6600.
i have updated my bios 1409 as well. no luck. maybe i just have a bad cpu
Well guys just pumped more FSB without touching vcore and get this :)
http://img366.imageshack.us/img366/9...vgaoc1xp32.jpg
Cheers all mates :up:
Sergio
OMG thats a sweet Quad core you've got there andressergio
Nice score andressergio, that cpu/board/ram combo is really going well.
Impossible FSB for QUAD, andressergio ! Great job !
Damn!!! Sergio, you're just like energizer bunny....that keeps going and going! :up:
@CryptiK
Hey dude! Hows it going? When do you plan to move to the Gigabyte UD3P? I see you're still on the M2F.
Sorry Have'nt Found Any Thread About My Quad :)
But Look Like Q9650
http://img98.com/images/h6tmgr9o4f2ym9l4o3gl.jpg
http://img98.com/images/pgljve0ndnjwmyjvz1z.jpg
http://img98.com/images/sft4uw13z3x1st7uv9k.jpg
But Many Times Can't Stable On 500FSB I Played With CPU Clock Skew & GTL's But Not Diffrent
Can U Gays Help Me For Stable In 500FSB?
Sorry For My Bad English
