I'm a gamer.
Secondly, I've been hunting since I was 5yrs old. A lifetime of gun blasts nearly every day of my life without hearing protection has left a nice ringing in my ears. :)
The xfi sounds golden to me! hehe
so guys, i've just submitted an RMA for my P5K premium... i dont want to spend money on getting a X38 at the moment... and as for OC'ing, i am no pro, but would like this build to be my OC'ing first...
would you recommend this board over P5K Deluxe or Premium?
thanks.
Yes ....get the Board its a Bad Mutha F@cka:slapass:
so far im VERY happy with this board so i can just agree with Esau, get this board :D
but be aware, you will spend quite some time getting infos, and playing arround with all the settings...cause there are...quite a few options in the bios ;) (i had a p5k deluxe aswell...sold it cause...donno..didnt ever feel really comfortable with asus boards...)
The Asus bios NEVER felt right to me cause it's AMI. Laggy, crappy, odd keystroke movement to get around. DFI and Abit both use Award and it shows.
Got mine on the slab awaiting a G0 Q6600--everything else is ready to go. Been re-reading this great thread and getting psyched.
Finally Finished up some Prime Blending.....Pretty Happy So Far!!
http://img229.imageshack.us/img229/8...end1si4.th.jpg http://img206.imageshack.us/img206/4...end2dj6.th.jpg http://img229.imageshack.us/img229/9...end3xr5.th.jpg
Bios Settings
http://img206.imageshack.us/img206/6...2020ja5.th.jpg http://img229.imageshack.us/img229/9...2021jt5.th.jpg http://img229.imageshack.us/img229/1...2022ta3.th.jpg
http://img394.imageshack.us/img394/1...2023mp9.th.jpg http://img206.imageshack.us/img206/2...2024fb2.th.jpg http://img394.imageshack.us/img394/6...2025dr8.th.jpg
http://img394.imageshack.us/img394/9...2026nw1.th.jpg http://img206.imageshack.us/img206/3...2027tv3.th.jpg http://img229.imageshack.us/img229/8...2028rr3.th.jpg
Took a while but Blend is definately stable. Time for some more Small FFT's.
Empty
Like I have said before anything prior to getting this Motherboard has felt incomplete and lacking in what I expected a Overclocking Motherboard to be although I will say this the Abit IP35 Pro that I had before this is a most excellent board but this board surpasses it in leaps and bounds its just a overclockers Dream come true.
Just waiting on my Cell Shock 4-4-4-12 (PC2 8000) Ram so I can take this board to the Xtreme:cord: :cord: :cord:
Also as a strong point of interest for those of you considering this board the Cooling system that delayed the release of this board was and is well worth the extra wait time PWM area Full tilt Prime 8hrs never climaxes over 51c and NB 50C and mine runs hotter than most I can only imagine how well this cooling system really works with the entire Transpiper/ Copper Plate set up in conjunction with very good water cooling:eek:
Any help on this
http://www.xtremesystems.org/forums/...d.php?t=160130
DFI UTP35-T2R and Galaxy 1KW no GO
Gave you what I know already! It's a DFI man and they are renowned to no like some PSU's but I would think that would not be one of them for sure.
Try another power supply:rolleyes:
Heres a screenie of my 8hr Prime run:up:
...um... it must be getting late... cus i dont see any pics...
You must be tired. Looks great Esau! :p:
Sorry experiencing some technical difficulties with image uploading! But thats pretty impressive right > this boards so fast you cant even see it:D
I'm getting there...
I did an 8 hour prime95 v2.54 large fft run with my G0 Q6600 L725A903 @ 450x8. I brought the CPU VTT voltage down to a level I'm more comfortable with. I found that it's all in the GTL's. At first I was trying using the 67% rule, but after bumping them up progressively (leaving everything else the same), I went from a few minutes before failing large fft to eventually settling on 116/116/117, which allowed the 8 hours without failing.
8x450fsb with Tuniq Tower 120 and a TT 12cm fan at max speed over the NB/PWM area.
http://img213.imageshack.us/img213/1...x8lowerij0.png
Bios settings:
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 8
- Target CPU Clock: 3600mhz
CPU Clock: 450mhz
Boot Up Clock: Auto
DRAM Speed: 333/667
- Target DRAM Speed: DDR2 901
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control: 1.40625v
CPU VID Special Add: Auto
DRAM Voltage Control: 2.19v
SB 1.05V Voltage: 1.150v
SB Core/CPU PLL Voltage: 1.75v
NB Core Voltage: 1.57v
CPU VTT Voltage: 1.48v
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Enable
x CPU GTL1/3 REF Volt: 116
x CPU GTL 0/2 REF Volt: 116
x North Bridge GTL REF Volt: 117
DRAM Timing
- Enhance Data transmitting: Fast
- Enhance Addressing: Fast
- T2 Dispatch: Disabled
- Channel 1 CLK fine delay: AUTO
- Channel 2 CLK fine delay: AUTO
CAS Latency Time (tCL): 4
RAS# to CAS# Delay (tRCD): 4
RAS# Precharge (tRP): 4
Precharge Delay (tRAS): 4
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance Level: AUTO
Read delay phase adjust: AUTO
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 6
Ranks Read to Read (tRDRD): 6
Ranks Write to Read (tWRRD): 5
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
116 for the GTL is pretty close to 67% with a VTT setting of 1.48V. Have to take into consideration that the VTT voltage set in the BIOS is only within 0.002-0.003 volts of the actual value. Also the GTL setting to actual voltage is a sliding scale. With VTT set at 1.20V a GTL of 125 will be 0.875V. But if VTT is set to 1.43 The same 125 GTL will be 0.975V.
What are you guys using for water-blocks on the NB, SB, and PWM?
i've read that P35 you really dont need WC'ing on NB/SB...
unfortunately, i've already received the EK ASUS NB/SB blocks when i was planning to base my build on a P5K premium...
now i've RMA'd the P5K... and waiting to see when i receive the DFI...
Nothing... It certainly doesn't need it at 500mhz bus. Not hot at all. Runs 4ghz as listed in my sig orthos stable for 12 hours and the n/b and pwm temps never go over 55. this is in an enclosed internal case, not an open system, and no transpiper installed. Also, I live in Arizona, and my ambient temp is 82 degrees F in my house.
I'm telling ya I really good CPU Block ( D-TEK Fusion) with the Transpiper and copper plate installed and you will be way good most definitely!
Heres my 3.4GHZ Prime run on this Board will post up template in a little while
